Old 06-09-2014, 03:59 PM   #15
2014 Interstate Ext. Coach
Aliso viejo , California
Initiation, same alarm went off.. and would not stop beeping,,,The trick was "do not start the engine :until the sliding door is closed. If you start the enginge the alram is triggered and does not go off until it resets by turning off engine and opening and closing door,. Problem fixed for us. Hope it helps others
Interstate14 is offline   Reply With Quote
Old 07-10-2014, 08:16 PM   #16
Teamaron's Avatar
Boca Raton , Florida
Originally Posted by Protagonist View Post
If memory serves (though sometimes it doesn't) the issue originally came up in another thread, for an Interstate owner who was planning to use his Interstate for around-town transportation for an elderly family member, not so much for camping.
For a scenario like that, I could see the benefit of being able to leave the engine running when providing curbside pickup and dropoff services in city traffic. And I can see the benefit of extending the step with the engine running, as it's an awfully high step for a physically impaired person to get in and out without the sliding step.
Any further detail on how to have step open while engine running?
We are traveling with family and having to shut engine on and off to open step while dropping off and picking up is really getting difficult.
Our old 2010 AI would open in either scenario. Not sure what step hold button does.
Thanks.
Teamaron is offline   Reply With Quote
Old 07-10-2014, 10:13 PM   #17
David M's Avatar
2013 Interstate Coach
Orange County , California
Thanks.
See the pics on how to enable the step with the engine running. You'll need a stubby screwdriver as shown and a jewelers screwdriver to pull the wire indicated in blue. Good luck!
Name:	ImageUploadedByAirstream Forums1405051870.519264.jpg
ID:	216091Click image for larger version
Name:	ImageUploadedByAirstream Forums1405051903.998135.jpg
ID:	216092Click image for larger version
Name:	ImageUploadedByAirstream Forums1405051931.588376.jpg
David M is offline   Reply With Quote
Old 07-11-2014, 12:32 PM   #18
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
That switch disables the step retract when the engine is off but the step will still retract when engine is started.
Old 07-13-2014, 04:22 PM   #19
Teamaron's Avatar
Awesome it worked.
But now I have to get beeping to stop
Old 07-13-2014, 04:47 PM   #20
Teamaron's Avatar
Never mind
Pulled the relay
Name:	ImageUploadedByAirstream Forums1405291661.611675.jpg
Old 07-13-2014, 05:28 PM   #21
73shark's Avatar
That was your last line of defense. Hope you don't regret it.
Old 07-13-2014, 05:54 PM   #22
Teamaron's Avatar
Now I'm second guessing it
But I'll leave it unhooked for now
Old 07-13-2014, 06:06 PM   #23
David M's Avatar
FWIW, I left my beeper intact.
Old 07-14-2014, 09:55 AM   #24
1964 19' Globetrotter
Garrison , North Dakota
Instead of pulling the relay, just pull the #11 fuse under the drivers seat. The #11 fuse powers the beeper for the awning and step. #10 powers the step motor.
relehnherr is offline   Reply With Quote
