06-25-2016, 11:00 AM
medanales
, New Mexico
Replacement of Hot Cold Spray Port
Has anyone changed the spray port on a 2016 Interstate? The gents at DW said it is as simple as removing the screws, pulling the unit out, unscrewing supply lines and then installing new unit by hooking up lines, putting unit in place, Apply sealant, replace screws. Could this be true?
06-25-2016, 11:17 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Depends on what you mean by "hot cold spray port." Do you mean the black tank flush fitting? The wet bath shower head? The exterior shower fitting? The galley faucet?
06-25-2016, 02:35 PM
medanales
, New Mexico
The external shower fitting. Thanks.
06-25-2016, 03:11 PM
Muskogee
, Oklahoma
Just curios-why do you want to replace it? It is true, but you must access the panel on the other side to unscrew the supply lines and it is a bit cramped.
2011 Interstate WD/Lounge (since sold).
2020 Leisure Van WonderRTB
06-25-2016, 03:14 PM
Auburn
, Georgia
Why are you replacing a brand new fitting (2016) ?
If the reason is that the male connector on the sprayer won't go in the fitting use a small Phillips head screwdriver and give it a light tap to free the internal valve seat.
Hope this will help if that is the problem ?
06-25-2016, 03:31 PM
medanales
, New Mexico
Unfortunately I missed the winterization part of the external shower and ended up with a leak that seems to be coming from the cold water valve. I had hoped I could get a valve kit but the manufacturer (DW) says nope you gotta replace the whole unit.
