Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 12-04-2006, 06:21 PM   #1
interstateflyer's Avatar
Profile:
Roof Rust on 2005 Interstate
I did a roof inspection yesterday on my 2005 Interstate and discovered extensive rust in the roof seams. Airstream did not paint the roof so it is the original Mercedes-Dodge white paint.
Has anyone else encountered this?
interstateflyer is offline   Reply With Quote
Old 12-04-2006, 06:45 PM   #2
Kistler's Avatar
Profile:  2002 25' Classic
Oro Valley , Arizona
What is an "interstate"? Is it the trailer or the van?
Kistler
Kistler is offline   Reply With Quote
Old 12-04-2006, 08:31 PM   #3
Profile:
Its the Interstate Touring Coach in my profile photo.
Old 12-09-2006, 03:39 PM   #4
Profile:  Currently Looking...
Gainesville , Florida
Interstate---class B motorhome////international---travel trailer, jim
zigzagguzzi is offline   Reply With Quote
Old 12-09-2006, 04:06 PM   #5
Kistler's Avatar
Back to the roof rust I wasn't aware that aluminium "rusted"!
Kistler
Old 12-09-2006, 05:14 PM   #6
RivetAddict
swebster's Avatar
Profile:  Louisville , Kentucky
Is it still under warrantee from Dodge/Airstream?
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
View My ThisOldRV.com Personal Page
ThisOldRV.com
swebster is offline   Reply With Quote
Old 01-10-2007, 08:47 PM   #7
Profile:
Yes it is under Dodge warranty but they exclude conversions from their paint coverage. Airstream says it is a Dodge issue. I believe that there are grounds to fight both on this. I may just have a local body shop do spot painting. I really don't have the time to deal with Dodge and Airstream. The rust needs to be dealt with now.
Why didn't Airstream paint the roof when they painted the rest of the coach. Sprinter vans have a history of roof seam rust, especially when drilling is done on the roof for add-ons. The metal filings tend to settle and rust if not properly cleaned off. They have been in the US since 2002.
Where else did they cut corners in areas that are otherwise concealed. The coach was painted half vastly I must add....painted it after they installed exterior components....white shows around the edges of outlets etc.
Old 01-15-2007, 02:58 PM   #8
AZtraveler's Avatar
Profile:  Cave Creek , Arizona
Interstate Paint
I have a 2006 Interstate. The paint job was not done by Airstream, but rather Carrera Designs and includes the roof. I'm not sure if it was custom, or if Airstream discovered the rust problem and began outsourcing their Interstate painting. Not sure if that helps any, but might give you more ammunition when trying to get them to cover it.
Larry C. in AZ
AZtraveler is offline   Reply With Quote
Old 01-26-2007, 04:34 PM   #9
Profile:
The seams rusted through both Airstream and DC paint. So beware and keep an eye on your roof.
I'm attaching some pictures. The roof is original Sprinter white with a blue cast from the sky. The Airstream color is champagne.
Name:	Right Center Roof 640-72.jpg
ID:	31368   Click image for larger version
Name:	Right Center Roof Close Up 640-72.jpg
Name:	Right Rear Roof 640-72.jpg
Old 01-26-2007, 05:43 PM   #10
SafariSS's Avatar
Profile:  2005 30' Safari
Houston Texas , Texas
Sprinter Rust..
hey there,
While I do not have an interstate I do have a 03 140 Wb Sprinter I use for work. I have rust on the edges of the drip rails and anywhere there has been a scratch. Apparently the body is not very well galvanized or primed well. I think the sprinter platform is fantastic, however I definatley believe that the engine will outlast the rest of the rig.
SafariSS is offline   Reply With Quote
Old 03-08-2007, 11:08 AM   #11
Profile:  Pocopson , Pennsylvania
I have 2005 Airstream Interstate -and yes I severe rust in roof seems in first year. Airstream reluctantly had repaired. Now 6 months later it is coming back again. Supposedl there is a 5 year warranty on paint.
rving42 is offline   Reply With Quote
Old 03-08-2007, 12:01 PM   #12
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Repaint alone wil not solve that problem. There is some contamination in the seam and unless it is ground out it will push up through the new paint again.
I would consider sewing in small claims court whoever built the original van. That may not cover the cost of repairs but it will get thier attention a lot faster than just asking. If the company has any operations in your state you should be able to get to them this way.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 03-08-2007, 09:22 PM   #13
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
The Sprinter is sold by Dodge and Freightliner and built by Mercedes.......take your pick!!!!!
Lew Farber -Certified Master RV Tech (currently on Forums sabbatical)
WBCCI #1456/VAC (assoc) #1456 AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 03-09-2007, 08:41 AM   #14
HowieE's Avatar
Images: 11
Lewster
This week it's all the same company. I would go for Mercedes just because that is where the money ends up, at least until GM buys them. I would file before GM gets into the act because they never warranted anything let along problems they bought.
dull roof on 1986 31' sovereign Daryl Miron Roof 12 07-25-2005 01:37 AM
Roof Air Problams 1985air345 Mechanics Corner - Engines, Transmission & More... 22 01-28-2003 07:40 PM
roof stack gaskets bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-25-2002 06:29 PM
Roof coating FrankR Roof 4 07-22-2002 02:56 PM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 02:35 PM
