Old 07-03-2016, 11:14 AM   #15
Bellevue , Washington
Thanks guys. I am still stomped that the Magnum monitor would say it was in float mode but upon removal of the AC power, the radio would not turn on. Surely after two hours of driving the Magnum display was telling the truth and that there would have been sufficient power to drive the radio. I measured the house battery voltage and I think it was 12.7 or some voltage like that.
The schematic for the Airstream does show the power connection to main chassis. And mercedes documentation talks about a combiner for the Aux and Chassis battery. Wonder if the the Aux battery saved my bacon by being the only battery still alive after this debacle???
amirm is offline   Reply With Quote
Old 07-03-2016, 11:17 AM   #16
Originally Posted by Boxster1971 View Post
If you removed the Airstream installed solenoid and replaced it with a solid state relay you might have a problem with dealer. They will claim you modified the system and caused all the problems.
They can try
I already have a deep apology from the General Manager of the place and my salesman (who forwarded my email to him). So I don't think this is a problematic case given what happened.
Old 07-03-2016, 11:40 AM   #17
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Service snafu $&!&& and which battery is which
The battery capacity may have been depleted but the Magnum will still do its best and go through its phases ending in float.
Regarding the radio, what is the position of the battery disconnect switch when the Kenwood isn't working and you think it should be?
Old 07-03-2016, 08:38 PM   #18
lewster's Avatar
Naples, FL , Hood River, OR
amirm,
Did you have any other charging source for your house batteries at the time the monitor read float charge? If you had the engine on and the batteries were depleted, the charge from your engine alternator thru the BIM would have caused the magnum to go to float charge, as it would have seen this alternator charge as full batteries. An operational, decent solar charging system would have shown the same results on the Magnum.
Old 07-03-2016, 10:06 PM   #19
Thanks for pushing me on this . My thought that the radio was only powered by the chassis batteries had led me down the wrong path.
I think the radio was going off when I had the DC switch disconnected. That also blanks the battery monitor AUX reading. I somehow associated these with the Mercedes batteries and not house.
Translating into English , the only thing that seems to have gone wrong here is the house batteries drained completely. The rest was my brain also drained completely, thinking another battery was killed.
The last thing that remains now is why the solid state switch is latched on. Will troubleshoot that now. Would be sad if it does that if the battery voltage goes too low.
Thank you all. As I get ready to re-do all of this for Lithium system, this has given me more insight into how everything is wired.
Old 07-03-2016, 10:08 PM   #20
Originally Posted by lewster View Post
amirm,
Yes, the stock airstream solar was on and it was sunny. Usually I see it back off when Magnum is running. I think in this case float was right in that I have measured the alternator pump more than 100 amps into the house batteries. Over the 2 hour drive, that should have finished bulk charging and the voltage was high enough for the Magnum to just go into float.
Old 07-03-2016, 10:39 PM   #21
lewster's Avatar
The 100 amp alternator charge is easily attainable, given that Airstream used (wisely) 1/0 cable from the alternator/chassis battery to the house batteries.
BTW, we are testing a Victron component from their marine selection that will allow for proper alternator charging of an auxiliary (house) battery bank that is lithium compatible.
I'll keep you posted on that one.
Old 07-04-2016, 10:06 AM   #22
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Unfortunately Airstream didn't switch to the 1/0 cable until about 2014 or 2015. My 2013 has a meager 4 AWG cable between the batteries.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 07-04-2016, 10:39 AM   #23
Yes, it has been one of the most pleasant surprises. Engine charging is at the cornerstone of my Lithium conversion.
Please do. I have a Sterling battery to battery dc-to-dc converter which current limiting which solves the strain on the alternator problem. But otherwise, it is very poorly implemented, not even allowing customization of charging parameters! The canned Lithium setting will likely cook the batteries and needs secondary limiting.
I hope Victron does a better job. It is remarkable that there is not one good Lithium charger on the market for mobile industry. They still try to shoehorn their lead acid chargers into this application which just doesn't work. They need to look at current draw in addition to voltage and have a single stage method that charges and then stops. It also needs secondary control for safety, allowing BMS to instruct it to curtail or shut down current.
Old 07-04-2016, 01:03 PM   #24
Fulton , Maryland
One of the frequent posters on the Sprinter forum (Graphite Dave) uses a unique method to ensure the house batteries always get a proper charge off the alternator. He uses an inverter tied directly to the alternator/chassis battery which provides 120VAC for various uses while driving including powering a Magnum inverter/charger which can be programmed for a proper charge profile. There are some additional loses doing this but they are insignificant to the vans engine and alternator.
http://sprinter-source.com/forum/showthread.php?t=22415
- - Mike
- - Mike
Old 07-04-2016, 05:03 PM   #25
Long Island , New York
Mike did you now that he is now building a new Ford Transit RV, and has a site documenting the build?
http://www.ortontransit.info/
Solar system: http://www.ortontransit.info/solar.php
I don't see anything specific about the inverter off-hand, but his thread here has info. on that IMO:
http://www.fordtransitusaforum.com/c...orton-diy.html
Cheers,
Peter
Old 07-04-2016, 09:19 PM   #26
Fulton , Maryland
Originally Posted by OTRA15 View Post
Mike did you now that he is now building a new Ford Transit RV, and has a site documenting the build? ......
Cheers,
Peter
Yes - I was aware of his switch to a Transit. He still posts a lot on the Sprinter- Forum.
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
Service A and Service B nesoutlook Sprinter and B-van Forum 17 12-14-2015 08:36 AM
Getting warranty service (or any service) at an Airstream dealer SeaLevel General Repair Forum 35 11-30-2015 08:01 AM
Our first winter "snafu" ...... truxpin Winter Living 9 12-08-2013 07:15 AM
Winterizing snafu - low point drain valve on FW tank stripped and won't opem bonginator Fresh Water Systems 12 09-29-2013 02:22 PM
AS Parts SNAFU! Turtle Windows & Screens 1 10-02-2005 06:43 AM
