06-28-2014, 12:09 PM
#121
Naples
Ahy,
If you have 2 group 27 Lifelines, your settings are off. You have a 200 amp/hour battery bank. Also, the absorb time should be 1hour for a bank of this size.
Also, a 300 amp class T fuse should only be used for 2/0 cable. What size inverter cable do you have? I would think 1/0 or smaller. If so, you need a much smaller fuse.
Lew Farber
RVIA/RVDA Nationally certified Master Tech
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
lewster
06-28-2014, 12:37 PM
#122
2014 30' FB FC Bunk
Hoover
, Alabama
how many amps to run both my AC units out sheer curosity? I was wondering to myself about a larger unit to have permanent in my truck bed later down the road to use for home use if needed and for dry camping in the heat....13.5k unit and 15k unit
06-28-2014, 01:25 PM
#123
2011 Interstate Coach
Overland Park
, Kansas
My 13.5 uses about 14-19 amps depending on outside temperature.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
06-28-2014, 03:02 PM
#124
2004 16' International CCD
Chicagoland
The 13,500 BTU unit's compressor has a full-load current requirement of 12.4 A. The 15,000 BTU unit consumes 13.3 A. The fan motor requires approximately 3 A of additional current.
Note that these values are only for normal running conditions. Starting currents can be as much as 7 - 10 times higher for very short periods of time. The LRA (locked rotor amps) for these motors are listed here:
https://www.dometic.com/b97fb7b3-584c-470d-b19d-6b5d758792f7.fodoc
This is why Dometic requires a 3.5 KW generator for one unit and a 5.0 kW unit for two.
07-02-2014, 12:53 PM
#125
2014 30' FB FC Bunk
Hoover
, Alabama
Running AC on Generator Power
So like a honda EU6500 or EU7000 would run both AC units
I'm just bored and thinking
Bout to have electrician quote me for home 50amp install and trailer sits about 100 ish feet from fuse box so it will be costly I think
Want power for home airstream AC use for planned guests I get every year for extra sleeping arrangement (including during hottest summer months)
Perhaps such a generator will replace my need to pay the electrician and serve double duty for home
07-03-2014, 11:06 AM
#126
2013 Interstate Coach
Napa
You can use a normal 110v with an adapter and still run the ac unit. Dealer supplied my a a heavy gauge 30amp extension and an adapter down to normal wall outlet when I bought my AS.
07-03-2014, 11:52 AM
#127
Mantua
, Ohio
No you cannot without problems sooner or later. Jim
07-03-2014, 12:41 PM
#128
1974 Argosy 26
Morrill
, Nebraska
You will eventually damage the A/C running it with a 15/30 adaptor. The voltage drop caused by the smaller wire, plus the increased current will damage the 15/30 adaptor.
The guy at A$ doesn't have a clue!
07-03-2014, 02:04 PM
#129
2024 Interstate 19
Fulton
, Maryland
Just use a 20 amp circuit. The adapter will support 20 amps and It works OK on the Interstates with their smaller AC units. You select the 20 amp option on the power monitor panel and you won't be able to power much else. The AC on an Interstate draws about 18 amps at max.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
07-03-2014, 07:38 PM
#130
BikerBill
2014 Interstate Ext. Coach
Poconos of Pa
, Pennsylvania
jquayle, if you are plugged into a 15 amp circuit and your rv is the only thing drawing power from that 15 amp circuit and you are using a heavy extension cord as you state, no problem. That is unless it over 20-25' long. Window air conditioners in most houses are plugged into 15 amp outlets in the home and there is no problem. What you want to make sure with your RV is to not turn on any other heavy duty current draws: water heater for example.
07-05-2014, 03:40 PM
#131
Townsend
, Tennessee
To pharmgeek....I just looked into a 30 amp installation. Box set at 150 feet from main panel.....cable alone was $600. Ouch! May move the parking pad a little closer to the house.
FMCA # 436814
07-05-2014, 05:33 PM
#132
2014 30' FB FC Bunk
Hoover
, Alabama
yeah, no matter how I slice it, its going to be expensive....electrician is coming on monday to quote me on the cheapest way to do it...but expect it will be total cast at least 1K...if not 2k or more...we shall see...
Given how rare I will need to run AC at home and such....I may just buy something like the new Honda EU7000 (or its predecessor EU6500) and use it for home backup and home airstream use...and for travel when I will have no hookups....
07-05-2014, 05:39 PM
#133
Mantua
, Ohio
Might not be a bad idea, it being hurricane season. A genny at home to use with the AS or to run the fridge and fans etc, during power shortage is reassuring. Remember to store gas and exercise the genny occasionally. Those big units are real quiet, also. Jim
07-05-2014, 09:33 PM
#134
Chicagoland
Depending on what else you need to power in addition to the air conditioning you might be able to get by with much less generator. I see that Honda manufacturers quite a few different 5000 W units. You could probably save some money if you bought one of them instead of the 6500 or larger.
07-06-2014, 04:23 AM
#135
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
A 50m amp circuit like the wiring coming into the circuit breaker box in the Airstream trailer is composed of three #6 conductors for that short entrance cable.
To go over 100' and contend with air conditioner startup current, I could see direct burial #2 copper triplex cable. After all it is only $$$$$$$ and it is for your Airstream which is worth it.
07-06-2014, 06:57 AM
#136
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Do you have that on a 30 amp home circuit? Even with that and any distance from a dedicated outlet, you will be risking trouble IMHO.
07-06-2014, 07:32 AM
#137
2014 30' FB FC Bunk
Hoover
, Alabama
Uhhhh - just how many $$$$ are talking for that cable ?!?!
#138
2014 30' FB FC Bunk
Hoover
, Alabama
Thanks - I'll be looking into these as well
07-07-2014, 07:55 AM
#139
2010 22' Interstate
Anchorage
, Alaska
To supply a 30A load 100' away #6 wire (copper) will keep the voltage drop to 3%. 125' of 63 UF-B cable is $306 at Home Depot.
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
07-08-2014, 07:11 AM
#140
Napa
Thanks for the info. We don't do it very often, but occasionally before a trip with the kids we run it for a few minutes to cool down the AS before we leave. Normally the only items I have running are the fridge and the ceiling fan on the temp sensitive setting. (I find opening the rear most pop out window vents along with the ceiling fan draws a good amount air and keeps the van cool on all but the hottest days)
Jeff
