Old 03-15-2014, 08:32 PM   #1
toskeysam's Avatar
2013 Interstate Coach
Townsend , Tennessee
Shakedown Cruise
We just returned from our "shakedown" cruise with our 2013 AI Ext. 2200 miles to Austin Tx and back to east Tn. I am truly impressed with the handling of the Mercedes Sprinter chassis. It handled 14+mph crosswinds and truck turbulence with minimal effort. It did require attention, but not worriesome.
We did uncover a couple of "bugs" for the service guys at the AI dealer, but nothing that left us on the side of the road. Has a nuisance problem with the CO detector...no CO just kept going off. Yes, I changed the battery and all the stuff in the manual, but no luck. I wound up unplugging it for the last 50 miles of the trip. It would go off while sitting in the driveway, with nothing running. I did manage to get it to reset ONCE, but no more. I was about 50 miles from home, driving up I-75, when my serenity was disturbed by that "sound" again. ARGHHH
One of the pleated window shades also fell into my hands this morning. I gotta figure this one out....this is the second time it happened. Either I am doing something wrong, or it is a delicate piece....
All-in-all...it was a great trip and we both love driving the "B".
toskeysam is offline   Reply With Quote
Old 03-16-2014, 08:46 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
They're not that delicate. If they were, my ham-fisted opening and closing of them would have broken something by now in mine. You can adjust the tension on the blinds by loosening or tightening the vertical strings.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-16-2014, 09:54 AM   #3
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
I had to tighten the cords on several of mine so they would hold their position better.
Old 03-16-2014, 10:41 AM   #4
Trying to Retire
MILATV's Avatar
Decatur , Illinois
+1 here too
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Old 03-16-2014, 11:35 AM   #5
Boxster1971's Avatar
Fulton , Maryland
I think they are too delicate. Two of mine have broken cords after only 10 months of use. But they are fairly easy to repair. I've been installing one size thicker cord when I do the repairs.
- - Mike
- - Mike
Old 03-16-2014, 11:54 AM   #6
toskeysam's Avatar
Before I start to take anything apart.....anyone have a tip on how to work on the window shades. My problem shade it on the back door....and it appears I do have to tighten one of the side shades as well.
THought I would ask before diving in and possibly breaking something.
Old 03-16-2014, 02:50 PM   #7
toskeysam's Avatar
Ok....I found the clips, removed the shade. The cord is broken......#@%$
Will see what I can do about replacing the cord, and figuring out the adjustment.
When we went to pick the van, the other rear door had a broken shade. They repaired it before we drove away. They would do this one too, but it is about time I figured this stuff out. If it broke in the middle of Arizona I would have to do it. Kinda heading that way with most repair thoughts (within reason).
Old 03-16-2014, 03:20 PM   #8
73shark's Avatar
For what it's worth, the rear shades have the adjustment spool at the top of the shade. At least that's the way it's done on mine. Not sure why they installed the rear shades upside down with respect to the side shades.
Old 03-16-2014, 03:33 PM   #9
Fulton , Maryland
Mine are the same and I've wondered why? Maybe because they are on back windows and when they break the shades are retracted for visibility out the rear windows. But the AIs have a rear view camera so it is a mute point.
- - Mike
Old 03-16-2014, 04:07 PM   #10
Even without rearview cameras, visibility out through the rear windows is not essential. Delivery vans have no rear windows to begin with, but delivery drivers handle them just fine by using the side mirrors.
I'm at a loss to explain why those blinds are upside down as well.
WBCCI #1105
TAC LA-4
Old 03-16-2014, 04:31 PM   #11
Ralph & Shin
Rsknutson's Avatar
2014 Interstate Ext. Coach
Frederick , Maryland
We had the same problem with our CO alarm in our 2014 EXT the thing would go off randomly even sitting in the driveway static after a week. The alarm manufacturer acknowledged it was defective; Airstream to cover under warranty. I see we're not the only ones with a shady problem, but what a pain they can be to adjust.
_____________
Ralph & Shin
WBCCI #6954
Rsknutson is offline   Reply With Quote
Old 03-16-2014, 08:02 PM   #12
Fulton , Maryland
... Has a nuisance problem with the CO detector...no CO just kept going off. Yes, I changed the battery and all the stuff in the manual, but no luck. I wound up unplugging it for the last 50 miles of the trip. It would go off while sitting in the driveway, with nothing running. I did manage to get it to reset ONCE, but no more. I was about 50 miles from home, driving up I-75, when my serenity was disturbed by that "sound" again. ARGHHH ...
I also had to get a new CO alarm after 14 months. Manufacturer only covers failure within one year. But Airstream covered it under their warranty.
- - Mike
Old 03-17-2014, 03:27 PM   #13
toskeysam's Avatar
Well...I replaced the cord with a slightly heavier weight. Not sure how long it will last. The hole in the center-bar has no grommet and the cord drags across th edge of the hole when you raise or lower the shade. It is where the old cord was "broken" or cut. At least the next time I replace it, I will know what to do. Also learning how age has crept up hands that used to be rock-steady.....$&%# In the meantime, I will look for a tiny grommet for those 2 holes.
Old 03-17-2014, 05:56 PM   #14
Newbie
joemikeb's Avatar
Fort Worth , Texas
My CO alarm failed and was replaced within a week after taking delivery of our 2013 AI. Its replacement failed last week 11½ months later. FWIW that alarm is loud, the AI was parked outside in the driveway and it woke me out of a sound sleep on the other side of my house!
The dealer's parts department reported CO alarm life spans ranging from less than a month (like my first) to 3 or 4 years with the average being closer to 1½ years. FWIW my cost from the Airstream dealer was less than half the cost of buying it direct from the alarm manufacturer.
Make errors — otherwise the Great Spirit realizes
you have finished your purpose on earth.
— Navajo saying
joemikeb is offline   Reply With Quote
Shakedown Cruise - 1100 Miles in a 1988 290 LE MarshallSF Classic Motorhomes 2 03-07-2014 12:26 AM
Super Cruise 2014 ranchmink Other Rallies & Events 0 01-27-2014 07:14 PM
ESP& Cruise Loss in high wind MILATV Sprinter and B-van Forum 7 01-25-2014 10:16 PM
Argosy shakedown cruise to Tyler State Park DKB_SATX Our Community 18 06-27-2011 09:06 AM
