Old 09-17-2019, 12:12 AM   #1
2015 Interstate Ext. Coach
Thousand Oaks , California
Solar connector corrosion
The solar wasn't providing any power on my 2015 Ext. and I found a corroded connector up there. Any suggestions for a different fitting are appreciated, the original fitting is positioned to collect water corrode.
ID:	352334   Click image for larger version
Ryoungca is offline   Reply With Quote
Old 09-17-2019, 05:55 AM   #2
Libertyville , Illinois
I’ll be replacing mine with one of these
Schmitte is offline   Reply With Quote
Old 09-17-2019, 08:23 AM   #3
LoveToWander's Avatar
Seattle , Washington
Attachment 352342
I've had trouble finding one narrow enough to fit in the space. I just replaced the existing connector with the same thing that Airstream used and buried it under a bunch of eternabond tape. It hasn't leaked in four months, so far. Rain season is just beginning now. Time will tell.
2016 Interstate GT Twin
LoveToWander is offline   Reply With Quote
Old 09-20-2019, 11:14 AM   #4
MC4 connectors are the industry standard. They have O-rings to seal out moisture and are generally about $2 a pair. Amazon has an SAE to MC4 breakout cable if your space is limited.
LB_3 is offline   Reply With Quote
Old 09-24-2019, 12:44 PM   #5
Thanks LB. Based on the first picture in my original post, it looks like I have an SAE to MC4 at the roof entry and then two MC4 connectors to the solar panel wires. Once I get up there and remove the existing Sikaflex maybe there will be enough slack in the wires to just use a pair of MC4 connectors and seal the hole.
Zamp connector and intalled solar Garfish Electrical - Systems, Generators, Batteries & Solar 48 08-30-2018 03:13 PM
Type of solar connector on the As roof waninae39 Generators & Solar Power 10 05-19-2018 08:36 AM
Should I use Corrosion X on brand new trailer to prevent corrosion ILOVESALLY General Repair Forum 31 06-25-2016 01:06 PM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 08:09 PM
Cracked City Water Connector wagsrp Fresh Water Systems 0 08-09-2002 01:48 PM
