11-28-2014, 10:09 PM
2024 Interstate 19
Fulton
, Maryland
Replacement Latches for Overhead Cabinets
The Mercedes Sprinter, as equipped by Airstream for the Interstate, is probably the safest RV on the road today. But, first I had an incident with the overhead cabinet doors flying open while driving. Then after seeing some videos of RV crashes I realized there is a real risk of thinks flying forward during a driving incident if the overhead cabinet doors should open unintentionally.
So I began a search to get a more secure latch for the overhead cabinets. The stock push knobs are LAMP PK-03/CR Chrome Push Knobs by Sugatsune. www.sugatsune.com
After a bit of research I found a suitable replacement that fits in the same 28mm hole in the overhead cabinet doors. This push knob latch has a locking deadbolt action when the knob is pressed in. The holding force of the deadbolt is rated at 44 lbs. The LAMP TLP Push Knob Latch works as a drop-in replacement. Specifically it requires two parts; 1) the TLP-BB/CR Chrome Push Knob/Base and 2) the TLP-LBM/WHT Latch Body. The best price I found was from an eBay vendor.
http://www.ebay.com/itm/250995789012
This new push knob latch protrudes a bit more than the stock Interstate push knobs. Installing it is straight forward, but took a bit of adjustment to make it work correctly. Here are a few photos of the push knob latch installed.
11-29-2014, 12:10 AM
2011 Interstate Coach
Overland Park
, Kansas
I don't recall w/o looking but is there a lip already there for the deadbolt to latch against?
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
11-29-2014, 02:17 AM
2014 Interstate Ext. Coach
Sedona
My tall wardrobe has a catch like that. Don't see why they couldn't have used them on all doors.
11-29-2014, 03:25 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
I just adjusted the tension on the spring hinges. I've never had a door come open by accident; EXCEPT a couple of times the full-height wardrobe door! I trust the spring hinges more than I trust the latch on that door, that isn't adjustable to provide more holding power.
11-29-2014, 08:27 AM
2024 Interstate 19
Fulton
, Maryland
Yes the deadbolt latches behind that aluminum trim lip.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
11-29-2014, 08:40 AM
2024 Interstate 19
Fulton
, Maryland
If you could adjust the spring tension for a 44 lb. pull to open - do you think you could even open it with one hand? High spring tension would also be a problem for my 5 ft. tall travel partner. With spring tension tighten to high level you should check the length of the screws holding the door to the spring mechanism. Mine were only 3/8" and they ripped out on one door while opening it.
This upgrade isn't for everyone - those latches are over $30 each. I only offer it as a solution to my problems. My van gets fairly heavy use at over 20,000 miles per year - so maybe it is wearing faster than others.
Hope this is useful,
- - Mike
- - Mike
11-29-2014, 01:46 PM
2024 Interstate 19
Fulton
, Maryland
I should have included this spec sheet on my original post.
11-30-2014, 06:48 AM
2005 39' Skydeck 390 SD
Hillsboro
Thanks for the info this is what I was looking for I only found larger once.
01-06-2015, 03:51 PM
Hillsboro
I got it and try to install. It just does not fit. It fits the hole perfect but the latch is to close to the edge. The body of the back side does hit the edge of the cabinet. So there is no room for it to work proper.
01-06-2015, 06:36 PM
2024 Interstate 19
Fulton
, Maryland
That looks like you are trying to install latch on the wardrobe door next to the bath. I don't think that will work. From my measurements these latches only work on the overhead cabinets.
- - Mike
- - Mike
01-11-2015, 07:37 AM
League City
Originally Posted by Boxster1971
[SIZE=3][FONT=Calibri]... after seeing some videos of RV crashes I realized there is a real risk of thinks flying forward ...
Do you have any vids you could recommend for those of us who'd like to learn more about this issue?
Our 2007 Interstate doesn't have cabinet latches at all - just the spring tension on the doors. At times, I have wondered what I ought to do to in terms of stowage procedures to maximize safety.
Crashes have a low probability of occurrence, but if you are that person with a wreck and your gear isn't stowed well, then you have a high probability of a projectile risk. I saw a TV show once about how this issue can affect people with loose objects in passenger cars. It featured a woman who was rendered into a permanent vegetative state because she wrecked while taking home her groceries. As near as they could deduce, an airborne frozen chicken impacted her skull.
01-11-2015, 08:02 AM
From All Over
My best suggestion for that is to take a cue from boaters, who have to worry about things staying put through a much wider range of motion than we'll ever see. On each side of each overhead locker, right behind the door, put two screw eyes on each side. One set right below the hinges, the other set about halfway between the bottom of the hinge and the lower lip of the opening. Stretch a bungee cord between each pair of eyes. To put stuff in or take it out, you undo the bungee cords from one end. The rest of the time, the cords will restrain things from falling out, except for those items small enough to pass between the two cords.
01-11-2015, 09:51 AM
Overland Park
, Kansas
Or maybe some type of cargo net like that that comes on some SUVs.
01-11-2015, 04:24 PM
2024 Interstate 19
Fulton
, Maryland
Search Google with the phrase "rv crash test" and you will find several.
- - Mike
01-21-2015, 03:48 PM
Hillsboro
Mike you right it works fine on the overhead bins but not on anything else. I have more problems with the drawers an the cabinet door.
So my search will continue .
Peter
01-22-2015, 06:53 AM
2024 Interstate 19
Fulton
, Maryland
Some here once suggested using a child lock on the drawers. I haven't tried that yet, but the drawer under the stove top does fly open some times.
- - Mike
01-22-2015, 10:07 AM
2013 Interstate Coach
Boca Raton
On the draw under the stove I use a Velcro strip. Drawer doesn't open on turns and speed bumps anymore. This draw is used for kitchen utensils and silverware. The weight of these items was too much for the latch.
01-22-2015, 12:18 PM
2024 Interstate 19
Fulton
, Maryland
Thanks nesoutlook, that sounds like a good idea. We also use that drawer for our flatware and utensils - so it is heavy.
- - Mike
01-22-2015, 05:12 PM
Hillsboro
Yes that what we use it too. The Velcro sounds like a good idea I will try that.
Peter
01-16-2017, 02:10 AM
Loma Mar
The cabinet drawers under the sink and range open on corners. Took it to the dealer and they installed additional/heavier magnets that hold the drawers shut.
Good news/bad news: The stronger magnets do hold the drawers better, but they are hell to open now. I one's hand is even slightly wet, getting enough grip to pull the drawer open is almost impossible.
Boating industry, that's what I've been thinking. Looked through several sites, didn't find any.
Haasman
