Old 12-18-2014, 01:23 PM   #15
1986 31' Sovereign
Miami , Florida
If you are getting only two channels in Houston, I would check the amplifier - there should be an indicator lamp adjacent to the port you plug the tv antenna cable into.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 12-18-2014, 04:06 PM   #16
2005 22' Interstate
Pittsburgh , Pennsylvania
Also, check all of the coax antenna connectors. This wiring was one of the places where the workmanship was very shoddy in our Interstate. I had to recrimp all of the connections in order to get decent performance.
Formerly: 2005 Airstream Interstate (2500 T1N)
Now: 2014 Great West Vans Legend SE (3500 NCV3)
avanti is offline   Reply With Quote
Old 12-19-2014, 06:47 AM   #17
Yup, we are going to check all of these issues in the near future, because something is obviously very wrong with our system. I will post specifics if/when we discover what it is.
Old 12-19-2014, 06:59 AM   #18
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
In May or so of this year, Winegard updated their batwing to a paddle design with tweaked frequency range and dual side pickup. It has definitely improved my digital reception and, turning the antenna around is less of an issue. It works with current hardware of the batwing.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 12-19-2014, 07:23 AM   #19
2005 22' Interstate
Yes. We updated to the new paddle antenna after our batwing was nailed by golf ball-sized hail. Works great and is physically much simpler and more robust. Easy install, too. It is bi-directional; i.e., you still have to point it, but it points in two directions at once, so there is significantly less fiddling involved.
Old 12-28-2014, 06:23 PM   #20
Following up on this, we replaced the original Winegard batwing with a King Jack digital antenna and went from receiving two channels to receiving ninety-two channels here in Houston. I had *no idea* there was that much free broadcasting going on. Much of it of course is special interest and non-English stuff, but it's interesting to see all that volume.
We won't be going with satellite services any time soon. I suspect that we will be able to get a number of networks in many travel locations.
There was probably something wrong with our old system other than it being just the analog antenna itself, is what I suspect. Apparently the new King Jack has its amplifier wired into the sequence at a different location than the old antenna... my husband did this work so I am not clear on the technical details. But I do know that he did not like the arrangement so he spliced a cut-off switch so the amplifier could not parasitically bleed the coach battery even a little bit. The new cut-off switch was installed in the upper closet panel; pic attached (we had to replace the original panel in that location with the two small panels visible in the photo... the original was apparently not designed to be removed... why not I have no idea, because owners need to be able to access all that wiring guts behind there...).
Old 12-28-2014, 09:00 PM   #21
2005 22' Interstate
The sun is slowly setting on the whole satellite video thing. We are still direcTV customers at home, and probably will be for some time yet. But we have never been tempted to install one of the unwieldy satellite systems in our rig. It makes so much more sense to concentrate on the best possible WAN Internet capability. It isn't perfect yet, but it is the future.
Old 12-29-2014, 05:27 AM   #22
...Apparently the new King Jack has its amplifier wired into the sequence at a different location than the old antenna... my husband did this work so I am not clear on the technical details. But I do know that he did not like the arrangement so he spliced a cut-off switch so the amplifier could not parasitically bleed the coach battery even a little bit. The new cut-off switch was installed in the upper closet panel; pic attached ....
This sounds discouragingly unwieldy as procedures go, so I perhaps should have noted that our original system had been a 110 volt arrangement in which my husband had to surgically remove a transformer because we switched to a 12 volt DC television. The original system did not make a lot of sense in the way it was laid out, perhaps owing to the age of our vehicle. Not everyone who wants to go with free-over-the-air TV will need to go to these lengths.
Any experiences with Tailgater Portable Satellite System by Dish? MarkMc Computers, Internet & Satellite 28 06-15-2013 09:16 AM
2005 Airstream Mercedes Interstate KVH Satellite System Direct TV eBay Watch Airstreams on eBay 0 06-30-2012 09:20 AM
2006 Airstream Mercedes Interstate Awesome KVH Satellite System Direct TV eBay Watch Airstreams on eBay 0 04-24-2012 06:50 AM
Internet satellite system silverbear Off Topic Forum 8 05-06-2006 04:27 PM
Sweet Satellite TV System - KVH A5 Xray Electrical - Systems, Generators, Batteries & Solar 2 08-21-2004 11:31 PM
