Old 01-14-2015, 09:13 PM   #1
Glamper1's Avatar
Shore power
Hi
Whats a fast way of being assured that the shore power is reaching my systems?
Came home and noticed a "low battery fault" message or something like that on the rear lounge area panel.
Its plugged into shore power so I thought that was odd.
I have the tank warmer on
Should I keep the house connect switch near the side door on?
The less I use the rig
The faster I seem to forget the drill
Glamper1 is offline   Reply With Quote
Old 01-14-2015, 09:36 PM   #2
Glamper1's Avatar
I may have hooked up the shore power WHILE the house battery was on
Not sure if that was a good move
Old 01-14-2015, 09:56 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Just hooking up shore power is no guarantee that your batteries are charging.
You also have to make sure the inverter/charger is turned on and in "charge" mode.
Truthfully, this is a new one for me, so I'm just speculating here… I know that the inverter/charger should be able to charge the house batteries regardless of the position of the 12vDC disconnect switch.
However, in order for the inverter/charger to invert, the 120vAC circuit breakers have to be turned on. Presumably in order for the inverter/charger to charge, the 120vAC circuit breakers also have to be turned on to make sure the inverter is getting power. Lewster would know that answer better than I would.
Oh, and you need to make sure the breakers at the service pedestal are turned on and not tripped. It is possible to forget to turn them on after plugging in. Also, if the service pedestal breakers were already turned on when you plugged in, they may have tripped and need to be reset.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-14-2015, 10:03 PM   #4
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
What are you plugged into? If it's a standard household socket at home (since you say you're at home) then wake up the the Precision Circuits display by hitting the button, and all the lights should come on: should be 30A or 20A, plus the 4 system lights on the right. 20A should be set if it's a household socket.
If all lights are on, then apart from Protag's suggestions, I wonder if you have a charging problem
Old 01-14-2015, 10:14 PM   #5
Glamper1's Avatar
All lights at circuit display are off
Ill put the house battery connection switch and inverter on and see what happens
Yes its hooked to regular house outlet thanks
Old 01-14-2015, 10:45 PM   #6
Glamper1's Avatar
My unit must have issues
Ill take Harvey in soon
Old 01-15-2015, 09:05 AM   #7
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
The inverter does not need to be on. When you are plugged in do you have other indications like the microwave display or the TVs on? Make sure you have power inside your Interstate.
- - Mike
Old 01-15-2015, 09:50 AM   #8
UKDUDE's Avatar
Sedona , Arizona
An obvious question: have you verified there's power at the socket? It may have tripped a breaker in the house.
Old 01-15-2015, 10:58 AM   #9
I beg to differ. The inverter/charger needs to be on in order to charge the house batteries from shore power. It will be in "charge" mode, not "invert" mode, but it must be on.
WBCCI #1105
TAC LA-4
Old 01-15-2015, 11:07 AM   #10
Gainesville , Florida
Check house breaker. 120 volts? I hope. Jim
Old 01-15-2015, 11:13 AM   #11
Glamper1's Avatar
Thanks Jim ill check
Old 01-15-2015, 11:20 AM   #12
Fulton , Maryland
Shore power
Not if it is a Magnum inverter/charger, which I assume they have since it is a new Interstate. For the Magnum you just have to be plugged in to get battery charging.
- - Mike
Old 01-15-2015, 12:58 PM   #13
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Battery disconnect switch may have to be on, when traveling I turn it on and leave it on. Batteries will not charge if plugged into shore power if the battery disconnect switch is in the OFF position. The batteries will charge if the switch is off and one is using AS Factory installed solar panels. As advised I'd check house breakers and just for kicks AS breakers as well.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
paiceman is online now   Reply With Quote
Old 01-15-2015, 01:03 PM   #14
Mjgman's Avatar
Bradenton , Florida
My inverter does not need to be on to charge the batteries when plugged into shore power..
Mjgman is offline   Reply With Quote
HELP?! On Shore Power, but lights dim, and power fades TGadaire Batteries, Univolts, Converters & Inverters 4 11-24-2012 05:18 PM
Shore power but no battery power RogerLG Lights - Interior & Exterior 6 09-28-2012 01:53 PM
shore power/battery power wiring NavyDavesCvl Electrical - Systems, Generators, Batteries & Solar 0 10-13-2010 06:32 PM
Power surging from shore power in my Excella 500? NVDeputy Lights - Interior & Exterior 4 10-09-2009 11:52 AM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
