Old 11-14-2019, 04:01 PM   #1
Lady Lake , Florida
Sewer Hose Reel
On our 2016 Grand Tour, the electric hose reel will not run. The fuse is good. When the retract switch is activated a low humming sound can be heard, but the reel does not turn.
I read four different threads on the forum. None had the same situation I described above. I wondering if anyone else had a similar situation and what was done to resolve it.
M and R is offline   Reply With Quote
Old 11-15-2019, 08:22 PM   #2
swilly43's Avatar
escondido , California
Try pulling some of the hose back out. It is possible that the hose is "bound up" due to too much overlap in one area. The humming sound indicates the motor is getting power. If the gears are stripped you should be able to push it back in regardless.
swilly43 is offline   Reply With Quote
Old 11-16-2019, 06:55 AM   #3
Lady Lake , Florida
Thanks, I pulled 100% of the hose out. It made no difference. The Airstream service manual has the part number for the hose reel, but does not have a picture. I will call Jackson Center and ask questions.
Old 11-20-2019, 09:57 AM   #4
Lady Lake , Florida
An update:
Airstream does not have a diagram of the hose reel in any parts manual.
The hose reel is manufactured by Technology Research Corporation which was purchased by Southwire. Steve is their tech support for hose reels. His contact info:
Steve Guarcello
Technical Support
Southwire Company, LLC
Phone 727-812-0578
Email stephen.guarcello@southwire.com
Website: https://rvpower.southwire.com
Steve said if you can hear the motor running but the reel does not turn, it is likely the cotter pins which secure the clutch mechanism have fallen out. Replace them using permanent lock tight.
Southwire has a rebuild kit which replaces the clutch eliminating the cotter pins and replacing the solenoid. Steve said cost was around $100.
ID:	356570Click image for larger version
ID:	356569Click image for larger version
ID:	356568Click image for larger version
Old 11-20-2019, 09:58 AM   #5
Lady Lake , Florida
The pages loaded in reverse order. Start at the bottom of the post for page 1.
Old 11-20-2019, 01:03 PM   #6
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
MandR - Thanks for the info. Appreciate the effort to post the four pages of the retro kit instructions. Could you also post the original PDF file since some of the images you posted have menu from your phone covering part of the instructions.
- - Mike
Boxster1971 is online now   Reply With Quote
Old 11-20-2019, 03:43 PM   #7
Lady Lake , Florida
ID:	356592Click image for larger version
ID:	356591Click image for larger version
ID:	356590Click image for larger version
I could not attach the PDF. Sorry.
Old 11-20-2019, 03:57 PM   #8
Fulton , Maryland
Thanks - yes, you can't attach pdf's from a phone.
- - Mike
Old 11-20-2019, 10:11 PM   #9
swilly43's Avatar
Thanks for the research and posting. It is what makes the forum great
Old 11-21-2019, 06:26 AM   #10
Lady Lake , Florida
Agreed!!! I have used many tips and techniques from this forum. Glad to help others.
Old 11-22-2019, 11:37 AM   #11
2017 Interstate Grand Tour Ext
East Hampton , Connecticut
I have a 2017 AI and the exact thing happened to me. I also called the real company. I had Airstream in Billings MT replace the 6 pins that had dislodged. It worked great for two weeks. And then it broke again. Our next step will be the kit you described. Interesting that we were actually able to coil the entire hose manually into that small external space and we are using it as is. Thank you for posting the details in the repair kit.
Jererae is offline   Reply With Quote
Old 11-22-2019, 11:45 AM   #12
Lady Lake , Florida
Originally Posted by Jererae View Post
I had Airstream in Billings MT replace the 6 pins that had dislodged. It worked great for two weeks. And then it broke again. t.
The tech advisor at Southwire said that when replacing the pins to make sure you use permanent lock tight or the pins will likely come out again.
Old 11-22-2019, 05:41 PM   #13
Mine were repaired with lock tight. After 2 weeks they dislodged again.
Old 11-23-2019, 07:17 AM   #14
Lady Lake , Florida
Ugh!!! I will tackle the project next week.
Old 11-25-2019, 06:52 AM   #15
Raymond , Iowa
Anybody know what model year of Interstates the four page Shoreline manual applies to?
Titus is offline   Reply With Quote
Old 11-25-2019, 06:47 PM   #16
Lady Lake , Florida
We have a 2016 Grand Tour. I tried taking the motor cover off while still mounted on the Interstate. I could not reach the top bolts securing the cover. I now have the hose reel apart on my work bench.
My hose reel operating mechanism is as pictured on page 1 of 4. In the bottom of the cover I found four of the six pins. One was still in the reel coupler, but had retracted and would no longer engage the large sprocket. The sixth pin was jammed behind the motor.
The reel coupler is made of plastic. Two of the six pin holes were damaged when the pins came out of the holes as the reel turned. After disassembly and inspection I decided the coupler damage rendered the part unusable.
I ordered the retrofit kit from Marysville Marine, 800.621.1271, cost $86.85 includes tax and UPS ground shipping.
Old 11-30-2019, 07:35 AM   #17
Lady Lake , Florida
Update:
In the retrofit kit, the reel coupler is made of cast aluminum. The pins which engage the reel are molded as an integral part of the coupler itself. The kit was easy to install. Reel works well.
Valterra 10-Foot Sewer Solution Kit, Macerator Universal Sewer Hose Rpatrick16 On The Road... 16 04-09-2019 12:11 PM
Fresh Water Hose and Sewer Hose Length Dilemma bigcountry Fresh Water Systems 40 04-08-2019 01:23 PM
Wired sewer hose reel problem Boxster1971 Sprinter and B-van Forum 1 09-07-2018 07:58 PM
A hose is a hose is a hose Vitaver Plumbing - Systems & Fixtures 37 02-06-2018 02:53 PM
