Old 06-04-2015, 11:52 PM   #15
bennu36's Avatar
2012 Interstate Coach
Portland , Oregon
Great thanks now I just have to past that test.
bennu36 is offline   Reply With Quote
Old 06-05-2015, 12:58 AM   #16
Figment of My Imagination
Protagonist's Avatar
Originally Posted by bennu36 View Post
Any way these radios are some what complex and to use most of the functions would take more attention that someone driving should spare.
Then it should definitely be installed on the passenger side in the tray over the sun visor. Along with a 1DIN CB radio in the center where that blank is now if you like; if you pop that center panel off there is a 12v power pre-wire behind it, though admittedly it's a very fine-gauge wire.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-05-2015, 05:46 AM   #17
Gainesville , Florida
On the older Interstate one could buy a high idle system which allowed for extended idling and better battery charging. Is this already on the newer Sprinter? Newer diesels don't like to be idled for long periods of time at low rpms. Jim
Old 06-05-2015, 10:32 AM   #18
norman , Oklahoma
Originally Posted by migriffin View Post
davydd's "Advancing Alvar" posts on the ClassBForum, he's reporting that he can charge his 800ah lithium batteries from about 30% charge in about 2 hours.
I'd like to read about that but could not find it with a search? migriffin, any help locating? Thanks!
russ240 is offline   Reply With Quote
Old 06-05-2015, 10:37 AM   #19
2014 Interstate Coach
You can find the thread here: Advancing Alvar - Class B Forums. It's a daunting 72 pages of posts, but a really fun read and got me really excited about some of the more innovative things that are happening in the space.
migriffin is offline   Reply With Quote
Old 06-05-2015, 11:08 AM   #20
Davydd's Avatar
Tonka Bay
Images: 13
I have the second alternator on my Advanced RV. It is a bit more sophisticated than just adding one. However, in prep for one you must order two options on a Sprinter. The first is an auxiliary alternator bracket for the alternator and that is a $409 option from Mercedes Benz. The second is the High Idle Fixed Package that is a $602 MB option. That is just the start and I have no idea if this can be done in a retrofit. That might be a point in this discussion in doing so for an Interstate.
Your engine alternator does charge your auxiliary batteries but not in an efficient manner. It and the computer module was never designed to do so and its primary function is to satisfy the chassis battery first.
My second alternator can charge my batteries at well over 240 amps and I think about twice the rate plugged into shore power will do. There is a 4.0 AWG copper wire from the alternator to the battery bank to do so. That is a humongous 1/2"+ diameter wire. I have an 800ah lithium ion battery bank that can take all the current you can slam at it and can restore a full charge to my batteries from an overnight stay where we draw down our batteries anywhere from about 120ah to as high as 300ah by driving generally about one hour at highway speeds. We have a total electric B, by the way, with no propane.
Roadtrek is installing second alternators they call an under hood generator but I don't know much about it and its capabilities. With all the cost involved I don't know if it would make sense for an AGM battery bank of two batteries.
Davydd
2015 Sprinter Class B Camper Van
(Former 1971 vintage Airstream Owner)
Davydd is offline   Reply With Quote
Old 06-06-2015, 06:09 PM   #21
BikerBill
2014 Interstate Ext. Coach
Poconos of Pa , Pennsylvania
Adding a 2nd alternator to a Sprinter is not an easy task. Not only is there a bracket needed to mount the alternator, you will also need a new fan belt once yo install the generator BUT there are problems with the lower radiator hose and related parts which have to be "relocated." It CAN be done but not cheap. Best to order the new unit with the extra mounting bracket from the factory.
The Roadtrek E-trek with the engine generator system uses 8-6 volt batteries if you order maximum power. They also then power a 5000 watt inverter to provide all the 115 volt electric one needs for AC, m-wave, TVs, outlets--all at one time.
The reason the engine needs to be revved up for about 20 seconds to 2000 RPMs is to kick-start the exciter winding in the 2nd generator which is a one-wire system. Once it begins to charge the engine can drop down to idle and can be left ton idle for more than an hour, per Customer Support at Mercedes.
As for wilding the Mercedes engine at an idle in a "quiet" campground setting vs running an underbody propane or diesel generator there is no comparison of sound levels. I cannot see where anyone in a quiet campground could complain about the idling of the Sprinter.
Davydd's ARV needs the high idle option since ARV uses a Silverleaf computer to auto-start the engine and rev it up. I don't know if they leave it at high idle nor do I know if they use the same generator at Roadtrek does.
Bikerbill is offline   Reply With Quote
Old 06-06-2015, 07:53 PM   #22
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
High humidity, no breeze and diesel exhaust is when they'd rightfully complain. It's not always the sound, but how/where the exhaust collects and does not disperse.
Old 06-08-2015, 12:35 PM   #23
Davydd's Avatar
Tonka Bay
Images: 13
The Advanced RV second alternator is a Nations dual alternator I believe a 270 amp model with a custome 3-stage charge controller. High idle is the Mercedes Benz High Idle Fixed Package. My understanding is that alternator is custom built for ARV. It doesn't rev at 2000 rpm to kick start anything that I am aware of. The engine starts and idles at a little less than 1200 rpm. Normal idle is down around 850 rpm. It doesn't need Silverleaf. The Silverleaf is a fancy central touch screen reporter and control module for a host of functions. The actual control is external to that. At high idle it charges my lithium ion batteries at around 200 amps. I can also manually start and turn off my engine without keys in the ignition remotely with the Mercedes Benz key fob, a Drone security key fob, a Drone iPhone app and RVC-Air app on the iPhone that mirrors the Silverleaf. I can of course simply use the Silverleaf touch screen. You do not need a key in the ignition. Barely and lightly touching the brake pedal will also stop the engine. So one cannot hop in and take off since you have to touch the brake to shift out of park.
I really never need the engine idle to charge my batteries. I haven't done so yet with about 100 days on the road other than to test and demonstrate it. It is there as a side benefit of having the dual alternator to fast charge lithium ion batteries independent of the Mercedes Benz computer controls.
A Mercedes Benz diesel engine is quieter than an Onan generator but I would not go so far to say it is acceptable to idle in a campground for an hour where rules forbid generators. Campgrounds are getting smart to that and include engine idling as a no no along with generators of any kind. You should have to abide by the same rules in place for Onan type generators. I'm OK with that. The Autogen feature is programmable so you can program in quiet hours to match a campground's rules. That is easily done with the Silverleaf touch screen. You can also disable it entirely with the touch screen. Otherwise it will automatically start when the batteries drop a certain percentage of charge.
Davydd
Old 06-08-2015, 12:49 PM   #24
On the Interstate, the engine exhaust is on the curb side, right where everyone gathers under the awning. The generator exhaust is on the service side.
For that reason if nothing else, charging my house batteries using the engine is never going to happen. That goes double if I'm going to be camping a while and set up my Fiamma Privcacy Room to enclose the area under the awning; the exhaust would be inside the room!
WBCCI #1105
TAC LA-4
Old 06-08-2015, 01:04 PM   #25
Davydd's Avatar
Tonka Bay
Images: 13
My engine exhaust is straight out the back of the van. That is a detail that can be dealt with but then it would add more cost in a retrofit case. But then I have already stated I think it overkill to try it with a simple standard 1 or 2 battery system. It is something Airstream will have to eventually totally engineer. They won't be competing with custom boutique builder Advanced RV on this but will eventually have to respond to Roadtrek's efforts.
Davydd
Alternator Charging House Batteries jerhofer Sprinter and B-van Forum 15 05-03-2015 09:10 PM
'02 LY 26' House Batteries not charging kardy Land Yacht/Legacy Motorhomes 13 05-04-2014 11:07 AM
Wiring a separate alternator for charging trailer batteries Streamside Batteries, Univolts, Converters & Inverters 12 01-04-2012 08:24 PM
Charging from alternator Bohemian Batteries, Univolts, Converters & Inverters 5 10-10-2011 07:32 AM
Charging with TV Alternator baby_beluga Batteries, Univolts, Converters & Inverters 4 05-20-2011 10:13 PM
