Old 07-13-2015, 12:35 AM   #1
mjwcubed's Avatar
2011 Interstate Coach
Denver/Boulder , Colorado
shower not draining in 2011 AI?
got my 2011 AI about 45 days ago...took it on the maiden voyage to Intl Rally in Farmington. While all things worked as expected....my first shower (navy size I swear) proved to simple gather in the shower pan. I was able to "baby plunge" the water into the grey tank. And, flush the grey tank. But it still will not drain water. Anyone else have had this challenge - and or any insights on what I should do? Trying to avoid my first service trip to Airstream for something that is ...stupid:-)? thanks!
MJ in Colorado!
mjwcubed is offline   Reply With Quote
Old 07-13-2015, 02:01 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I was at Farmington as well, the white Interstate in site 4-151.
First rule of troubleshooting is, check the easy things first. The easy thing in this case is, is the gray tank full? You said you "flushed the gray tank" but it never hurts to check. A full gray tank would account for the symptoms you describe.
The next thing is, the shower drain on an Interstate's wet bath is much smaller than the one in your home, and it's easier to clog. It doesn't take much hair to clog the drain.
Try fishing around in the drain with a dental pick— a handy tool to carry just on general principles— to see if you can dislodge a hairball. But be careful not to drop the pick down the drain! I bought a removable wire mesh strainer that I placed in my shower drain for exactly that purpose; I may not have any hair left on top, but I shed enough beard hair and body hair to cause problems over time.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-13-2015, 06:27 AM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
On our older trailer we carry a clean olf fashioned toilet plunger to help the shower along when it needs it. The plunger just rides in the shower until needed.
Old 07-13-2015, 06:53 AM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Along with a plunger on board I also carry and have used a small snake to unclog drains.
MICHAEL
Old 07-13-2015, 07:23 AM   #5
I'm not sure if a plumber's snake would damage a Hepvo valve, though.
WBCCI #1105
TAC LA-4
Old 07-13-2015, 07:50 AM   #6
AWCHIEF's Avatar
Images: 33
It might, in that case if it don't fit don't force it.😳
MICHAEL
Old 07-13-2015, 08:59 AM   #7
If you do all of those things listed above and still have no resolution, the next logical step is perhaps to verify that all of your lines are correctly plumbed. I don't know how this could be accomplished on a 2011, but on a 2007, it is achieved by scooting under the chassis and having a look-see. If one of your lines got damaged during previous ownership, it may have been inadequately repaired, leading to a problem. Some Interstates (especially the older T1N models, it seems) have experienced breakages in the joints between the ABS pipes and both the grey and the black water tanks. If an improper patch were installed in such a situation, it could impact the drainage.
Old 07-13-2015, 10:28 AM   #8
JPAIRSTREAM's Avatar
1972 31' Sovereign
, Ohio
Images: 47
On a Hepvo Valve using a plunger may actually reverse the flow. I would suggest that by using compressed air blowing into the drain may reverse the rubber valve. This of course is if this is the issue.
IF you are using a plunger every time you pull the plunger off you are potentially pulling the valve the opposite direction causing it not to drain.
JP
JPAIRSTREAM is offline   Reply With Quote
Old 07-22-2015, 10:14 PM   #9
mjwcubed's Avatar
thanks and an update...
thanks to all for this discussion....after seeing my Airstream dealer (my first trip here in Denver) and it was a great experience. After spending some time - they were able to pull out a type of pine cone like "thing" - obviously causing the clog. But, to another's insight on this thread: there was also some of the glue adding the the problem, and that value was cracked.
So, I am grateful for knowing 1) I'm not insane, and 2) we are close to having the problem resolved - waiting on a part (now it leaks - very little, but leaks). Again, all in all - grateful it's not a bigger deal.
MJ in Colorado!
Shower not draining KiraR Sinks, Showers & Toilets 3 07-05-2015 07:42 PM
Asheville Newbie's lav sink not draining--separate valve? meghanhester Sinks, Showers & Toilets 2 08-06-2012 08:55 AM
Black water tank not draining....... mapley3 Waste Systems, Tanks & Totes 4 10-23-2010 09:12 AM
A/C not draining properly JKnight Furnaces, Heaters, Fireplaces & Air Conditioning 1 08-30-2010 03:59 AM
New member- Water Tank Not Draining jvandal Fresh Water Systems 6 11-10-2006 11:17 AM
