Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 07-31-2014, 02:34 PM   #1
toskeysam's Avatar
2013 Interstate Coach
Townsend , Tennessee
Solar panel fuse
On my 2013 AI Ext, I am reading zero amps from my solar panel. Have been for some time now. Batt voltage is below 12.6.
Sitting in full sun all day....no amps. There is a fuse between the panel and the control module.....anyone have a clue where it might be? Or any other suggestions?
FMCA # 436814
toskeysam is offline   Reply With Quote
Old 07-31-2014, 08:10 PM   #2
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Mine was located under the rear lounge/bed. IIRC, it was an inline fuse on the curbside near the BIM. Don't recall what size it was. I'd check but the AI is packed for departure. You do have to remove the "wall" under the bed to access it.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
Old 07-31-2014, 08:40 PM   #3
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
Yes the inline fuse for the solar panel is in compartment under the lounge/bed. You have to remove rear panel under bed to get access to than fuse.
- - Mike
2013 AS Interstate on 2012 MB Sprinter
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
Old 08-01-2014, 05:18 AM   #4
toskeysam's Avatar
Thanks folks....I have been that compartment several times lately, trying to troubleshoot the new battery monitor. I am surprised I did not see the solar fuse......probably because I was not looking for it. It is supposed to be a 10 amp fuse.
FMCA # 436814
Old 08-01-2014, 10:24 AM   #5
toskeysam's Avatar
Well.....I may not have seen the solar panel fuse for a good reason. Apparently my unit has the fuse "in the solar panel". There was no inline fuse in the wiring to the solar control module....or anywhere in the solar wiring under the lounge. Looks like I get to add this to the list for the shop. I am going to call them to see just where this fuse may be.....and is it easily accessed....
I vaguely remember someone found theirs in the wiring harness above the wardrobe.....might just look. If I have a day of nothing to do.
FMCA # 436814
Old 08-01-2014, 11:41 AM   #6
2024 Interstate 19
Fulton , Maryland
More evidence that Airstream wires units from same year differently.
- - Mike
- - Mike
Old 08-09-2014, 08:30 AM   #7
toskeysam's Avatar
I guess the fuse has not blown after all. We are seeing output from the panel now!!!! Left off shore power with refrig running for a few days! Just not used to seeing batteries with a full charge and how well they can perform when properly charged. 😊😊
FMCA # 436814
Broken Fuse Block In Distribution Panel - How Best To Repair montanaandy Batteries, Univolts, Converters & Inverters 12 06-01-2015 08:01 PM
What size fuse for 12-volt panel? paddy79 Electrical - Systems, Generators, Batteries & Solar 4 05-23-2004 08:39 AM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 10:21 PM
