Old 08-24-2013, 04:39 PM   #99
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Originally Posted by joemikeb View Post
IF I am plugged into a 20 AMP circuit and use the panel to set input tp 20 AMPs the 20 AMP setting will hold. However, I noticed the other day that I had it set on 20 AMP and plugged into a 30 AMP source. When I turned on the A/C and apparently the panel automatically reset itself to 30 AMPs.??
I'm beginning to think that the Airstream Interstate is not quite ready for prime time.
Old 08-24-2013, 04:42 PM   #100
Newbie
joemikeb's Avatar
2013 Interstate Coach
Fort Worth , Texas
My take on that is the control panel is smarter than I was giving it credit for.
Make errors otherwise the Great Spirit realizes
you have finished your purpose on earth.
Navajo saying
joemikeb is offline   Reply With Quote
Old 08-24-2013, 04:53 PM   #101
73shark's Avatar
I agree with you if the panel can actually tell what the breaker size is that it's connected to. However I do not think the Airstream technology is quite that smart.
Old 08-24-2013, 05:32 PM   #102
David M's Avatar
Orange County , California
Lol, I don't think it's that smart either
David M is offline   Reply With Quote
Old 08-24-2013, 05:34 PM   #103
David M's Avatar
That's the same switch I'm talking about. It's just that when I press it it doesn't do anything. It doesn't switch between 20 and 30 amps. I even tried pressing and holding for several seconds to see if that's what it took it still doesn't change. The LED light remains lit for 30 amps all the time.
Yeah, there's something wrong there. You should be able to toggle between 20 and 30 amps.
Old 08-24-2013, 08:01 PM   #104
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Stupid question here - but you don't have generator running do you? It will default to generator over shore power if running.
Just covering all bases. Mine switched pretty quick from 30 to 20 when pressed.
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Old 08-25-2013, 07:10 AM   #105
2012 Interstate Coach
norman , Oklahoma
Originally Posted by MILATV View Post
May have found culprit, we took showers in van, and tried to heat water with elec for 10 min or so, but no indicator to say its running (first time trying water heater) so we turned off elec and fired it up gas. If water heater pulls from bat or inv I'm sure it sucked them down pretty low!
Just to clarify, the water heater does not run off battery power (neither 12v dc nor via inverter to 120v ac). It is a large load and can only run off of shore or generator power, just like the roof top air. Now the cold-weather tank heating pads (controlled by the red switch by the sliding door) for the fresh and grey water tanks, that's a different story. Those do draw 12v and will kill the house batteries in about 4 hours.
russ240 is offline   Reply With Quote
Old 08-30-2013, 01:44 PM   #106
Teamaron's Avatar
2014 Interstate Ext. Coach
Boca Raton , Florida
Ok
It happened again today.
Here's the scenario:
engines running and I go and start generator.
No problem, it starts right up and runs.
I then go and turn on AC after waiting a few minutes for Jenny to warm up.
So far so good, alls ok.
I then go shutoff chassis engine.
Now is when it starts going downhill.
After about 10 min or so of engine being off and no change in settings of Jenny. AC still running and all ok.
THEN, BAM everything shuts off. CAN'T RESTART !! ALL DEAD.
Only way to restart is by starting chassis engine again. It has to be batteries? Right?
But the weird thing is batteries still show 13+ volts even with nothing on?
This Damn thing is frustrating....
Teamaron is offline   Reply With Quote
Old 08-30-2013, 07:25 PM   #107
David M's Avatar
Wow, Teamaron; it sounds like you've got a completely different problem than what I had Hopefully consolidated minds of this forum can come up with a diagnosis...
David
Old 08-30-2013, 10:07 PM   #108
2013 22' FB Sport
College Place , Washington
On my old coach the generator and propane solenoid ran off the chasis batteries. If the chassis batteries are not great, when you alternator goes off you may not have enough voltage to fully open the propane solenoid for the generator. Then the generator may not have enough fuel to run at full power.
morgandc is offline   Reply With Quote
Old 09-04-2013, 07:51 AM   #109
hamiltonmj's Avatar
1965 17' Caravel
Opelika , Alabama
Agree. If battery power to the switch goes low then generator may shut down. Ca u check propane switch power?
Mike Hamilton
WBCCI # 2766
2013 Airstream Interstate (Darth Vader)
1965 17' Caravel (R2D2)
hamiltonmj is offline   Reply With Quote
Old 09-04-2013, 08:12 AM   #110
73shark's Avatar
Unless the inverter is off, wouldn't the generator bring the battery voltage up to the normal charge voltage and keep propane valve open?
Old 09-04-2013, 08:15 AM   #111
Figment of My Imagination
Protagonist's Avatar
Indirectly, there's a simple check. Light a burner on the stove. If it lights and goes right out, the solenoid is closed and you've just burned the residual LPG in the lines. Or maybe you've run out of propane in the tank. If the burner lights and stays lit, the solenoid is open.
However, on the Interstates, the propane solenoid is definitely powered from the house batteries, not the chassis battery. If you have enough battery power to start the generator, you've got enough for the propane solenoid to stay open. The only way you'd lose battery power while the generator is running is if your inverter/charger is malfunctioning (or switched off, as 73shark suggests) and not charging the house batteries— or maybe if you have an intermittent fault on a battery terminal connection so the inverter/charger can't charge the batteries.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-04-2013, 09:06 AM   #112
Teamaron's Avatar
I tried running burners and no problem there. But only when generator running. If jenny not on I don't even hear solenoid turn on or off at switch on outside of coach.
I think it's bad house batteries.
But how would you check for intermittent faults or inverter malfunction?
