Old 05-17-2018, 02:06 PM   #1
Ponte Vedra Beach , Florida
Replacement Lug Nut Covers
I've lost 2 lug nut covers from my 2018 AI GT. I can get replacements from Airstream for $7 plus shipping but does anyone know an alternative source.
Also, any tricks for keeping these from coming off in the future?
FlStrmr is offline   Reply With Quote
Old 05-17-2018, 03:29 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Toss those original lug nuts in the trash, ALL OF THEM, and replace them. Eventually you will get tired of dealing with the junk that is original equipment. Get stainless steel and be done for the next 20 years.
I kept searching online till I found McGard lug nuts on sale for $0.99 each. The bulk purchase of 40 gave me enough for 6 wheels on my 34' (Ebay or Amazon - can't remember)
ps:
I think I have some of those old lug nuts with covers in my storage building. If you can wait until next fall when I return to FL, you are welcome to all.
Alan
Old 05-17-2018, 05:13 PM   #3
2016 25' Flying Cloud
Holly Springs , Mississippi
Don't waste the postage. Buy the McGards and be through with this issue...forever.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 05-17-2018, 07:14 PM   #4
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
There was recent thread on this topic over on the Sprinter-Source LTV Unity subforum. They also discussed chrome lug nut replacements. Here is link:
https://sprinter-source.com/forum/sh...ad.php?t=64782
Also two sources with lower cost:
https://zips.com/parts-detail/phoeni...printer-c-sp39
http://www.phoenixusa.com/SP39
- - Mike
Old 05-18-2018, 07:49 AM   #5
Raymond , Iowa
Are the McGards an honest-to-God lug nut that looks nice, or just another brand of cover? The Phoenix are just a dimpled cover - not sure why they wouldn't eventually fall off too. Semi tire lug not covers screw onto the outer part of the stud - but I have never seen that type for the Sprinter.
Titus is offline   Reply With Quote
Old 05-18-2018, 12:55 PM   #6
2007 22' International CCD
McGards are an honest, one-piece lug nut. They flat donít have the crappy cover that splits and falls off when you least expect it.
Old 05-18-2018, 01:11 PM   #7
2011 Interstate Coach
Tulsa , Oklahoma
Just finished talking to McGard. They do not have a direct cross reference to the lug nut for Sprinter. They asked for and I have furnished them the M/B P/N but they are unable to determine the lug spec. They are VERY helpful and want to help we Sprinter pilots. They are requesting dimensions, ie; thread pitch, depth and chamfer. I do not have access to my rig to respond to them directly presently. I will attempt to get them that info in the next few days.
Road Jager
Living On Tulsa Time
RoadJager is offline   Reply With Quote
Old 05-18-2018, 01:32 PM   #8
Raymond , Iowa
The Sprinter wheels center on the hub and not on the lugs, so there is no chamfer to the lug nut. The lug nut sits flat against the wheel, and there is what looks like a washer at one end of the nut. The washer is where the chamfer would normally be. I believe the lug threads are 14 x 1.5 mm.
Old 05-18-2018, 01:40 PM   #9
Fulton , Maryland
The Lug Nuts are 14mm Threaded x 1.5
They don't have a chamfer and are open end nuts with a captive flat washer between the wheel and nut. The attached two PDF files from Alcoa talk about the issues related to lug nuts and changes in 2016. They also have photos of the uncovered lug nuts.
- - Mike
Old 05-18-2018, 02:14 PM   #10
2014 27' Flying Cloud
Stowe , Vermont
I had a cap pull off one of my lug nuts last week after a blow out on I-81 in PA. Afterwards, I called Colonial AS and ordered a full set of replacements that they said are "solid" one piece. FYI - my original lug nuts took a 3/4" socket. I think that's standard on all AS. When I stripped the "cap" off the nut, I found that it took an 18mm socket to fit properly. Since then, I heard that a lot of car and truck companies use the same crappy lug nuts as original equipment.
VT Wanderer is offline   Reply With Quote
Old 05-18-2018, 03:01 PM   #11
Raymond , Iowa
I don't understand the tech bulletin. It refers to inner dual position and outer dual position and steer wheel. I need to go out and check but I think my front and rear (dual on my 3500) lug nuts are the same. And the lug nut holds both the inner and outer real dual wheels. So why the distinction between inner and outer dual?
Old 05-18-2018, 03:07 PM   #12
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
Never really checked close enough to know we got caps covering nut/washer rather than true 1-pc lug nuts. Hoping McGards can give you some good answers.
Alex AVI is online now   Reply With Quote
Old 05-18-2018, 08:08 PM   #13
Fulton , Maryland
The front and rear lug nuts are the same. Those technical bulletins are about issues with trying to use Alcoa aluminum wheels in both the outer and inner positions on the rear axle. Airstream Interstates all have the OEM steel wheels on the inner dual rear axle position. Other manufacturers like LTV have offered a six wheel Alcoa option with an Alcoa aluminum wheel on inner dual position.
- - Mike
Old 05-18-2018, 08:20 PM   #14
Alex AVI's Avatar
I am going nuts over lug nuts As if the dually steel valve extensions were not bad enough.
Lug nut covers russ240 Sprinter and B-van Forum 27 03-07-2017 08:34 PM
Lug Nut Covers Rain Sprinter and B-van Forum 13 12-06-2016 06:12 PM
Lug Nut Covers - To cheap to stay on! dadstoy General Motorhome Topics 15 08-24-2015 05:43 AM
Lug nut covers? SebasSF Classic Motorhomes 25 02-22-2015 05:57 PM
Wheel / Lug nut covers bkahler Classic Motorhomes 3 04-13-2008 01:10 PM
