Old 06-14-2018, 04:56 PM   #1
2010 22' Interstate
New Bern , North Carolina
Sliding door window
The knob that controls the sliding door window on my 2010 Airstream interstate seems to have disconnected from the mechanism inside. With the window closed, if I lift it an inch or so on the outside then the mechanism connects and it will crank the window open. However, when I crank the window closed in the closed position the knob seems to be, again disconnected.
Any experience, references or comments would be greatly appreciated.
Prairie is offline   Reply With Quote
Old 06-14-2018, 08:55 PM   #2
Air99's Avatar
2014 Interstate Ext. Coach
Camas , Washington
If your window is like my 2014.5 CR Laurence, itís possible that the tiny gearbox (which is attached to the rod with 2 levers that raise and lower the window) is stripped of a few gears, hereís some info and pics of its access and removal. You may have to order a new one before proceeding with replacement.
http://www.airforums.com/forums/f240...ml#post2016628
Air99 is offline   Reply With Quote
Old 06-15-2018, 07:53 AM   #3
2010 22' Interstate
Thanks air99; this looks like the information I need. Nothing is as easy as it looks or should be!
Old 06-15-2018, 09:07 AM   #4
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
The sliding door windows are problematic. They take a beating with slamming the door shut. Mine leaked until I did major investigation to locate leak in the window frame. I stopped opening mine. Interesting that Airstream eliminated this window on late model Interstates and now just order Mercedes fixed glass on the slider.
- - Mike
Old 06-15-2018, 09:41 AM   #5
Air99's Avatar
Camas , Washington
Agreed, and they finish the inside with mouse fur panel and shade to match the rest of interior, much nicer than the odd 2 piece Velcro curtain.
Old 06-15-2018, 01:55 PM   #6
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
MIKE - yes, glad I do not have it on mine. I would have preferred them on rear door windows, as it is much easier to drive with them open while in process of expelling hot interior air. Not sure if folks drive with the sides open. I do not because I am scared it will fly off or shorten it's life expectancy.
Alex AVI is offline   Reply With Quote
Side Sliding and Fixed Window Repair Chaplain Kent General Motorhome Topics 83 12-02-2018 06:20 AM
Sliding screen door for the sliding door! weirdstuff Sprinter and B-van Forum 29 02-28-2014 09:19 PM
Copilot sliding window. Inland RV Center, In Commercial Listings 3 05-02-2005 03:57 PM
Sliding window tracks thenewkid64 Airstream Motorhome Forums 17 08-02-2003 04:52 PM
