Old 05-20-2015, 12:16 PM   #1
2013 Interstate Coach
Flemington , New Jersey
Shift Knob DIY
Never did care for the shift knob on my 2013. Changing it for the 2014.4 knob has been on my mind for about a year. So while I was at my Sprinter dealer for Service B last week I decided to chat with the parts department.
First, they need to check your VIN. If you don't have one handy get one from a Sprinter on the lot. That way they can search to see if it actually fits.
Knowing car manufacturers they will keep mechanical changes to a minimum just changing easily changed aspects such as hoods, fenders, lights, grilled, shift knobs, etc. for their "face lift" or "low cost initiative" Same product different look.
Here goes.
2014.5 low cost initiative shift knob part no. in case you don't have your vin handy.
Name:	ImageUploadedByAirstream Forums1432145267.272328.jpg
This step may be optional. I removed the faux wood trim to make sure I can easily remove the shift lever boot.
Name:	ImageUploadedByAirstream Forums1432145353.391740.jpg
Pull the boot up and over the knob. Use an adjustable wrench to turn the plastic collar at the bottom of the shift knob counterclockwise. Perhaps one to one and half turn.
Name:	ImageUploadedByAirstream Forums1432145462.073535.jpg
Pull up on the knob. Leaving just the lever.
Name:	ImageUploadedByAirstream Forums1432145500.240949.jpg
Slide the new knob / boot assembly over the lever, turn the lock at the base of the knob clockwise one to one and a half turns and pull the boot down and snap the boot frame back into the console.
Name:	ImageUploadedByAirstream Forums1432145680.211852.jpg
Reattach self adhesive faux wood trim.
Takes less than 5 minutes and costs about $55.
Mario
2013 Interstate
2014 Little Guy 5x10 Silver Shadow
Tiato is offline   Reply With Quote
Old 05-20-2015, 02:51 PM   #2
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Good job. Definitely looks better.
Ron_CA is offline   Reply With Quote
Old 05-20-2015, 05:54 PM   #3
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
I agree. It does look better.
Now if MB would change the HVAC controls to something that made sense. I had to make a cheat sheet to decrypt the symbols for changing the airflow.
Does the Equalizer shift weight to trailer axles? Gene Hitches, Couplers & Balls 13 10-19-2007 02:31 AM
Tranny Shift smily Mechanics Corner - Engines, Transmission & More... 5 01-27-2004 08:03 AM
Sticking Shift Lever '96 Land Yacht John and Anne Mechanics Corner - Engines, Transmission & More... 1 11-02-2003 08:10 AM
Ebay: A fad or a paradigm shift? ipso_facto Our Community 31 05-12-2003 12:28 PM
