02-22-2017, 10:17 AM
2014 Interstate Ext. Coach
Houston
Shore line charging
When I plugged in shore line the house battery is not charging?
My master switch is on but all circuit breakers were in off position, could that cause the battery not charging ?
House battery can be charged by alternator and/or generator
Your help
02-22-2017, 11:40 AM
Port Angeles
On my older model, there is a battery disconnect.
'Store' and 'use' I think.
In Store, it will not be charged by shore power.
Does yours have such a switch?
(Be aware that at least on my older model, the battery charger is a simple 'one stage' charger and should not be left on for extended periods of time. Once charged, the battery is put into 'store'. Yours may be totally different)
02-22-2017, 12:17 PM
Houston
I guess is that I need put it on "on" or "use" in order to get charged, and more, airstream tech told me that my circuit breakers must be stay on as well, for a long term storage, I'm better off disconnecting the negative side
02-22-2017, 12:29 PM
Tampa
One reason to disconnect is that by law, some things cannot be turned off. The propane leak detector, and carbon monoxide detector for example.
So while stored, the batteries get discharged.
02-22-2017, 07:14 PM
2024 Interstate 19
Fulton
, Maryland
Shore line charging
Your help
I see you have a 2014 Interstate. On late models if you have all the 120VAC circuit breakers off then the Magnum charger will not charge the batteries
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
02-22-2017, 08:20 PM
2012 25' Flying Cloud
Battle Lake
We put a toggle switch on the propane detector lead (check list item), and the CO detector has its own battery. Our Battery Disconnect Switch shuts down battery power to our Airstream. However our factory solar system still keeps the batteries charged if they ever need it over a long period.
Doug and Cheryl
02-23-2017, 06:29 PM
Houston
Thank you all, after all night, the battery is at 100%, my master switch is on, all 120v circuits breaker is in a. "On" position, Door side house switch is off, now, can I plug the shore power while put the rig in storage for a month ? Is there a down side ? What has been your experience ?
02-23-2017, 06:41 PM
Normal
We were instructed to set to "store" and disconnect when the rig is not in use.
I don't know that there is any benefit to staying plugged in while your unit is in storage.
Maggie
02-23-2017, 07:16 PM
2017 Interstate Lounge Ext
Jacksonville
, Jacksonville, Fla, Sautee, Ga, Boca Grande, Fl, Breckenridge, Co
There have been many discussions on this subject you can find using the search function. I notice you have a 2014, so you should have the Magnum inverter. I have the same, and I always store it plugged in to keep the house batteries from going dead from all the battery draining items in the AI electrical system. My unit will charge the batteries with the door side disconnect switch on or off. My prior AI had the old inverter/charger which could not be left plugged in for storage which made it a challenge to keep the batteries charged.
02-25-2017, 08:03 PM
Houston
Thank you for the info, I will plug in for long term storage
03-05-2017, 08:00 PM
2015 Interstate Ext. Coach
Columbus
, Ohio
I soon will have a concrete pad finished at our residence and will store our AI there when completed.
Question, I do not currently have 30 amp service available to plug into. Is it alright to just use the 20 amp service I have to keep the batteries charged while parking it or do I need to have 30 amp installed?
03-05-2017, 08:14 PM
Contributing Member
Austin (Hays County)
For battery charging, a common 15 amp household outlet should be more than sufficient.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
03-05-2017, 08:27 PM
Tampa
Illegal.
I sympathize. I may do the same, but it's not legal.
03-05-2017, 08:34 PM
League City
Illegal.
Put a DPST switch on the propane solenoid and the detector.
03-05-2017, 08:40 PM
2002 30' Classic S/O
Fleming Island
I moved the wire powering the propane detector to the other side of the STORE/USE switch. The switch will be in USE mode whenever the trailer is occupied. Should eliminate the risk of forgetting to turn on the power to the detector.
Al
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Batteries not charging via shore power???
crazylev |
Electrical - Systems, Generators, Batteries & Solar |
32 |
09-07-2023 03:01 PM |
Bambi battery not charging from shore line
nbranco |
Batteries, Univolts, Converters & Inverters |
13 |
07-23-2013 05:05 AM |
Battery charging when connected to shore power.
Wingeezer |
3 |
07-15-2011 10:12 AM |
Charging battery on shore power.
Dr Dan |
8 |
08-26-2010 02:07 PM |
Charging Battery While Plugged in to Shore Power
Kevin245 |
2 |
12-29-2007 01:10 PM |
