Old 11-09-2015, 12:33 PM   #1
2013 Interstate Coach
Raymond , Iowa
Sliding door water leak
I have a water leak on the sliding door that I first thought was around the window. But I am now 110% sure that it is not from the window area. So please do not suggest that fix in any replies. I removed the inner fabric covered panel and did the hose test and find the water coming in around the door handle. I have looked at my handle vs the handle on other Sprinters and cannot find any obvious difference from the outside. (Obviously those owning other Sprinters were not too interested in letting me remove their panel so I could compare handles from the inside. My handle seems to be as tight (or not) on both the front and rear pivot points. No obvious seals or plugs that are missing from mine. Next step is for me to call a Sprinter dealer to see if they have any experience with such problems. But I expect to hear a 'make an appointment' answer, so thought I'd start here where no appointment is necessary.
Titus is offline   Reply With Quote
Water Leak on Sliding Door rwcmick Sprinter and B-van Forum 12 09-24-2016 11:35 PM
Sliding screen door for the sliding door! weirdstuff Sprinter and B-van Forum 29 02-28-2014 08:19 PM
water leak in rear upper cabinet and sliding door russ240 Sprinter and B-van Forum 12 12-13-2013 01:11 AM
Sliding Bath Door Marc Marenco 1974 - 1979 Sovereign 0 07-09-2003 04:33 PM
