Old 07-05-2013, 08:53 AM   #1
Billshop's Avatar
2013 Interstate Coach
Fairport , New York
sliding door stopper.
I am installing a screen on the sliding door opening, and I need to fully open the door to gain access. The stopper keeps the door from fully open, and I recall someone on this forum had removed the stopper to allow access to the sliding step electrical connections. Before I blindly move ahead with this removal, I need to know if there is anything that I should be aware of? Is it simply a matter of removing the torx screws? Anny advice or suggestions would be welcome.. Thanks... Bill
Billshop is offline   Reply With Quote
Old 07-05-2013, 03:16 PM   #2
Teamaron's Avatar
2014 Interstate Ext. Coach
Boca Raton , Florida
Not sure about what your looking to do but I do have a question about stopper.
With the stopper in place does the door stay in a 'locked open' position until you release it via the door handle? The same way it does when fully open without door stopper.
Teamaron is online now   Reply With Quote
Old 07-06-2013, 04:19 AM   #3
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
Yes it is as easy as removing the screws. The door open all the way now. The only problem I see on mine is the cup holder in the door will touch the edge when moved back. This leaves a black mark which I hope will be easy to clean up.
And yes the stopper makes the door lock in the open position.
PSchw is offline   Reply With Quote
Old 07-06-2013, 12:02 PM   #4
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
So they finally put a cup holder on the door. Will have to check that out as the second row needs them.
Old 07-07-2013, 04:41 AM   #5
PSchw's Avatar
Livingston , Texas
Yes not sure when but my 2013 has 1 in the door and on behind the driver seat on the side panel. The cup holder sticks about 1/4" out and moving the door back it hits the edge. I can push the cup holder more then 1/4" in so it should be possible to somehow keep it in so it does not make the edge.
Old 07-07-2013, 10:28 PM   #6
2012 Interstate Coach
norman , Oklahoma
Would love to see a pic of the new cupholders. Definitely something my 2011 needs!
russ240 is offline   Reply With Quote
Old 07-07-2013, 10:41 PM   #7
73shark's Avatar
I don't think we'll be able to add them on as the picture in the brochure shows them to be recessed into the door and into the side panel behind the driver. And they're probably very expensive if other replacement parts are an example.
