Shore power problem?
My charging system is giving me trouble. Running off the generator everything is 100%, but when I plug into shore power I have an intermittent problem. Sometimes I plug in and everything works, other times I plug in and either nothing happens at all (like I'm not plugged in) or the Intellitec EMS panel starts to do it's normal start up drill for just a moment and then goes blank. Once it goes dark, plugging and unplugging does no good, though sometimes if I leave it plugged in and come back later I will find it has started charging, other times not. Anytime its not working on shore power, I can fire up the generator and everything works normally.
Also, sometimes when it is charging normally on shore power, when I turn on the air conditioning it comes on as it should, the amp reading notches up to 15-18, the unit starts cooling and after anywhere from a few seconds to several minutes later the EMS unit goes dark and I lose all power. Even when that happens, I can still fire up the generator and everything works normally even while running the A/C.
Does this sound like a problem with the Intellitec EMS, the Tripplight inverter/charger or a problem with my shore power conneciton?
Notes: I'm plugging in only to the 30 amp RV plug at my house through my Surge Guard surge protector. My electrician has checked my shore power plug, I am having no other problems with the 600 amp service I have at the house and the Surge Guard has reported no issues. I'm using the same RV cord that I got when I bought the unit three years ago and it has no signs of overheated plugs/scorching.
Thanks for any tips on tracking this down!
PS Lewster if you are reading this I'd love it if you could stop by OK on the way back to FL this fall and do a full Magnum charger/battery monitor/solar upgrade on your way home!
