Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 06-13-2015, 02:00 PM   #1
2011 Interstate Coach
san francisco , California
Slight Propane Smell Right by Shutoff
i was snooping around under the coach and i noticed that if i turned on the propane cutoff switch and then stuck my nose under the coach almost all the way up to where the actual shutoff valve is I could smell a whiff of propane. i spayed some soapy water and didn't see any bubbles or anything. would it be normal to have a slight smell right in that area or is there likely a small leak somewhere?
rwcmick is offline   Reply With Quote
Old 06-13-2015, 03:10 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
If you smell gas you have a leak. Nothing to mess around with. Have the system leak tested ASAP.
MICHAEL
Old 06-13-2015, 03:17 PM   #3
thanks. i think i have this one resolved. there were two connections, on on either side of this device (part of the shutoff?) with the foil tape. neither was really loose, but i could turn tighten each connection a bit with my crescent wrench. then i turned on the valve, didn't smell anything. then i ran the generator for a bit. got under there, still nothing. i'll continue to monitor it though. any other odors and off to the shop it goes.
Old 06-13-2015, 03:19 PM   #4
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
I would recommend taking it to any HVAC repair and have them use a "sniffer". It's a handheld device with a small gooseneck and sensor at the end. It can find leaks that wont necessarily bubble up with soapy water. That smell is a compound called Oronite that is added to Nat and Propane gasses.
You probably have a miniscule intermittent leak at the valve. Easy fix.
Clayton
NavyCorpsman is offline   Reply With Quote
Old 06-14-2015, 06:12 AM   #5
AWCHIEF's Avatar
Images: 33
After buying my new to me Safari I stopped off at Jackson Center to have a couple of immediate safety problems looked at. While there I had them do a complete inspection of all systems. I mentioned there was occasionally a gas smell. The tech used a leak detector at the gas joints and valves. He found a cracked fitting behind the frig. Due to low pressure it was causing a slow start when operating the frig on gas.
MICHAEL
Old 06-14-2015, 10:56 AM   #6
hamiltonmj's Avatar
2013 Interstate Coach
Opelika , Alabama
2 propane leaks
I had 2 propane leaks. 1 was the regulator. Solved on recall. The 2 nd was the purge valve.
hamiltonmj is offline   Reply With Quote
Old 06-14-2015, 10:59 AM   #7
1979 25' Tradewind
Watkinsville , Georgia
Put a good flashlight by the valve, then go to the kitchen & put a drop of dish soap in a half a Dixie-cup of water. Stir, then drip the mix all over your shut-off valve. Especially soak the shaft of the shut-off knob and the tubing connections. Turn on your flashlight and study the soaked valve, looking for bubbling especially at the base of the valve stem and where the tubing joins the valve. If you see any bubbling, shut the gas off at the bottle & take it to your dealer.
roebling is offline   Reply With Quote
Old 06-14-2015, 11:07 AM   #8
1981 31' Excella Limited
Anchorage , Alaska
I finally "bit the bullet" last autumn and bought a propane sniffer myself. I went with the CD100A Combustible Gas Detector, which can be ordered from Amazon for about $151 these days, I think. This thing is pretty much perfect for troubleshooting propane leaks- you can literally dial down the sensitivity to where you can quickly zoom in on minute gas leaks at a specific fitting, even with a very slow leak. It's got a long extendible probe, so you can poke it into small spaces where you wouldn't easily be able to use the soapy water test, and it's much much faster and easier than soapy water - perfect for my own impatient troubleshooting style. In the time I've had it, I've used it to trace a natural gas leak in my house at the dryer, find a loose fitting on my truck camper propane supply, find a troublesome long-time very slow seep on my Airstream (which was slow enough that it would have been hard to detect with soapy water), and test countless other fittings on my Airstream to make sure they *weren't* leaking. A valuable little tool which has paid for itself multiple times over for me. Something to think about for the toolbox.
aJ
1981 Airstream Excella 31'
Wasilla, Alaska
akflyer is offline   Reply With Quote
Old 06-14-2015, 01:07 PM   #9
1977 31' Sovereign
Lynnwood , Washington
A slight propane smell could be several things:
1) Propane tank is low. Correction, pressure in the tank i not adequate to sustain operation of an appliance. Pilot light goes out, but propane is still flowing thru pilot light orifice, albeit at very low pressure.
2) You have a loose fitting. Check fitting tightness. If a fitting won't tighten, it could be cracked.
Note - Under low-low propane pressure, the soap bubble test doesn't always work. Indeed, propane pressure beyond the regulator is pretty low anyway, about 7 psi.
3) Propane sniffers can be pricey, but a good investment nevertheless.
The rule here is this: If you think you smell propane, it's because you do - even it's for a fleeting moment. Never doubt olfactory sensor reception, especially that of your better half. LOL
Tom
TomKirk is offline   Reply With Quote
Old 06-14-2015, 02:47 PM   #10
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
Clayton
rwcmick -- this is a very good recommendation. You have had a few issues with this 2011 rig. It might be time to get it to a good knowledgeable Airstream Dealer that knows Interstates and have it checked over. I recall you recently bought it used from a private party. Unfortunately all RV dealers are very busy this time of year.
NavyCorpsman -- best I can tell Oronite is a business division of Chevron.
https://www.oronite.com/about/
I think the smelly chemical compound in LP and Natural Gas is Ethanethiol.
https://en.wikipedia.org/wiki/Ethanethiol
Old 06-14-2015, 05:15 PM   #11
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Cool
How 'bout "Mercaptan" for a smell????
MelGoddard is offline   Reply With Quote
Old 06-14-2015, 05:47 PM   #12
1987 25' Sovereign
Oregon , Ohio
Clayton
Natural gas ad propane have different smells. If oronite is added to propane, ok, I have never heard what it is called. After 40 years of working for a natural gas company I know that the odorant used in natural gas is called mercapton.
msmcv51 is offline   Reply With Quote
Old 06-14-2015, 05:53 PM   #13
Slowpoke
Gnorts's Avatar
2012 27' Flying Cloud
Portland , Oregon
Bingo.
I'm not too familiar with the Interstates - my recent B-van was a Sprinter Westfalia, imported by Airstream in 2005. JC had to convert 250 of these vans to meet US DOT and RVIA specs. My LP tank, right below the curb side slider, had a pressure gauge. Do the Interstates have pressure gauges?
If there's a pressure gauge in the system, you have a leak detector built in. It's easy to use: Make sure all LPG appliances are off, with their individual valves closed. Note the reading on the pressure gauge. Stick a piece of tape on the face of the gauge that lines up with the edge of the indicator in the gauge so you'll know exactly where the indicator is. Open the valve to the stove and light a burner. Turn the burner off at the stove and wait a while. 5 minutes should do it, but it could take longer if the leak is really tiny or the tank is low. (Best to do this leakdown test with a full tank.) Have another look at the gauge. If the needle has moved at all, you've got a leak. If all is good, you have proven that the main feeder from the tank to all the shutoff valves, and the line to the stove, are OK. Now proceed to the next appliance and open the valve. Don't start it - just open the valve. Wait a while and check the gauge. As soon as you see a drop, you have identified the portion of the system - appliance or piping - that needs fixing.
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
Gnorts is offline   Reply With Quote
Old 06-14-2015, 10:14 PM   #14
Thanks but I actually bought it from an Airstream dealer and I've seen what they are capable of. :-(
Old 06-15-2015, 12:04 PM   #15
2024 Interstate 19
Fulton , Maryland
Ouch!
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
1977 Argosy Possible Slight Rear end Separation Would you buy Please help Tony S All Argosy Trailers 4 07-07-2010 11:02 AM
Slight jerking below 40 mph greatlakes Hitches, Couplers & Balls 16 02-14-2010 02:15 PM
Slight noise from a Suburban furnace nickcrowhurst Furnaces, Heaters, Fireplaces & Air Conditioning 12 02-09-2010 05:36 PM
Power Twin Stabilizers and fore/aft trailer movement on campsite with slight grade TX_Streamer Jacks, Stabilizers, Lifting and Leveling 7 10-24-2007 10:00 AM
NT30 Suburban, slight problem Pick Furnaces, Heaters, Fireplaces & Air Conditioning 1 04-26-2003 07:16 PM
