Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 04-24-2017, 12:57 AM   #1
ScottP's Avatar
2020 27' Globetrotter
2019 Interstate Lounge Ext
Jackson Hole - Tetons , Wyoming
Simple Question s.... free Bourbon...!
Hey -
Is there a cigarette/cigar plug in the aft section of the coach behind the bench seat? I'm becoming an early onset Alzheimer's case here.....and don't have my van nearby to check. Thanks all... : --0
Also
Yah know how the thermostat goes "wacky" when it loses power, and upon re-boot it runs both AC and Heat?
What's the re-set process? Just fix the time on its click iirc covered on the forum?
Heading to Moab tomorrow and these are questions it'll be helpful to clarify.
I really do think I'm losing it!! Please pass me another Manhattan "while I think on it."
Smiles, Scott
ScottP is offline   Reply With Quote
Old 04-24-2017, 04:31 AM   #2
Sag Harbor , New York
Guessing your thermostat manufacturer's instruction booklet has the reset/reboot procedure for the stat, if it is a Dometic and similar to an AS trailer.
Good luck!
Peter
Old 04-24-2017, 07:15 AM   #3
ScottP's Avatar
Also
What's the re-set process? Just fix the time on its clock (iirc)?
Smiles, Scott[/QUOTE]
Old 04-24-2017, 08:47 AM   #4
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
There are no 12VDC power outlets behind the bench seat.
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
Old 04-24-2017, 10:54 AM   #5
1972 25' Tradewind
Calgary , Alberta
That's not important...
I'll PM my address for the free Bourbon, I'd prefer vintage and rare but I'm ok with whatever.
Thanks in advance.
Monza is offline   Reply With Quote
Old 04-24-2017, 11:10 AM   #6
PKI
PKI's Avatar
Walnut Creek , California
If you need a 12volt power source, the fastest way to get it is to use the cigarette lighter port that many of the combination jump start batteries have. The Lithium style just has a USB port and that is not 12 volt. Not sure the info helps, but understand your question. We could not believe a coach that runs lots of stuff on 12 volts would not have an outlet.
Travel safe. Pat
Old 04-24-2017, 08:04 PM   #7
2024 Interstate 19
Fulton , Maryland
Travel safe. Pat
The Interstate/Sprinter has three 12VDC cigarette style outlet in the cab area up from. But OP was asking about outlet in the back, which the Interstates don't have. I added three in the rear area, two on rear side of galley cabinet on road side and one wall near rear TV an curb side. It's very helpful to have the extra 12VDC outlets in the back - something Airstream should provide.
- - Mike
Bourbon Trail KY gwg On The Road... 7 05-09-2018 09:40 AM
Simple question, probably not so simple answer AWCHIEF Generators & Solar Power 10 01-23-2016 03:23 PM
Free-Free-Free -- Twin Bed Setup - 1955 Flying Cloud Tx Air 1950-1955 Flying Cloud 9 03-14-2010 09:07 PM
Free....Free... Free Happycampers Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-14-2005 05:54 PM
