Old 09-17-2014, 11:44 AM   #15
2005 22' Interstate
Pittsburgh , Pennsylvania
Indeed, it doesn't even have to be a Sprinter-specific facility at all. This work is not rocket science. The problem is getting the proper fluids and filters on the road. If you are really worried, you could always take them with you, just in case.
Formerly: 2005 Airstream Interstate (2500 T1N)
Now: 2014 Great West Vans Legend SE (3500 NCV3)
avanti is offline   Reply With Quote
Old 09-17-2014, 02:52 PM   #16
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Originally Posted by weirdstuff View Post
Thanks all. Just talked to our dealer back home and he also said to get service done on the road.
We will b going right through Harrisburg & mechanicsburg...but, it will b the weekend. Darn.
I'll find a place though, and get it taken care of.
Looks like wel b going south on the 81, through Virginia, then heading west.
Sure could use a good washing too. Space shuttle is looking ratty!!!
Check with Sun Motors. I think they are open for service on Saturday.
- - Mike
2013 AS Interstate on 2012 MB Sprinter
- - Mike
Old 09-17-2014, 03:12 PM   #17
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Mercedes-Benz Dealer in Raleigh NC - New Used Cars SUVs Durham / Leith Inc is right at the top of north carolina. They are close to a mall with good restaurants and a barnes & noble.
Ron_CA is offline   Reply With Quote
Old 09-17-2014, 08:33 PM   #18
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Originally Posted by avanti View Post
Neither my 2004 nor my 2014 Sprinter call for a front end alignment as part of routine service schedule. I believe that is an "as needed" item.
It's not, I just had it done w/ the tire rotation to get the camber fixed.
My theory is that the alignment specs are for a Sprinter w/o the extra weight in the rear from the Airstream conversion which tends to raise the front end causing the camber to go more positive. This will wear the outer edge more which is what a lot of folks are seeing. Wished I had brought some camber bolts so I could have gotten closer to the negative side of the spec. Maybe next time.
Any Dodge dealer that's a former Sprinter dealer can also do the service.
Some truck stops have high bay truck wash facilities.
Old 09-22-2014, 02:12 PM   #19
weirdstuff's Avatar
2018 23' International
We're at Mercedes Benz in Knoxville, TN. Great people here. They're taking care of us. Doing our Service B, and checking out a couple other items. As luck would have it, in their customer lounge, they have a generous supply of my favorite candy...Peppermint Patties. And they have super fast wifi. I'm happy.
weirdstuff is offline   Reply With Quote
Old 09-22-2014, 09:42 PM   #20
toskeysam's Avatar
Townsend , Tennessee
MB Knoxville is my home dealer😊. Got both bases covered there. MB Knoxville for chassis and Chilhowee RV (near airport) for the Airstream part.
And I agree...nice people😊
FMCA # 436814
toskeysam is offline   Reply With Quote
Old 11-20-2014, 10:21 AM   #21
Trying to Retire
MILATV's Avatar
Decatur , Illinois
I have 21,000 miles on my Van and just got a SERVICE A due; if 'weirdstuff' is getting a Service B Due message am I missing something? I had the 1st Service A done right at the 10,000 mark and taking my van in on Monday for another Service A; just want to make sure the CA dealer didn't reset my van as if a Service B was done. ??? What should be done.
Had the tires rotated before my trip (SEMA ) so I'm good there; and they always check my alignment when I bring it in; so good there.
I pulled page 11-12 from owners manual and Fuel Filter & Cabin filters seem to be the only added item over the 10k service.
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Old 11-20-2014, 10:32 AM   #22
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Mercedes Benz did muck around with the service intervals recently, and I'm not sure exactly what the triggers are anymore.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-20-2014, 10:56 AM   #23
nesoutlook's Avatar
Boca Raton , Florida
I have the same problem. The Service A was done 8k ago but the dash monitor says Service A in about 3,000 miles. I am pretty sure I need a service B in 3000 miles.
nesoutlook is offline   Reply With Quote
Old 11-20-2014, 11:37 AM   #24
lewster's Avatar
Naples, FL , Hood River, OR
Since I use my '11 Sprinter every day and have 103K on the clock, I change oil every 5K per Mercedes recommendation and all filters every 10 K. I also change the trans fluid every 25K, also per the dealer' rec.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 03-06-2017, 11:10 AM   #25
2015 Interstate Grand Tour
Port Charlotte , Florida
Originally Posted by Protagonist View Post
You're in luck, sort of. Since Schedule B service is not warranty work, you're not limited to going to a Mercedes Benz Sprinter dealer; you can also go to a Freightliner dealer to have the work done, and probably cheaper than at MB.
Check along and near your planned route for Freightliner dealers, and for Mercedes dealers that handle Sprinters. You're bound to find one.
I purchased a used unit last year and coming up on the 17k mile mark (Schedule B @20k miles). Are there any recommended dealers in the central-south part of the state of Florida for the non-warranty work besides the dealer? Or is the census to visit the dealer?
Coolrunnings is offline   Reply With Quote
Old 03-06-2017, 12:16 PM   #26
Rig Rat's Avatar
Columbus , Ohio
I agree with Protaganist's approach....shop around for the best $$. I got 3 written quotes from local dealers, 2 MB and 1 Freightliner. They all were priced differently. Some had an all inclusive $ and some were ala carte for each service item. When I compared what was included vs the cost for the separate components to the recommended 'B' service, I went with the all inclusive quote!
Rig Rat is offline   Reply With Quote
Old 03-07-2017, 10:16 AM   #27
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
Mine is off too. I had a service done at a yearly interval with a lot less then the 10k miles and it resulted in my Assist being incorrect. My dealer tried to reset it but to no avail. I just have to remember which service I am going in for.
c21bill is offline   Reply With Quote
Old 03-09-2017, 11:05 AM   #28
Ayr , Ontario
Funny I've never got a service A until now. I think I had 6 service B's in a row and then a Service C.
One thing to watch out for is that if you take the unit in elsewhere that they assemble the pipes properly. I took mine in to a "high end" shop (specializing in foreign cars) and everything was fine until they said that my oil cooler was leaking and wanted $2500. I took it to the dealer and they said all of the pipes where assembled incorrectly and that the seals had been re-used. They replaced the seals and put it together right. They also had to replace the belt as it had oil all over it. I've been now going back to the dealer, since going elsewhere didn't save me any money in the long run. So far the oil cooler has held, but it's still a ticking time bomb.
gator.bigfoot is offline   Reply With Quote
"Service A due" message weirdstuff Sprinter and B-van Forum 17 07-12-2014 09:56 PM
Restrictions due to price of fuel marvinr Tow Vehicles 10 04-30-2008 07:23 AM
Give Credit Where Due Ganglin Off Topic Forum 4 05-10-2007 07:12 PM
Frustration Due To Time Out Just Makes Me Want To..... 87MH Forum Admin, News and Member Account Info 9 03-14-2006 08:23 PM
Removing rear skin due to dents IPM Ribs, Skins & Rivets 11 09-02-2003 10:11 AM
