Old 09-16-2014, 04:49 PM   #1
weirdstuff's Avatar
2018 23' International
San Diego , California
Service 'B' Due.. question
We r currently in Montreal. Getting message that Service B is due in 1800 miles.
I think we will drive about another 4000 miles before we get home. Wondering if we should find a sprinter dealer to do service while we r on road, or just wait until we get home. Not sure how critical it is to do exactly on time.
Thx for ur advice!
weirdstuff is offline   Reply With Quote
Old 09-16-2014, 05:40 PM   #2
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
I've always had my services done 400-500 miles past when indicated by computer. I'm not sure about going over by 2,000 miles. Which service are you due for next? I had my 40,000 mile service done while on the road on Portland. The 40k service is a big one with filter and transmission fluid changes.
- - Mike
2013 AS Interstate on 2012 MB Sprinter
- - Mike
Old 09-16-2014, 06:36 PM   #3
weirdstuff's Avatar
We will b at about 25,000 miles. It's prob normally done at 20,000 but we bought a demo with 4500 miles on it and they did a service for us when we bought it and reset interval. (Make sense?)
Old 09-16-2014, 07:21 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
If it was me, I'd do the service 1800 miles early rather than doing it 2200 miles late.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-16-2014, 07:37 PM   #5
Ron_CA's Avatar
2015 Interstate Ext. Coach
I would do it now as well. Any where near Raleigh North Carolina? Great Mercedes dealer there.
Ron_CA is offline   Reply With Quote
Old 09-16-2014, 08:10 PM   #6
Fulton , Maryland
Where are you going from Montreal on your way home to San Diego? One of the best Sprinter dealer service departments in USA is Sun Motor Cars in Mechnicsburg, PA.
http://mercedes.sunmotorcars.com/sprinter-repair.aspx
- - Mike
Old 09-16-2014, 08:57 PM   #7
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
If you're at the 20,000 mile service (sounds like you will only be about 500 miles over), then it's an oil/filter change and fuel filter change. Also rotate/balance the six wheels and front end alignment. If you notice the outer edge of the front tires wearing faster then have the camber set to the most negative side of the allowed range. IOW closer to vertical.
Also fill the DEF reservoir and change the cabin air filter.
If it's the 40,000 service then like Mike said, the tranny fluid and filter get changed along with the engine air filter and belt.
There's a whole host of maintenance checks and all of this is spelled out starting on page 11 of the Sprinter Maintenance Booklet that should be with the rest of the stuff that came w/ the van.
Old 09-16-2014, 09:49 PM   #8
lewster's Avatar
Naples, FL , Hood River, OR
Thx for ur advice!
Nancy,
You can't ignore the service schedule, nor can you extend the mileage when you have it done. Once you reach the zero point for having the service done, your mileage counter will show negative, like -100, -200, etc. When you reach a certain point (this has changed with model year, but it was around -1000 miles on my '11 van), you will start to get a count down showing the number of engine starts that remain before the computer shuts the ignition and will not allow you to start the engine. Only a re-flash of the ECU done by Mercedes will re-set this lock-out.
I would highly suggest that you get the service done within the 1000 mile window after you have reached the zero level.
Old 09-16-2014, 10:15 PM   #9
ScottP's Avatar
2018 30' International
2018 Interstate Lounge Ext
Bend , Oregon
We all have opinions I guess.
Depends upon your route of
Travel. Seems like you could coordinate service enroute to your return home. A good Mercedes dealer such as the Sprinter/Mercedes dealer near Portland Maine yields a free C-Class loaner car and an opportunity to sample the fine restaurant and culture of Portland Maine and Portsmouth New Hampshire. Suggest Wentworth By the Sea hotel and Chauncey Creek Lobster Pound :-)
Scott
www.CirrusVillage.com
2018 Int. Lounge 9 pass 4x4
Bend, Oregon & Rye, New Hampshire
Previous 9 pass Interstate's owned:
2014.5, 2015, 2016, 2017 (4x4)
ScottP is offline   Reply With Quote
Old 09-16-2014, 10:34 PM   #10
73shark's Avatar
That didn't happen w/ mine on the 20,000 alert. I think that you may be thinking of the DEF refill alert. Now that one will shut you down if you don't fill it when it says to.
Old 09-16-2014, 10:48 PM   #11
lewster's Avatar
MUST BE GETTING OLD!!
I stand corrected!
Now that you mention it , that is it exactly!!!!!
Thanks for the correction.......
Old 09-16-2014, 11:28 PM   #12
2005 22' Interstate
Pittsburgh , Pennsylvania
Neither my 2004 nor my 2014 Sprinter call for a front end alignment as part of routine service schedule. I believe that is an "as needed" item.
Formerly: 2005 Airstream Interstate (2500 T1N)
Now: 2014 Great West Vans Legend SE (3500 NCV3)
avanti is offline   Reply With Quote
Old 09-17-2014, 10:47 AM   #13
weirdstuff's Avatar
Thanks all. Just talked to our dealer back home and he also said to get service done on the road.
We will b going right through Harrisburg & mechanicsburg...but, it will b the weekend. Darn.
I'll find a place though, and get it taken care of.
Looks like wel b going south on the 81, through Virginia, then heading west.
Sure could use a good washing too. Space shuttle is looking ratty!!!
Old 09-17-2014, 11:02 AM   #14
You're in luck, sort of. Since Schedule B service is not warranty work, you're not limited to going to a Mercedes Benz Sprinter dealer; you can also go to a Freightliner dealer to have the work done, and probably cheaper than at MB.
Check along and near your planned route for Freightliner dealers, and for Mercedes dealers that handle Sprinters. You're bound to find one.
WBCCI #1105
TAC LA-4
"Service A due" message weirdstuff Sprinter and B-van Forum 17 07-12-2014 09:56 PM
Restrictions due to price of fuel marvinr Tow Vehicles 10 04-30-2008 07:23 AM
Give Credit Where Due Ganglin Off Topic Forum 4 05-10-2007 07:12 PM
Frustration Due To Time Out Just Makes Me Want To..... 87MH Forum Admin, News and Member Account Info 9 03-14-2006 08:23 PM
Removing rear skin due to dents IPM Ribs, Skins & Rivets 11 09-02-2003 10:11 AM
