10-29-2018, 06:36 AM
League City
Replacing skid plates with skid wheels?
We talked about this issue several years back, but (a) nobody identified a definite solution at the time, and (b) we have a bunch of new people on the forum now, several of whom are compulsive DIYers like LB_3 and me, so the fresh blood may be able to accomplish more on this question (heh heh).
I had a total *MY BAD* moment last Friday when I jumped a concrete curb abutment (finger structure) that protruded into a parking lot lane of travel.
In hot, humid Houston, concrete gets darkly mildewed, and if curb fingers are not edged in yellow paint for visibility (or red if fire lane) or sodded with grass in the middle of the structure, it can very difficult to spot them - they are camouflaged, blending in with the surrounding equally-mottled concrete pavement. Add an unfavorable sun angle and drivers will smash into them all day long.
Believe me, you don't want to hit a curb in an eight thousand pound vehicle - it's an acutely unsettling experience. It does not appear that I did any serious damage to upfit components, but I did shear off one of the two strike plates intended to protect the rear end (specifically the Onan generator).
Several years back, someone noted that we'd be doing our chassis a favor if we replaced those simple Airstream-installed plates with the kind that have heavy metal wheels at the bottom. That way, instead of scraping over obstructions and shearing when necessary, the Interstate could roll over stuff (presumably still snapping off when tolerance was exceeded).
It sounded good, but at the time, nobody identified a suitable upgrade product. Has anyone successfully done this kind of mod? If so, what did you use, and how did you determine that it was suitable for use on your chassis?
Sheared skid plate, offending parking lot in the background:
10-29-2018, 08:12 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
No...why would you want the rear to hit prematurely?
It could cause more damage than just scraping...plus with wheels you may not even notice that the rear end is dragging.
The stress could get really bad up an incline.👎
The skid plates are there for a reason...to skid, loudly. 🤣
"You don't know where you've been until you leave, enjoy life" RLC
10-29-2018, 09:21 AM
Contributing Member
Austin (Hays County)
I have a steep driveway that rises from a crowned road. When entering, I nearly always slightly scrape the passenger side skid plate and leave a 6" mark on the concrete. I can leave without touching, but it is very difficult to try to back up the steep slope. A wheel going off either side is not a nice option.
When I had my 22' International trailer, I had the same situation. I found some skid wheels that only reduced clearance by about 3/8" and mounted in the triangular opening. They were quite stout. I haven't been able to find those wheels for the AI. They would be very nice for my situation.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
10-29-2018, 10:08 AM
League City
When ANY metal part of an Interstate impacts the pavement, trust me - it will announce itself loud and clear. There will be no mistaking that event.
Also, I cannot parse these two sentences consecutively: "...you may not even notice that the rear end is dragging. The stress could get really bad up an incline."
May not notice it AND the stress could get really bad? I suspect that, if I didn't notice it, it's because the wheels would be rolling smoothly in a way that RELIEVES some of the stress.
The present skid plates are attached to the hitch infrastructure. One of the historical questions was, how much force should that area bear? What are the limits and how do we determine them conclusively? Then, how do we add something that conforms to that physical reality?
Check out this 30-second Class A vid. My question is, what are the working limits of those casters (as they are called)? It appears that they are taking some load off what I assume are leaf springs? They are not taking the whole vehicle load - they are just serving to keep it a bit higher than it would be without them (correct me if I'm wrong). But how much is safe in terms of exerting force where they are mounted? This was an unresolved issue from several years ago IIRC.
Edit: Maybe they ARE accepting what is effectively the whole load. The poster described them as 16,000 lb. casters. Expensive little suckers, too.
10-29-2018, 10:20 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
😂 I'm Parsing harder...granted it will roll easier, I'm not sure how much vertical stress is relieved.
But IS's are different than trlr's, so do what you feel is best.👍
WOW...i just checked $$$$ you were't fib'n. 😳
10-29-2018, 11:25 AM
2014 Interstate Ext. Coach
Camas
On my 2014.5 EXT they are just round metal loops and they are freaking loud when scraping, to protect the pretty fiberglass cladding cover the rear bumper, I was able to back out both times without further damage. They sure serve the purpose so I won’t do it again!
PS, you could reinforce the frame where a mounted set of 10k lbs casters could roll and help protect the rear end, enabling you to climb a little higher, until your driven wheels get airborne then you are truly stuck.
10-29-2018, 12:37 PM
2013 Interstate Coach
Waterloo
, Iowa
Just put mine in storage for the winter so I can't do an eyeball analysis, but I suspect the hitch assembly cannot support the rear of the vehicle even if you could find casters that would fit.
10-30-2018, 01:01 AM
2018 Interstate Lounge Ext
LV
, Nevada
INTERBLOG - I do not have skid plates. Mine came with skid loops. I am planning to upgrade to rollers when I find a set I really like that doesn't decrease the clearance any more. The loops are pretty flush to tow hitch structure. Any roller would at least double the protrusion, so I am debating if it would be a good idea to lower the clearance more.
FWIW - In situation where I can anticipate the clearance need (obviously does not help in an accidental finger curb incursion), I stop & raise the rear VB Air to max height (gives me 3-4" extra clearance)
11-01-2018, 07:29 AM
Prof. of Pending Projects
2018 Tommy Bahama Interstate
Orlando
Thank you for the photo Alex. Same setup I have. Had not noticed that those are just bolted in place. So technically we should be able to replacement with casters...once we find a set that can take the beating.
11-01-2018, 07:54 AM
2012 Avenue Coach
Corpus Christi
Those parking lot protrusions irritate me to no end. They serve no purpose that a paint-stripe wouldn't serve just as well. All they do is endanger tires, rims, and understructure. I don't care whether it's a car, truck, suv, or motor home. The person who decided these were a good idea should be tarred & feathered!
11-01-2018, 08:52 AM
2007 27' International CCD FB
San Diego
Casters are not solving the right problem. Sliding or rolling friction is not the issue. It's the vertical jacking forces. In the, the roller does not much help unless it can be mounted in such a way that it creates more clearance before it engages.
11-01-2018, 05:19 PM
LV
, Nevada
PTECK - Yeah, this is the issue why I have not removed the fixed loops to replace with casters. The casters actually REDUCE the already limited clearance. From a design engineering standpoint, the ideal design would be a caster system that is fully retracted but with a plunger pre-set at the max clearance desired. Once the plunger scrapes pavement, it drops caster. Of course, it is easier said than done, because a non-fixed caster would have to be engineered even more beefier than a fixed one, thus reducing clearance further. And hench the vicious cycle repeats. Ughh! I may just have to live with the fixed loops. I have been judicious & careful with driveways when I have a choice. I try always approaching at an angle instead of perpendicular. So far, I have only very barely scraped one of the loops
11-01-2018, 05:25 PM
LV
, Nevada
ROWIEBOWIE - Yeah, I agree. And if they really wanted to have those protrusion/curbs, why cant they use the now very common recycled rubber stuff. Lots of parking lot tire stops are made of them. All new playgrounds have them. Much cheaper than concrete and easier to relocate if need be
11-01-2018, 06:09 PM
2012 Avenue Coach
Corpus Christi
Does that mean we can't tar & feather them?
11-01-2018, 09:55 PM
San Diego
From driving very low clearance sports cars all my life, I can tell you that steel slides quite nicely. Even if fully engaged and dragging on whatever surface. Sure, it may leave a mark on the tarmac (as you see in the steep driveway entrances and speed bumps), but the steel member on the vehicle is really no worse for wear other than some cosmetic scrapes. Even after repeated day after day scraping.
Approaching and departing these transitions at an angle does does wonders for clearance.
11-02-2018, 12:31 AM
LV
, Nevada
ROWIEBOWIE - That's too light of punishment. I vote strapping them down on the tip of the protrusion I am not ashamed to say through the years, I have scraped many a nice wheels. Yeah, sure it my fault, but still . . . On the other hand, I notice many local LV parking lots are staying away from them, only putting them on really critical junctions and always with a tree, lightpole, or some type of vertical sign to serve as visual aid. Another example is in our subdivision, there are no squared off curbs. The street goes into the gutters and then gently slopes up to meet the sidewalks/lawns. So if somehow I misjudged the C/S, I just gently roll up the gutter to the curb and not ruin a wheel, tire, or alignment or undercarriage. All new developments here are built that way.
11-02-2018, 01:45 AM
Sag Harbor
, New York
Great discussion of the limitations of adding casters/rollers, thanks.
Peter
11-07-2018, 09:01 AM
2005 39' Skydeck 390 SD
Hillsboro
Here is what I did:
I add a hitch receiver on both sides for accessories and add a skid roller.
The height is the same as the flimsy sheet metal bows which I would not consider a skid plate as the bend or shear off at contact.
Peter
11-07-2018, 09:15 AM
Mrfixit
Bathurst
, New Brunswick
Skid plate under valves
Hi
I am just finishing a full redo on my vintage travelux. I have put a skid on the valve side but will probably add one on the other side. It has not hit anything yet,due probably, to raising the suspension profile by putting the axles under the springs.
11-07-2018, 08:06 PM
LV
, Nevada
Originally Posted by mrfixit51
Hi
MRFIXIT51 - looks customized. Does not look like you can buy that from any store. Very nice job! Since I am one of those 'prefer symmetrical' guys, I am with you on adding extra on other side, whether it needs or not, to balance the look. Not that anyone will be inspecting that underside too often, but then again you said it is raised higher now, so maybe it will be seen more
