Old 04-10-2014, 06:57 PM   #1
2012 Interstate Coach
Redwood City , California
Seller forgot to give key for exterior little doors
The 2012 Interstate just arrived. Unfortunately the small key used to unlock the small doors is missing. The seller can't find it. Plus he's across the country. I think its to fill propane and maybe generator. What can I do?
poodlelover is offline   Reply With Quote
Old 04-10-2014, 07:16 PM   #2
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Well... Here are a couple suggestions...
1. Call Airstream Customer Support in Jackson Center and ask for replacement key or key info..
2. If cabinet locks have numbers on them, those can be used to make new keys by locksmith
3. Airstream used to specify key blanks and have places to write key code numbers in their Owner Manual Binders..
4. Worst case, a locksmith can open and make new key for the lock..
Condoluminum
Condoluminum is offline   Reply With Quote
Old 04-10-2014, 07:17 PM   #3
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
There should be a number on the key cylinder.
Any locksmith shop or trailer shop can get you the keys with that number.
The number will be something like GH005 or RH108 or R3223 or some such as that.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-10-2014, 07:34 PM   #4
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Those small doors on the driver side are for the tank dump systems. The larger lower door is where the macerator hose reel is stowed. The smaller upper door is where the black/gray water tank valves and macerator controls are located.
As others have mentioned any good lock shop should be able to get you a key.
- - Mike
Old 04-10-2014, 09:27 PM   #5
David M's Avatar
Orange County , California
All RVs use the same key for those small doors. My Neigbor had a box full of them that I can have as spares. Try going to an RV shop. They might have a box full of them as well.
David
David M is online now   Reply With Quote
Old 04-11-2014, 07:51 AM   #6
Thalweg's Avatar
1962 24' Tradewind
Buffalo , Wyoming
I had a problem like this once. I pulled into a locksmith parking lot. The guy came out with a key blank and a file. Five minutes later he hands me a key and I hand him $10, and I'm headed down the road. Easy-peasy.
Thalweg is online now   Reply With Quote
Why did Airstream change from front hinge doors to suicide hinge doors? arcamedies Airstream History 28 08-15-2019 12:06 AM
Duh....I forgot how mandolindave Photography 9 03-06-2013 07:49 AM
Amateur hour. Forgot electrical cord. RLemmens 2006 - 2010 International 6 11-30-2012 12:13 AM
forgot the low point drain rbs Winterizing, Storage, Carports & Covers 4 10-25-2012 09:49 AM
Forgot to put the pin in the hitch! 1cericks1 Brakes & Brake Controllers 9 07-21-2009 08:02 AM
