Old 10-07-2014, 07:36 AM   #29
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
Thanks for the tip with locking the door I will do this.
Meanwhile I found some gray dust arp puny the edge of the frame on the lower storage bin behind the sliding door. This is the reason for mine not to close proper the door would hit the frame and the frame pushed against the sliding door.
Just had it at Jackson Center and they cut the floor back to give it more room.
Yes the size of the door makes not too easy but mine was just unreal.
Everybody trying to adjust without fixing the cause did not help either. Only longtime wear would show the real problem.
Peter
PSchw is offline   Reply With Quote
