Old 01-10-2019, 03:22 PM   #1
HOUSTON , Texas
Solar charging and outside shower
Still climbing the newbie inclined learning curve with my 2018 Interstate GT EXT.
Does the master switch for the house battery bank need to be on or off for the solar charging system to charge them or does it's position not matter?
Again, thanks in advance for your assistance.
John 1048
John1048 is offline   Reply With Quote
Old 01-10-2019, 07:23 PM   #2
Libertyville , Illinois
The solar charging will occur independent of the master switch position.
Schmitte is offline   Reply With Quote
Old 01-10-2019, 09:48 PM   #3
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
As Schmitte mentioned solar is not effected by the disconnect switch.
Your subject line mentions outside shower. Do you have a question about the outside shower?
- - Mike
Old 01-10-2019, 11:16 PM   #4
New Borockton , Alabama
Images: 21
Wonder if he was wondering it the outside shower gets hot. Kinda lost me too but certainly willing to help if possible.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 01-11-2019, 01:07 AM   #5
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
John 1048
JOHN1048 - As prior answers, makes no diff. Along the same lines - if plugged-into shore power or generator running, batts will charge regardless of switch position. No, the outside shower is not controlled by the Main Disconnect switch IF you are hooked up to city water. But if you are using your AI fresh water tank, then Main Switch has to be ON, in turn so you can turn on the water pump, which in turn will pressurize the system to allow water to all faucets (including outside shower). However, even if you are hooked up to city water, you may still need to turn on the Main Switch to turn on the water pump IF the water pressure coming from spigot is too low. The AI water pump helps build up the system pressure to 50-55 psi.
Alex AVI is offline   Reply With Quote
Old 01-11-2019, 02:21 PM   #6
HOUSTON , Texas
When I began the post I had an additional question regarding the outside shower. As I was composing the question I checked the AS owner's manual and discovered I may have not followed instructions and therefore deleted that question but failed to correct the title.
Thanks for all the responses to the solar charging portion. You guys are really patient with me.
USB Charging Ports not charging WkendWarrior Electrical - Systems, Generators, Batteries & Solar 29 09-08-2018 09:12 PM
Zamp solar 200 watt portable solar charging kit Cascadian Airstream Classifieds 0 05-11-2018 09:13 PM
TV Charging Needed With Solar and Inverter? youngpeck Batteries, Univolts, Converters & Inverters 7 03-17-2017 08:51 AM
Solar Charging Panel and Cell Phone Antenna noiva Generators & Solar Power 15 01-16-2006 06:06 PM
Solar and the Disconnect Switch/Charging/Phantom Loads Xray Generators & Solar Power 9 01-23-2005 12:55 PM
