Old 02-10-2014, 05:34 PM   #1
BikerBill
2014 Interstate Ext. Coach
Poconos of Pa , Pennsylvania
Secure water fill cap for safety
I have been concerned with the security and safety of the water fill inlet for the built-in tank. The screw-on fill port is a PERKO brand. I purchased a PERKO “locking insert” #0525DPOBLK. The card says better than a locking “gas” cap but it is for the PERKOP water inlet ports. Cost was in the $25 range. Difficult to insert into the PERKO water inlet due to a slight ridge where the horizontal inlet turns downward about 45 degrees. Follow instructions and it reminds you to “trim off” the ridge. Be careful so the plastic debris you cut or trim off does not fall into your water tank. We had 3 hands doing it with a vacuum and flashlight to solve the problem. It works. It comes with 2 metal keys with a “handle” built onto the key which you need to help insert and remove the inlet blocking device.
ID:	205304   Click image for larger version
Bikerbill is offline   Reply With Quote
Old 02-10-2014, 05:44 PM   #2
toskeysam's Avatar
2013 Interstate Coach
Townsend , Tennessee
I tried to buy the water lock last month....was told they were out of stock and unavailable. Looked further and found they were being recalled due to material strength issues. If I can find the email they sent me I will post more details.
toskeysam is offline   Reply With Quote
Old 02-10-2014, 06:24 PM   #3
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
I had an issue with the cylinder staying in the body of the lock. I add a piece of plastic orotund the locking cylinder and now it works fine. Not easy to remove but better then no lock.
PSchw is offline   Reply With Quote
Old 02-11-2014, 10:44 AM   #4
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
I didn't order one of these because of problems that other posters were having. Perhaps now that they are recalled Perko will redesign them.
c21bill is offline   Reply With Quote
Fresh water fill removal & replacement thefiddler Fresh Water Systems 2 02-01-2012 08:37 AM
Water tank-weep holes-mystery leak(s). Gator113 Fresh Water Systems 9 09-21-2011 02:39 PM
Water Heater Calcium Deposits -- What to do? Wilmington Water Heaters, Filters & Pumps 7 05-18-2011 03:11 PM
atwood water being fitted to a 1960 Overlander Lothlorian Water Heaters, Filters & Pumps 10 01-01-2011 05:42 PM
