Old 09-17-2014, 09:11 AM   #15
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Shoreline Tripping A/C Circuit Breakers
Excellent point on the 50 HZ, induction motors will operate at 5/6 speed and this will cause stress.
Old 09-17-2014, 09:40 AM   #16
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Having lived in Europe twice (first time Netherlands for 4 years, second time in Belgium for 3 years), I can attest to the difference that 50 cycle current has on US appliances. Anything with a US electric motor in it will usually cause a problem (60 cycles). The step-down transformers that you can buy (and there are huge differences in transformers as well), do NOTHING to accommodate the difference in cycles...only volts. It could be very funky going from one appliance to another. The washer would work, the dishwasher wouldn't. Then there was the fun of a US dryer which used 220 for the heating element, but 110V for the motor and timer unit.....because our 220 and their 220 are most assuredly different. If you were using one of the inverter generators (e.g., Honda EU type), I'll be your problems would be solved.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 09-17-2014, 09:43 AM   #17
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
It's an Interstate, with a built-in Onan propane-fueled generator. But that sucker is LOUD when you're trying to sleep with it located right under the bed. I'm sure that's one reason why the OP wants to be plugged in to run the A/C. Not to mention the Onan only produces 20 amps, not 30.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-09-2014, 12:23 PM   #18
S3d
2014 Interstate Ext. Coach
Kuwait , Kuwait
Originally Posted by Bikerbill View Post
S3d, I see your listing shows Kuwait. Is that where its plugged in? Has it worked before at that electrical outlet? Also affecting electrical appliances is the cycles per second of the AC current. Do you know if you are receiving 60 cycle/second? Some European countries use 50 cycles and that also has an effect on devices, especially motors, that are built to operate on 60 cycles.
I'd also make sure the electrical connections in the outlet box are tight. Make sure the power to the outlet is turned off before checking it.
Also circuit breakers are known to go bad. Does the breaker that is tripping get very warm? That would indicate an overload causing it to trip.
You're right. Our country uses 50 cycles and found an electrician who fixed that issue. Everything works fine now.
Thanks!
S3d is offline   Reply With Quote
Old 10-09-2014, 04:42 PM   #19
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Thanks for the follow-up. I was sure that 50 Hz power was your problem.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Breakers tripping in Campground only L911 Electrical - Systems, Generators, Batteries & Solar 15 07-06-2013 07:40 AM
Breakers keeps tripping greyzeth Electronics & Connectivity 20 12-13-2011 01:10 PM
Circuit Breakers Tripping bgarver Electrical - Systems, Generators, Batteries & Solar 2 11-16-2007 10:52 PM
Circuit breakers,94 33ft Motor Yacht rayschell Batteries, Univolts, Converters & Inverters 4 07-10-2005 11:35 AM
Electric Heaters Tripping Circuit Breakers streamlean General Motorhome Topics 11 01-20-2004 09:29 PM
