Old 05-18-2019, 03:28 PM   #1
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Sink replacement
I never replaced the sink in my 2014 because of difficulty with the microwave mounted close under the sink. It can be done, but it is a lot easier on my current 2018 GT.
The new sink comes FedEx on Tuesday. It was not in stock at my local Lowe's. The faucet I wanted was in stock and I bought that.
I pulled out the old sink today and mounted the new faucet.
The sink comes out easily with four small Philips screws. You can loosen the screws and rotate the plastic locks out of the way. I simply removed the screws and recovered the loose parts under the sink.
I was surprised to find back-flow preventers in both the hot and cold lines. I guess this is required since the spout on the old sink could be under water and siphon back into the lines. The back flow preventers work like tire valves.
The waste goes into a vertical Hepvo waterless trap. I may be able to use the waste assembly as-is, but I'll need the new sink on hand to know.
The end fittings on the PEC are a couple of inches short of reaching the new faucet water inlets. I bought plastic extensions at HD. By loosening the straps on the PEC to get some movement, the extensions just reached. I'm still having fits getting the cold water connection water-tight. I'll re-visit that problem when I am next at the storage yard on Monday.
Name:	Sink loose.jpg
ID:	341050   Click image for larger version
Name:	Sink removed.jpg
Name:	Waste removed.jpg
ID:	341052   Click image for larger version
Name:	Faucet in place.jpg
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 05-18-2019, 05:10 PM   #2
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
The new setup will look so much better.
Now that I know that it can also be done on the Lounge I will be following your steps.
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 05-18-2019, 05:22 PM   #3
2015 Interstate Grand Tour
Lake Oswego , Oregon
John,
Congratulations... you are days away from galley sink nirvana !
When I did that project a year ago, I replaced the Hepvo waterless trap as a precaution against future problems, found here: https://amzn.to/2YzZ1sX
PM me if you want contact info for my local guy who can make a cutting board cover that nests into the new sink opening.
Mark
Name:	Bare sink in place.JPG
ID:	341056   Click image for larger version
Name:	Backsplash in Place.jpg
Name:	Backsplash Detail.jpg
ID:	341058   Click image for larger version
Name:	Cutting Board in Place.jpg
Tronadora is offline   Reply With Quote
Old 05-18-2019, 06:01 PM   #4
Contributing Member
Pahaska's Avatar
Mark
My current Hepvo valve has just 3 months of use, so it should be fine for quite a while.
Thanks for the pointer to getting a top. I do a lot of wood working, so I'll probably make my own. Keeps me off the street!
John W. Irwin
WBCCI #9632
Old 05-18-2019, 06:06 PM   #5
wachuko's Avatar
Orlando , Florida
Mark,
You were the one one that messed me up with what you did, lol. I stopped pursuing the idea of changing it when I thought it could not be done due to clearance issues with the microwave.
A fellow owner in Facebook did it and shared the parts he used to make it fit. The trick was using a shallow sink trap.
I will want a matching board to cover the stove as well.
Safe travels!
Wachuko
WBCCI #26769
Old 05-19-2019, 05:25 AM   #6
wachuko's Avatar
Orlando , Florida
One concern I had... the sink trap to use in the Lounge to make this work, does not have a drain plug. I thought that plug served two purpose and one was to avoid odors coming into the cabin from the gray tank. Or is that solely handled by the waterless membrane trap that these rigs have?
Safe travels!
Wachuko
WBCCI #26769
Old 05-19-2019, 05:51 AM   #7
Contributing Member
Pahaska's Avatar
No trap in mine, either. The waterless Hepva valve acts as the sink trap. Any pressure from below just makes it seal more tightly. Same thing for the shower except that that Hepva trap is installed horizontally under the shower floor.
John W. Irwin
WBCCI #9632
Old 05-19-2019, 09:52 AM   #8
wachuko's Avatar
Orlando , Florida
Perfect. Thank you John.
Safe travels!
Wachuko
WBCCI #26769
Old 05-20-2019, 03:44 PM   #9
Contributing Member
Pahaska's Avatar
Ready for the sink
Stopped by today to get the faucet connections water-tight. I ended up with 2 sets of plastic faucet extenders end to end to get enough length (about 5") to reach the PEX fittings. I discarded the unnecessary backflow preventers and the gray couplings. I'm sure the backflow preventers are there just because the faucet can be submerged in the old sink.
An hour of water pump pressure and all is dry.
I rolled lengths of plumber's putty around the periphery of the sink opening, ready to seal when I drop in the new sink.
I padded the wall area where the weight on the pull-out spout hangs so that it will not bang on the plywood when driving.
Email from FedEx: sink is in Austin and will be delivered tomorrow.
John W. Irwin
WBCCI #9632
Old 05-21-2019, 10:42 AM   #10
Contributing Member
Pahaska's Avatar
Waiting for FedEx
AI is in the driveway, waiting for FedEx delivery that is usually just about noon.
In the mean time, I mounted the magnetic bar that I have been meaning to mount for some time. I mounted the bar on some scrap Lexan so that items hung on the bar would not rub on the mouse fur wall. I padded the screw heads and pop rivet ends on the back so that the mouse fur will not be marred.
I screwed it to the wood strip behind the cabinets, mounted on a nice trimmed piece of laminate that I had salvaged when I eliminated the bed extensions. I cut the laminate down to 1 3/4" wide and all three visible edges are trimmed to match. I had some nice brown screw caps in the shop, so everything is nicely trimmed.
The silverware drawer is quite shallow and it is nice to get items such as bag clips out of that drawer.
Now, for FedEx!
John W. Irwin
WBCCI #9632
Old 05-21-2019, 02:16 PM   #11
Contributing Member
Pahaska's Avatar
Still waiting
The new sink didn't get into Austin until this morning. Apparently, although a trace showed it was out for delivery, it must be on the late truck. That means, it may be just about dark when it arrives.
In the mean time, I have been busy doing a list of smaller items that I have been avoiding. Principal among these is to rip apart the teak floor cover I saved from my Lounge and rebuild it for the GT. I made a cardboard template and it took just about an hour to rip the thing apart, plan the parts arrangement for the GT, and assemble it. I had one piece of teak left over. It fits the GT like a glove.
John W. Irwin
WBCCI #9632
Old 05-21-2019, 07:41 PM   #12
Contributing Member
Pahaska's Avatar
One more step
Sink is installed. Tightening the clamps was a real pain in the whatsit. Hard to get my fingers up there and hard to see what I was doing. I have 4 of the 5 clamps installed. The remaining clamp can not be reached and will not be installed.
I need to redo the drain piping. The drain is lower and a bit further away from the Hepva valve. The plastic strainer that came with the sink is very deep ... over 4" deep. I ordered a 2.7" deep stainless steel strainer to come tomorrow. By using the shallower strainer and pushing the Hepva valve down as low is possible, I can just fit a drain without any fancy tricks.
John W. Irwin
WBCCI #9632
Old 05-21-2019, 08:00 PM   #13
wachuko's Avatar
Orlando , Florida
Teak shower mat gives the bathroom such a relaxed look.
All great mods. Sink looks great.
Safe travels!
Wachuko
WBCCI #26769
Old 05-23-2019, 05:56 AM   #14
What are you doing with your old sink?
Replacing 2014 27FB sink with vessel sink Wishing Sinks, Showers & Toilets 15 08-30-2018 07:05 AM
2014 Sprinter kitchen sink faucet loose from sink base AirHammar Plumbing - Systems & Fixtures 0 11-15-2016 11:11 AM
How do I remove leaky sink drain pipe, bathroom sink, 1970 Sovereign NevaH Plumbing - Systems & Fixtures 4 09-14-2015 04:01 PM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
advice wanted for bathroom sink replacement Shelby Copeland Sinks, Showers & Toilets 8 12-25-2003 07:06 AM
