Old 05-11-2016, 08:11 PM   #43
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Originally Posted by Mcrider View Post
I just discovered a more elegant and simple resolution to shutting down the inverter and it is a Magnum option AS could have installed.
"The MM-DCLD (DC Load Disconnect) pigtail adapter is designed to provide a
means to DISABLE the inverter function when a 12 volt DC signal is removed.
This is useful in applications when a vehicle or boat is placed into storage
and the battery disconnect switch is turned off to disconnect all DC loads, the
inverter can also be automatically turned off if the MM-DCLD is installed."
Thanks Mcrider - that item looks interesting. I'll have to research it further to see if it works on the entire Magnum line since I've upgraded to a 2000 watt unit. Here is link to manual.
http://www.magnum-dimensions.com/sit...27-MM-DCLD.pdf
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 05-11-2016, 08:40 PM   #44
Fulton , Maryland
Ok it looks like the MM-DCLD is only designed to work with the MM series inverter installed by Airstream. But there is a similar item known as the ME-DCLD that works with the other Magnum units including my MS-2000. Both big tails look the same but they might have some internal differences. Here is link to the ME-DCLD manual.
http://www.magnum-dimensions.com/sit...-A-ME-DCLD.pdf
I wonder what Lew Faber thinks of this Magnum accessory and if it would be a better solution.
Neat stuff!
- - Mike
- - Mike
Old 05-11-2016, 09:08 PM   #45
lewster's Avatar
Naples, FL , Hood River, OR
- - Mike
I'm very familiar with this device. The only problem is that you need a 'stack port' which is usually at the top of the RJ-11 input groupings.
Unfortunately, your MMS series inverter/chargers DO NOT HAVE THE STACK PORT. This is why I never mentioned this route for the Interstate coaches with the MMS series Magnums.
The red Blue Sea Systems M-series switch in the foreground is my go-to device for completely isolating the inverter from your battery system. The shot is of a freshly completed solar/ Magnum system with a 300 amp/hour lithium all neatly positioned under the curb side of the rear lounge.
Sorry guys!
PS: Mcrider, It should work on the MS-2012 or MS-2000 as they both have the required stack ports. I still prefer the manual M-series switch though as any electrical switch will require some parasitic draw to be operational.
Old 05-11-2016, 09:35 PM   #46
Fulton , Maryland
I've read through the documents for these Magnum DCLD accessories and it's not clear that they would eliminate all parasitic DC battery drain. The instruction sheet says the charger function will continue to work, that implies there is still an internal DC connection to the batteries. This does require more research and I plan to contact Magnum tech support and see what else I can learn before using this accessory. Need more info.
- - Mike
- - Mike
Old 05-11-2016, 09:44 PM   #47
Fulton , Maryland
Sorry guys!
Thanks Lew. I posted my last as you were posting. I'm sticking with the BSS M-series switch I installed. Just looking for another way to disconnect the inverter and other DC loads independently. Perhaps a second switch would be best.
- - Mike
- - Mike
Old 05-12-2016, 05:49 AM   #48
Houston , Texas
I agree Lew that a switch is the ultimate solution for storage. For $30 I like this addition as it avoids the mistake of accidentally leaving inverter on when one intends to have the house in a low energy state (I.e. The convenience of hitting the main disconnect during short stays).
I do like your lithium setups but not prepared for that $$ yet. The AS has been in a driveway for 4 days with frig running and not until morning of day 5 have I seen 50% DOD. waiting for the sun to pop up. It was overcast yesterday. I'm satisfied with what the 300 Watt solar is doing especially for plug and play. I've concluded I need additional AH to accomplish what I'm after so plans in works for two more 24Ts.
Mcrider is offline   Reply With Quote
Old 05-12-2016, 07:54 AM   #49
I like the solid state relays over solenoids since their parasitic loads are 3 orders of magnitude lower when they are on. It's true that they are never truly off but their bleed current is measured in micro-amps. To put that in perspective, a 70uA current would take over 160 years to drain a 100A battery. This is nothing compared to the internal discharge rate of lead acid batteries.
The ideal solution (IMO) is a separate inverter and charger with a solid state cutoff for just the loads and not the charger.
If you ever go with Lithium batteries, a good battery management system will not only protect the batteries from over charging or discharging, but will also handle all the charging and battery isolation without needing to turn a knob or push a button.
LB_3 is offline   Reply With Quote
Old 05-12-2016, 09:00 AM   #50
Fulton , Maryland
With more reading of the Magnum inverter manual and thinking about this DCLD accessory overnight I've concluded it functions just like the On/Off switch on the Magnum inverter/charger. How well that works to stop the parasitic current in the inverter is something I can measure myself. If it is as low as pointed out by LB_3 it would be a useful item to add to the Magnum and certainly better than the solenoid used in Airstreams SB-164.
- - Mike
- - Mike
Old 05-12-2016, 10:16 AM   #51
I've been looking at this 100A solid state relay but they are available in larger sizes:
https://www.waytekwire.com/datasheet/44402.pdf
Old 05-12-2016, 01:50 PM   #52
Houston , Texas
- - Mike
I read it the same way. The no-load Magnum draw with Inverter On is 1.6amps. With inverter off, 0.4 amps. TheDCLD does not shutdown the charger. I've ordered it.
Old 05-12-2016, 01:55 PM   #53
At 0.4 amps you're looking at about 10AHs per day. That will kill a battery inside of 2 weeks in a garage with no power.
Old 05-12-2016, 04:55 PM   #54
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
Looks to me like the MM-DCLD is a nice addition to the basic 1,000W Magnum Invertor and can be plugged into the same port as the temp sensor by using a 6 pole phone splitter.
What say you Lew?
c21bill is offline   Reply With Quote
Old 05-12-2016, 09:27 PM   #55
lewster's Avatar
What say you Lew?
You would only need a 4 conductor splitter as Magnum only uses 4 wire RJ-11 plugs, but I'm not sure that the MMS series will accept the DCLD into that port. I've used a splitter for adding the ME-AGS-N which is a networked auto generator start wired thru the inverter that works with the MMS series and reads thru the ME-RC, but not sure about the switching device. I would suggest a call to Magnum tech support on that one.
Old 05-12-2016, 10:34 PM   #56
I'll call them. Thanks Lew.
Dometic Service bulletin lewster Electrical - Systems, Generators, Batteries & Solar 8 08-11-2015 08:59 AM
Tacoma--upgrading suspension/Technical Service Bulletin work? Belbein Tow Vehicles 4 03-10-2014 10:54 AM
Dometic Refrigerator Service Bulletin TomW 1967 Overlander 5 10-31-2010 05:26 PM
Service Bulletin: #131, Chassis frame rail bracing MyParadise 2002 - 2005 International 6 08-18-2009 04:58 PM
Service Bulletin #29 upallnight Repairing/Replacing Floor &/or Frame 9 05-12-2004 10:08 AM
