08-04-2018, 06:21 PM
2017 Interstate Grand Tour Ext
Houston
Sewer adapter size for Interstate
I don't mean to double dip, since I've already posted this question in another forum,
http://www.airforums.com/forums/f444...es-185237.html
but my question may be peculiar to the Interstate so I'm posting it here also. I'm looking for an adapter for the Interstate macerator system that allows it to screw in to a smaller sewer port (3.5 inches?). My system came only with a small adapter (home takeout size) and a 4 inch adapter that fits most park drains, but some parks seem to have a slightly smaller sewer pipe. Am I missing something?
Leigh & Bettie
Houston TX
2017 Interstate GT
08-04-2018, 06:46 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Yes, you're missing something— a tapered black rubber donut that fits over the 3" fitting to allow you to insert it into any sewer hookup that's in between 3" and 4" diameter.
08-04-2018, 06:48 PM
2024 Interstate 19
Fulton
, Maryland
My 2013 came with three adapters. One 4" pipe cap another that I think is 3" pipe cap and a black rubber doughnut with tapered sides to mate with non threaded dump pipes. The 4" and 3" adapters are nothing special. They are just standard white PVC threaded caps that you can get at any Lowes or Home Depot. Then drill a hole in center (about 1.5") to accept the macerator end fitting. If you don't have a drill big enough just mark the required size and drill small holes around perimeter of marked hole size and smooth edges with a half-round file.
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
08-04-2018, 07:19 PM
Prof. of Pending Projects
2018 Tommy Bahama Interstate
Orlando
What he ^ said
08-05-2018, 06:42 AM
Houston
Thanks for preceding several responses. I have the rubber doughnut but am looking for a threaded adapter that goes into the 3.5" pipe shown in the the photo. I would rather not trust the doughnut if there is a threaded alternative.
But maybe I'm just not using the doughnut correctly. What's the technique? Wedge the small end into the pipe? Then wedge the 3" macerator adapter into the big end? Is that stable enough?
Leigh & Bettie
Houston TX
2017 Interstate GT
08-05-2018, 06:55 AM
Houston
Ah, I did manage to find this one: https://amzn.to/2LYrHJL
I'll try the drill-out fix suggested by Boxster.
I'm surprised I seem to be the only one worrying with this problem. Should I just go with the rubber doughnut for the occasional odd-size?
Leigh & Bettie
Houston TX
2017 Interstate GT
08-05-2018, 09:33 AM
2014 Interstate Ext. Coach
fairfax station
, va
Waste not
I have all the adapters, but I never use them.
Is that normal?
I've never had a problem with just putting the angled hose end in any inlet and closing the lid or weighting down with a rock.
Of course this is pump dump and go. I've never considered a semi permanent hook up.
https://images-na.ssl-images-amazon....iL._SX425_.jpg
08-05-2018, 10:01 AM
Franklin County
, Missouri
Tayara Travel, I had the same problem once. I just put a nearby rock on top of the ell to hold it in place when I pumped out. I don't keep the sewer hose hooked up so this worked for me. If there was more room in the hose compartment I would get the plug you located.
08-05-2018, 10:08 AM
Houston
Much of the time we "dump and go" in which case there is no issue. Sometimes I like to screw in when we arrive, dump, leave it connected, then dump again on departure. So I'd like the hook up option.
This is not a big deal, but I was wondering if there was an obvious fix I am missing.
Leigh & Bettie
Houston TX
2017 Interstate GT
08-05-2018, 11:46 AM
2007 22' International CCD
Corona
I’ve noticed that many campgrounds tend to have a convenient rock right by the sewer connection. Coincidence, I think not!
08-05-2018, 04:22 PM
2024 Interstate 19
Fulton
, Maryland
Is that normal?
I do the same most of the time. But if there is no rock and the pipe has threads I'll often use them just to be sure I don't spill any sewage.
- - Mike
08-05-2018, 05:59 PM
From All Over
Is that normal?
I've stayed at a few commercial campgrounds (but only for rallies) where the sites are so close together that my sewer hookup was under my neighbor's awning, and my neighbor on the other side had his sewer hookup under my awning. In situations like that, properly sealing the discharge hose to the sewer hookup is not only mandated by the campground, but also essential for controlling odors.
08-05-2018, 06:34 PM
1988 32' Excella
Robbinsville
, New Jersey
Actually that's not normally mandated by the campgrounds, the campgrounds are usually just relaying their state health department's mandate.
08-06-2018, 06:05 AM
fairfax station
, va
It's funny that you say that. The third place I stayed in my still young RV career is a place we still call "Stinky Lake"
I now avoid "full service" sites if I can, opting for EW or electric only if available. Of course we are travelers, not full-timers or long term campers.
I don't mind using the communal dump station every few days...most are very well maintained. Much better for me than having a live sewer outside my window.
08-06-2018, 11:08 AM
1988 32' Excella
Robbinsville
, New Jersey
To me it's actually seems a bit strange that this is a rare opinion.
Kind of the way a lot of non-RV people try to avoid public restrooms if they can (especially men when they need to take a seat). Yet many RV people get up in the middle of the night get dressed (or go out in public in PJs) go past their private bathroom walk a couple hundred yards to use a public restroom.
01-31-2024, 04:15 PM
2016 Interstate Lounge Ext
Quaker Hill
, Connecticut
No, but without a rock that is contoured to fit over the cap, I find that I need to hold it down but my arms or legs are not long enough to hold its down and then flip the pump switch
02-06-2024, 04:31 PM
Houston
Originally Posted by CarolC
No, but without a rock that is contoured to fit over the cap, I find that I need to hold it down but my arms or legs are not long enough to hold its down and then flip the pump switch ��
what works fine for me is put the out take of the macerator hose through the rubber doughnut and then screw the smaller sewer cap on. I am then able to jam the doughnut securely into an open sewer drain, and run the macerator. Even though the hose thrashes around during the dump, the doughnut and out take remain securely in place. It is not a vapor seal, but I don't have to find a rock or keep my foot on it.
Leigh & Bettie
Houston TX
2017 Interstate GT
