Old 08-21-2015, 11:09 AM   #1
2013 Interstate Coach
Lafayette , Louisiana
Roof ac condensation
Anyone notice water from roof ac running down on exterior of Sprinter. I just noticed water flow while parked and roof ac running. I had not thought of where any condensation may exit the unit. Very hot humid air in S. Louisiana at this time. May have something to do with water condensation
buildup. Any comments?
drgene is offline   Reply With Quote
Old 08-21-2015, 12:36 PM   #2
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
It's normal. If parked headed downhill, it will usually run down the A-pillar. If parked headed downhill, it will usually run down a rear corner. My salesman told me about it during the orientation.
The higher the humidity, the more the A/C will extract from the air as it flows across the evaporator. Same as the A-coil in your furnace at home that usually runs down a tube to the closest floor drain.
Old 08-21-2015, 02:04 PM   #3
Boxster1971's Avatar
Fulton , Maryland
Agree it's normal. I sometime run the AC when parked in my driveway with slight nose up incline. Then the condensation runs down the back corner of the van.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Water Leaks and Condensation-34' LTD lmcatee Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 04-04-2004 04:16 PM
leak or condensation Tin Hut Windows & Screens 5 10-13-2003 03:42 PM
Window condensation Seon Windows & Screens 5 03-16-2003 10:19 PM
bed condensation kooblekidz Airstream Motorhome Forums 7 01-16-2003 08:52 AM
Window condensation????? Anna Windows & Screens 1 10-28-2002 10:51 PM
