Old 03-22-2014, 11:30 AM   #15
1974 Argosy 20
Kooskia , Idaho
In my post above, saying that a 50 amp outlet only had 25 amps on each side was WRONG. I must have been asleep still.
Sorry. The 50 amp outlet should have two 50 amp legs on it. If you use a 50 to 30 amp adaptor, your coach 30 amp circuit breaker will limit your use to 30 amps.
Moral: don't post first thing in the morning when you are not thinking clearly!
Old 03-22-2014, 08:05 PM   #16
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Shore Power Questions
It is a mind thing, each leg of a 50 amp 240 volt service is 50 amps each if used separately with a neutral, but still, if used together in 240 volt service, the two 50 amp legs add up to 50 Amps....
Old 03-22-2014, 09:14 PM   #17
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
My A/C draws about 12 amps to 18 amps depending on the ambient temp. One summer at 105*, I had to shut down the inverter to keep the A/C running.
12 Volt problem when on shore power pacejamr Electrical - Systems, Generators, Batteries & Solar 4 01-01-2012 06:55 AM
Power Max RTurnConn Batteries, Univolts, Converters & Inverters 1 10-16-2011 07:30 AM
Newbie has power questions Czechitout Electrical - Systems, Generators, Batteries & Solar 2 08-07-2011 04:20 PM
Power Steering Not Working - 310 Motorhome steveturk Classic Motorhomes 27 02-18-2011 05:00 PM
Power cord length-recommendations? SilverHoot Electrical - Systems, Generators, Batteries & Solar 17 01-23-2011 02:39 PM
