Old 08-24-2013, 08:23 AM   #85
David M's Avatar
2013 Interstate Coach
Orange County , California
Originally Posted by MILATV View Post
100% not 200%. Fat fingers - little keys
Lol, when I read your original post, I thought, not even Lewster with his 5 solar panels can get 200%
David M is offline   Reply With Quote
Old 08-24-2013, 08:30 AM   #86
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by David M View Post
Protagonist, MILATV's 2014 probably has a Magnum Inverter so he may not have a 3 position switch on the Inverter itself like our Tripp-Lite inverter does. In fact, I don't even know where they put the Magnum inverter because when I looked at a 2014, there was a blank panel where the Tripp-Lites are. Perhaps someone with a Magnum inverter can chime in.
Didn't think of that. But even a Magnum inverter/charger is bound to have an "off" setting. If it doesn't, then when you don't need to invert, switch it to charge only. Don't rely on the inverter being smart enough to stop inverting when you shut all the 120vAC appliances off. Some appliances still draw power when switched off (anything with a remote control, anything with a clock display) so the inverter will NEVER switch itself to "charge" unless you start unplugging things (or until you hook up to shore power or start the genny).
Also, the inverter may not be shut off by the battery disconnect, either. Again, an easy check. Turn on a television, then turn off battery power; it the television stays on, the inverter is not controlled by the battery disconnect.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-24-2013, 09:19 AM   #87
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Thanks for the help,
I thought the bypass switch might work but didn't bother the wife (visiting her mother) will remember that one.
All "non required items" off from now on, but hoped wife could watch Netflix while I work at the beach w/o noisy generator - we'll work on that one.
Laptop gets 5hrs on batt so will use internal until generator running, shouldn't be a problem
May have found culprit, we took showers in van, and tried to heat water with elec for 10 min or so, but no indicator to say its running (first time trying water heater) so we turned off elec and fired it up gas. If water heater pulls from bat or inv I'm sure it sucked them down pretty low!
So that should drop me to one TV as second monitor (don't have to have router as I'm using Verizon on IPhone ( got router and retrans for iPads and blueray player for Netflix.)
I can go w/o that if needed but I work with some huge spreadsheets and 2nd monitor is helpful.
Ill update any notices, but with EVERYTHING running life w/o Jenny isn't very long
Will see how often it happens then consider battery & solar upgrades.
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Old 08-24-2013, 09:25 AM   #88
Trying to Retire
MILATV's Avatar
Decatur , Illinois
FYI. Magnum is under the rear bench,behind the breaker panel (not accessible w/o removing some screws, Remote allows for Off position but with battery disconnect OFF position, the magnum panel still works. As does all the other panels.
Mike
Old 08-24-2013, 10:42 AM   #89
David M's Avatar
FYI, I believe that the light on the waterheater only comes on if it fails to light. So it was probably working on electric. Also, you can run the waterheater on both electric and propane if you're in a hurry, but generally use propane unless you're plugged in to shore power.
Old 08-24-2013, 12:36 PM   #90
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
My A/C on a 90+ degree day will draw close to the 20A max. That's why I turn my Tripp-Lite inverter off because if I don't, the controller will shed load to get below the 20A max. The generator will continue to run as will the A/C fan, just not the compressor. This is what happened to me two years ago.
The inverter will draw some current even if the batteries are fully charged and it's set to line charge only. Maybe the Magnum operates differently.
If everything is working properly, one should be able to start the generator if the diesel is running and the alternator/chassis battery is supplying 12V to the buss.
On another topic on electrical, has anyone got the button on the monitor that supposedly switches between 20A and 30A to actually do something? On mine, the 30A LED is always lit whether on shore or generator power and pressing the button does nothing.
That's correct.
Old 08-24-2013, 01:03 PM   #91
It might do something if you plugged your shore power cord into a 15amp or 20amp outlet. Haven't really tried it.
WBCCI #1105
TAC LA-4
Old 08-24-2013, 01:52 PM   #92
Trying to Retire
MILATV's Avatar
Decatur , Illinois
That's correct.
Yes. If plugged into shore power you can push the button and drop to 20amp
I plugged into house and kept popping the breaker (TV + Air + Router) because power controller thought it had 30 Amps to work with, on 20 amp setting all was good.
Mike
Old 08-24-2013, 01:53 PM   #93
Trying to Retire
MILATV's Avatar
Decatur , Illinois
FYI I was plugged into a 20 amp plug.
Mike
Old 08-24-2013, 01:56 PM   #94
David M's Avatar
I believe you're supposed to manually press the button depending in whether you're plugged into 20a or 30a. The Gen light should come on when it's on.
David
Old 08-24-2013, 02:18 PM   #95
73shark's Avatar
David
I don't have a "Gen light". Are you referring to the Load LEDs that come on as the generator comes up?
I'm plugged in to a 15A outlet and the button does not have any effect. Besides it can't tell what the shore power service rating is.
The A/C will run on 15A shore power with everything else off as long as temp. is <80*. After that, the current draw will go over 15A.
Old 08-24-2013, 04:15 PM   #96
David M's Avatar
I think we're talking about the same button. I'm talking about the "Select" button on the Power Control System pictured on the upper right below. When you're plugged into 20a, you're supposed to press the button until the 20a light lights up so the AS doesn't try to pull too much amps and blow your shore power breaker. Or am I totally misunderstanding your question?
Old 08-24-2013, 04:21 PM   #97
73shark's Avatar
That's the same switch I'm talking about. It's just that when I press it it doesn't do anything. It doesn't switch between 20 and 30 amps. I even tried pressing and holding for several seconds to see if that's what it took it still doesn't change. The LED light remains lit for 30 amps all the time.
Old 08-24-2013, 04:36 PM   #98
Newbie
joemikeb's Avatar
Fort Worth , Texas
That's correct.
IF I am plugged into a 20 AMP circuit and use the panel to set input tp 20 AMPs the 20 AMP setting will hold. However, I noticed the other day that I had it set on 20 AMP and plugged into a 30 AMP source. When I turned on the A/C and apparently the panel automatically reset itself to 30 AMPs.??
On the same topic I just checked and the OAT is 102 and with the temp set at 78 the A/C is doing a good job holding the temp setting and only pulling 15 Amp.
Make errors otherwise the Great Spirit realizes
you have finished your purpose on earth.
Navajo saying
joemikeb is offline   Reply With Quote
