Old 07-04-2013, 12:17 PM   #43
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
Originally Posted by jquayle View Post
Can you post a picture of your final dip switch settings?
Not sure these switches are easy to capture on a useful photo, but you can refer to page 6 of the Tripp-Lite manual which you can download here: http://www.tripplite.com/shared/tech...ual/932768.pdf
This is for the RV750ULHW which is the model in my Interstate. Manuals for other models are available at the same website.
Hope this helps,
Wayne
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 07-04-2013, 01:21 PM   #44
David M's Avatar
2013 Interstate Coach
Orange County , California
Hello jquayle,
Here is my current dip switch settings. In case the picture isn't clear, the positions are (from right to left), up, down, down, up / down, up, up, down. My inverter is a Tripp-Lite RV750ULHW. Thanks,
David
David M is offline   Reply With Quote
Old 07-04-2013, 01:39 PM   #45
David M's Avatar
mine is in that same config 90% if the time! The memory foam mattress makes it fun trying to crawl under there and access the panel.
Just wanted to say I have the same experience. AC runs fine off shore power. (20 amp, not on a 30 amp circuit)
Mine also worked fine off of 20 amp shore power -- which perplexed me for a while. I thought, why would the inverter run the a/c under shore power when, at 20 amps, it isn't getting any more amps than what the generator puts out? Well it's because I wasn't pressing the "Select" button on the overhead panel to 20 amps when plugged in. So the inverter thought it was getting 30
amp shore power, doh!
Old 07-04-2013, 08:13 PM   #46
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Originally Posted by David M View Post
Do you remember which charging option you changed it to?
Here's my switch settings which according to my guy talking to Jim P. are the latest settings:
B4-UP, B3-UP, B2-DOWN, B1-DOWN, A4-DOWN, A3-UP, A2-DOWN, A1-UP
The 20/30 amp button on the panel does nothing on my unit.
Old 07-04-2013, 08:19 PM   #47
73shark's Avatar
Hello jquayle,
David
Attachment 190142
Did you really mean "right to left"?
Old 07-04-2013, 10:24 PM   #48
David M's Avatar
Yes, I did mean right to left. This is because the manual numbers the dip switches from right to left. My B1 and B2 were also both in the down position as a default, which caused my A/C not to turn on. Flip B2 up and see if this works for you. It did for me
Old 07-05-2013, 11:29 AM   #49
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Aaargh!! I'm a complete newbie when it comes to RV electrics, and I'm seriously trying to learn from this thread. However, it doesn't help that my Interstate has a Magnum inverter and Panel, and I can find no references to any of the above in the Magnum literature.
Old 07-05-2013, 06:00 PM   #50
Boxster1971's Avatar
Fulton , Maryland
UKDUDE,
I also have a 2013 Interstate with Magnum Inverter/Charger. I have run my AC off the propane generator many times with no issues as being discussed in this thread. My advice I not to worry about this unless you are having problems running AC off the generator. I consider the Magnum a superior unit to the Tripp-Lite. It is a 1000 watt inverter compared to the 750 watt Tripp-Lite.
- - Mike
Old 07-05-2013, 06:14 PM   #51
Teamaron's Avatar
Boca Raton , Florida
Is it possible for generator to have trouble with loads when low on propane?
Teamaron is offline   Reply With Quote
Old 07-05-2013, 07:35 PM   #52
73shark's Avatar
Hello jquayle,
David
Attachment 190142
The only one I would change is B4 to UP as the inverter will draw less current and it also will extend the life of the batteries. (according to the Tripp-Lite manual) It also was the change that kept the A/C from tripping off last summer.
Old 07-05-2013, 07:42 PM   #53
73shark's Avatar
Possibly when the liquid is gone and just vapor is left. But at that point, I'd guess there's not much fuel left.
Old 07-05-2013, 09:00 PM   #54
David M's Avatar
Originally Posted by Boxster1971 View Post
UKDUDE,
- - Mike
Wow, I wish mine came with the Magnum inverter. Then I wouldn't have had to go through this whole ordeal
Old 07-05-2013, 09:06 PM   #55
David M's Avatar
Yeah, I was thinking of the same thing. But the manual makes reference to extending life of smaller batteries. But I would think this applies somewhat to the Lifeline AGMs as well. I don't know enough about it to make an informed decision at this time. I'm sure others here do.
Old 07-06-2013, 08:05 AM   #56
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
UKDUDE,
You can download the Owner's Manuals and Data Sheets (PDFs) for the various Magnum Inverter/Chargers from their website: Document Library
Just choose your category (PSW or MSW) and select your model.
Wayne
- wayne
AIR #44779
TAC AK-1 !!
