Old 09-15-2015, 10:40 AM   #15
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
robinair - you can add a gravity dump option. Someone on this group has done it. I'll see if I can find the post for you later.
Also you might want to check our another forum that is focused on B-van RVs. Here is link:
http://www.classbforum.com/forums/
There is some discussion there about GVWs closing.
http://www.classbforum.com/forums/f5...ered-3624.html
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 09-15-2015, 12:05 PM   #16
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Originally Posted by robair View Post
Our Generator quit working on the trip back, we only use it when we stop t o eat for an hour or so when it is hot we have a cat. it has less then 200 hours on it, but to work on this all sprinter are the same.
Robair
Have you checked / changed the oil on your generator lately. If the oil level gets too low it will not run.
Ron_CA is offline   Reply With Quote
Old 09-15-2015, 12:51 PM   #17
2011 Interstate Coach
Muskogee , Oklahoma
Here's the link. It's not that hard to do. Took a couple of hours, and two parts.
http://www.airforums.com/forums/f240...-92862-39.html
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 09-15-2015, 03:35 PM   #18
Fulton , Maryland
Sewer hose problem
The link above kept taking me to the POR-15 discussion. Try this one for gmiller's Gravity dump mod.
http://www.airforums.com/forums/1640693-post.html
- - Mike
- - Mike
Old 09-15-2015, 03:45 PM   #19
Muskogee , Oklahoma
Thanks. Guess I cut the wrong link.
Old 09-16-2015, 10:46 AM   #20
kfrere's Avatar
2008 31' Classic
Lenoir City , Tennessee
Interesting update. I called AS customer service to discuss my kinking hose problem, and their solution. The gentleman with whom I spoke told me that they didn't even know this was a problem. That surprised me given how many people have responded to my initial inquiry with the same problem. He told me that he will look into it and get back to me.
I don't have the expertise to cut off a section of the hose. I mean, I can certainly cut it off - I just don't know how to reattach the nozzle. And, if I cut a section every time this happens don't I eventually run out of hose?
I'll update you guys if I get a response. Thanks for all of the suggestions!
Kelly & Matt
WBCCI - #4335
2005 Diesel Excursion
2008 31' Custom Classic "Moonshine"
2016 Interstate "BugOut"
kfrere is offline   Reply With Quote
Old 09-16-2015, 12:32 PM   #21
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
It's not a problem once you see how to reel the hose in without a kink.
Here's a picture of how I do it. It also shows the clip I've used to reattach the hose to the nozzle. Very simple and no more leaks!
Name:	ImageUploadedByAirstream Forums1442428358.429797.jpg
Old 09-16-2015, 01:40 PM   #22
Fulton , Maryland
I do something similar to the photo provided by UKDUDE, except I make an even bigger loop to the right of the compartment. There is a lot of space at top of the hose reel compartment to accept a large loop of hose to avoid kinking it.
- - Mike
- - Mike
Old 09-17-2015, 03:59 AM   #23
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
It's also easier to store the nozzle if you remove the PVC sewer cap first. The tip of the nozzle unscrews to allow removal of the cap.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-17-2015, 08:22 AM   #24
73shark's Avatar
Overland Park , Kansas
Are you referring to the 3 inch threaded part on the end shown in the picture above?
Old 09-17-2015, 10:28 AM   #25
Yes.
WBCCI #1105
TAC LA-4
Old 09-17-2015, 12:29 PM   #26
Muskogee , Oklahoma
It is not hard to put a 90 elbow on the hose.
1. Cut off existing valve assembly with a razor knife.
2. Unscrew the existing straight 1/2" threaded adapter off the valve.
3. Buy a 90 degree PVC unthreaded on both ends adapter, and a 1/2"unthreaded on one end and threaded on the other from Lowe's or some other source, and some "All purpose PVC Cement" at the same time.
4. Glue the elbow into the threaded adapter. Then screw on the valve. Then, glue on the other adapter by pushing on the hose and let it set 24 hours.
5. Enjoy the new, leak proof hose.
A picture is easier to understand. See attached.
Old 09-17-2015, 06:01 PM   #27
73shark's Avatar
Yes.
On mine, the assembly is all glued together except where it screws into the valve. Maybe that was what you meant. I didn't realize that it wasn't glued there until I just tried to unscrew it. Learn something new every day.
So the cement works w/ the hose mat'l. Second thing I learned today.
Sewer solution to home sewer-so difficult? lsbrodsky Plumbing - Systems & Fixtures 39 05-05-2018 09:35 PM
Sewer Hose Adapter Size Problem crabbey1 Waste Systems, Tanks & Totes 9 05-04-2015 11:53 AM
Sewer Hose Problem Roadtech Waste Systems, Tanks & Totes 20 05-19-2014 08:43 PM
Attention New to Airstream owners - sewer line outlet info - Thetford sewer systems Catman6 Waste Systems, Tanks & Totes 29 04-01-2011 05:22 PM
Staining Sewer vent from sewer gas TheProfessor Cleaning, Stripping & Polishing 6 02-16-2008 01:42 PM
