Old 02-16-2015, 02:29 PM   #1
2018 30' Classic
Rock Hall , Maryland
Sewer hose
Has anyone replaced this hose and if so, any tips?
GloryBound is offline   Reply With Quote
Old 02-16-2015, 02:30 PM   #2
Mjgman's Avatar
2013 Interstate Coach
Bradenton , Florida
Are you still under warranty? If so I would have the dealer do it..
Mjgman is offline   Reply With Quote
Old 02-16-2015, 03:16 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
The hose just screws off at the hose reel, and the end fitting also screws off, just like a garden hose. You can buy an OEM replacement here: RV Macerator Pump & RV Waste Disposal Accessories
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-16-2015, 04:01 PM   #4
2018 30' Classic
Thank you. I couldn't see the connection.
Old 02-16-2015, 04:33 PM   #5
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
I would be interested in hearing from anyone who has used this product and if they are happy with it. I am thinking about ordering it but not sure the bayonet clamps have sufficient clearance to seat the fitting.
Thank you,
Steamy1 is offline   Reply With Quote
Old 02-16-2015, 05:07 PM   #6
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Works in conjunction w/ a macerator pump which is standard on the AIs. I like it.
Old 04-11-2015, 08:47 PM   #7
lamato's Avatar
Sacramento , California
Our hose has a slight leak due to getting bent. The leak is just below that silver clamp on the handle. I see where to get the new hose, but installation looks tricky. There are two white roller bars in the way and I can't get my hand in there to disconnect the hose. Any suggestions/help?
lamato is offline   Reply With Quote
Old 04-11-2015, 10:46 PM   #8
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Sewer hose
Why replace the whole hose? You just need to cut off the hose at the split, remove the remaining hose and original clamp from the nozzle assembly, and reattach it to the hose using a new hose clamp.
Old 04-15-2015, 01:24 PM   #9
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
I had to cut my hose twice because of a real small pin hole. Looks like the hose in general is about 2 feet to long and jams up easy . After loosing about 2 feet with my 2 cuts now it works OK and no more leaks either.
PSchw is offline   Reply With Quote
Old 04-15-2015, 11:50 PM   #10
lamato's Avatar
Thanks everyone for all the advise. We ended up cutting off the hose about 3 inches. Repositioned the handle on the hose and used a clamp from Home Depot. Just curious, Protaganist....how do you get the other end of the hose out? There are two rollers there that are blocking my hand from detaching the hose.
Old 04-16-2015, 01:21 AM   #11
From underneath, after driving the van up onto leveling blocks to give the van a bit of extra ground clearance.
WBCCI #1105
TAC LA-4
Old 04-16-2015, 07:27 PM   #12
lamato's Avatar
Thanks, Protagonist...good to know!
Old 04-16-2015, 11:21 PM   #13
peetoe's Avatar
2012 25' FB Eddie Bauer
SLC , Utah
I just got the Drain master hose system. Only used it once but couldn't be happier.
peetoe is offline   Reply With Quote
Attention New to Airstream owners - sewer line outlet info - Thetford sewer systems Catman6 Waste Systems, Tanks & Totes 29 04-01-2011 06:22 PM
Staining Sewer vent from sewer gas TheProfessor Cleaning, Stripping & Polishing 6 02-16-2008 02:42 PM
Sewer Hose Questions (peww) overlander76 Waste Systems, Tanks & Totes 28 06-09-2007 11:01 PM
Sewer Hose Connector Diana Langley Waste Systems, Tanks & Totes 25 08-12-2006 09:12 PM
Hose for gray water to sewer hookup?? eikel1we Waste Systems, Tanks & Totes 12 03-11-2003 02:49 PM
