Old 07-19-2019, 11:38 AM   #1
2017 Interstate Grand Tour Ext
Houston , Texas
Shower head replacement
We are thinking about replacing the original shower head on our 2017 Interstate GT with this Camco one:
https://amzn.to/2XTdswg
https://images-na.ssl-images-amazon....AC_SL1500_.jpg
Anybody have a better recommendation?
The goal is a shower head that has a gentler spay (original one tends to lime up and get harsh) and has an off/on switch on the head.
Leigh & Bettie
Houston TX
2017 Interstate GT
BMW R1200GS
TayaraTravel is offline   Reply With Quote
Old 07-19-2019, 11:47 AM   #2
2014 25' FB Flying Cloud
Kingwood , Texas
Oxygenics is what I see most people get. We have not changed out yet.
DoubleR is offline   Reply With Quote
Old 07-19-2019, 11:51 AM   #3
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
For $8 for the Camco you can certainly afford to be disappointed.
I changed our shower head to the Oxygenics Body Spa RV eight years ago ($26) and we have been quite satisfied. The design accelerates the water speed giving a sensation closer to an at-home shower without increasing the water consumption rate. It does have an on/off feature which is activated by turning the knurled end of the handle adjacent to the hose connection.
The lime/calcification/debris issue is a function of your water and will affect both the shower heads and sink faucets. You may benefit from using a water filter for both city water connections and tank fills.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 07-19-2019, 01:09 PM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
A filter will do nothing for calcium, lime etc.
Old 07-19-2019, 02:28 PM   #5
2007 22' International CCD
Lime and calcium needs a water softener system at minimum.
Old 07-21-2019, 03:01 PM   #6
Houston , Texas
Thanks for the information
Leigh & Bettie
Houston TX
2017 Interstate GT
BMW R1200GS
Old 07-21-2019, 03:21 PM   #7
BernieMac13's Avatar
2019 25' Globetrotter
Nashville , Tennessee
We went with two items, a really low-flow, high-pressure shower head and a little valve to completely shut off the water. Boy, has it made a difference in both comfort of our showers and how long our FW tank lasts! And we don't have to shorten our showers as much knowing that it's not wasting water as we lather up! our last rig had an Oxygenics, but we found that we preferred to save even more water than that!
Links:
Shower head: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The shut off valve:
Not as cheap as others, but the most effective model we could find at only 1.5 GPM!
'18 RAM 2500 Laramie, Cummins
'19 Globetrotter 25FB
BernieMac13 is offline   Reply With Quote
Old 07-21-2019, 04:54 PM   #8
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Go with the Oxygenics. Lower water usage and higher feeling output.
2019 Ford Expedition Platinum
1956 Shower head replacement question... MichaelC 1956 - 1959 Flying Cloud 1 05-11-2012 04:03 AM
1987 34' Excella shower head replacement? RSRFCMP Sinks, Showers & Toilets 1 08-01-2009 05:42 PM
Shower head problems Pahaska Our Community 25 08-26-2002 10:43 AM
Shower head Pahaska 2002 - 2005 International 0 08-24-2002 04:13 PM
Shower head Pahaska 2002 - 2005 International 0 08-24-2002 04:12 PM
