Old 09-22-2014, 05:15 AM   #15
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Actually, AGM batteries can become swollen from charging them too quickly, which causes overheating. The plates in the cells get warped, which causes the sides to bulge.
I don't think it's the fault of your Magnum inverter. In fact, I'm inclined to lay blame on the engine alternator, which is using a single voltage regulator to charge not only the Group 49 chassis battery, but also the Group 24 house batteries through the BIM. You know how they always say not to mix battery sizes in a battery bank? Well, the engine alternator sees all three batteries as a single bank when the BIM has the two systems interconnected for charging, and it doesn't charge the batteries proportionally with their capacity or state of charge.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-22-2014, 09:23 AM   #16
mefly2's Avatar
2015 25' FB Eddie Bauer
+1 with Paul...
Old 09-22-2014, 10:26 AM   #17
According to the Lifeline Technical Manual (http://www.lifelinebatteries.com/manual.pdf) an AGM battery is very resistant to freezing temperatures:
100% charge, freezes as -94F
75% charge, freezes at -53F
50% charge, freezes at -13F
25% charge, freezes at +9F
0% charge, freezes at +21F
So unless you winterized your Airstream Interstates with less than a 50% charge which is I don't think you guys are so careless to have done the electrolyte in the batteries shouldn't have frozen. Even though freezing temperatures may cause the electrolyte to expand, you guys shouldn't have experienced temperatures cold enough, for long enough, to let the whole thermal mass of the batteries get that cold.
I still think the culprit is overcharging, probably from the engine alternator, which would have bypassed the Magnum inverter/charger entirely.
WBCCI #1105
TAC LA-4
Old 09-22-2014, 05:37 PM   #18
Trying to Retire
MILATV's Avatar
Decatur , Illinois
The van is outside in Decatur, IL; and we had some snow this year, so YES, but the van was plugged into 30A power so they 'should' have been at full charge all winter.
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Old 09-22-2014, 05:39 PM   #19
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Which is why Airstream should by me new batteries for saving $20 and not installing the Magnum Battery Temperature Sensor - costing me nearly $600 for batteries.
Amazon.com: Magnum MEBTS15 Battery Temperature Sensor with 15' Cable: Automotive
(I have mine to connect when I put new batteries in).
OF Course if overcharged by the ALTERNATOR then that is a whole other issue - how do I resolve that from happening again? I can't control what it does - can I?
Mike
Old 09-22-2014, 07:18 PM   #20
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
I don't think the lack of temp sensor or the MB alternator are likely source of overcharging.
I looked up the charging voltages vs temp in Lifeline manual. The necessary charging voltage goes up as temp drops. So without the temp sensor the Magnum charger would not overcharge in cold winter weather. If anything they would be undercharged in cold weather.
According to the PCI BIM manual the BIM is designed to prevent overcharging of the coach batteries during long drives. The BIM relay does not close to charge the coach batteries when engine is running until the coach batteries are below 12.6V. Then it shuts off after an hour of charging and won't turn back on until coach batteries are again below 12.6V. If anything the BIM undercharges the coach batteries.
I recommend you check with your Airstream dealer and with Lifeline regarding these bulged batteries.
- - Mike
2013 AS Interstate on 2012 MB Sprinter
- - Mike
Boxster1971 is online now   Reply With Quote
Old 09-23-2014, 06:13 AM   #21
BikerBill
2014 Interstate Ext. Coach
Poconos of Pa , Pennsylvania
Roadtrek's new E-trek package would prevent the engine alternator from overcharging the rv batteries since they install a different, 2nd generator for charging the rv batteries. Totally separate system for the rv.
Bikerbill is offline   Reply With Quote
Old 10-21-2014, 10:56 AM   #22
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Update to battery install
Update: installed new Lifeline Batteries (took about 30 minutes to do myself) While in there I pulled out back wall of electrical to reach the inverter and connected a Magnum Battery Temp Sensor; so the charger could work properly (shame on Airstream).
After 24 hrs plugged in on 30AMP to charge everything fully I took it off A/C power (Fridge Off, Antenna Off, LP Off) and 4 days later was setting at 90% charge still (Solar Panel Clean & in partial Sun).
For Reference: with old batteries and no load; the batteries were < 8v in less than 2 hours. So we'll see with time if the problem was dead batteries on the lot when unit was initially picked up (suspected since NEVER over 24 hours with light load); or something to do with charging system (doubtful since all tests good).
Mike
Old 11-04-2014, 03:09 PM   #23
Milatv, like your ladder to get to top. Did you custom make that or purchase it? az
andyzager is offline   Reply With Quote
Old 11-04-2014, 03:24 PM   #24
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Replace House Batteries (Magnum Inverter)
I think this was it. Easy install only thing is the left door won't fold all the way around (release catch - open to magnet). I find I use it more to strap stuff to (chairs, bike, grill, etc) than I use it to climb on the roof. But I do use it for that as well. Mainly yo clean solar panel.
http://www.amazon.com/gp/aw/d/B00177..._SY115&simLd=1.
Mike
Mike
Old 11-04-2014, 06:11 PM   #25
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Checked it out on Amazon and in one place it says it's a bright dipped polished finish on thick gauge aluminum tubing. Then in another it says it's heavy duty stainless steel with an electro polished finish. Can you tell which it is?
Also it says it hooks over the door tabs. Does that mean it hooks over the top edge of the door? The picture is unclear but doesn't appear to have hooks on the top. Is it attached at the bottom?
Also says it comes in two lengths but only lists one - 6'. I'm guessing 6' would work on our high top van.
Upgrading from Tripplite to Magnum inverter/charger russ240 Sprinter and B-van Forum 12 04-27-2018 10:54 PM
Magnum settings for LifeLine Batteries AtlantaCpl Sprinter and B-van Forum 21 10-26-2014 02:03 PM
prices of Magnum MS2812 2800W Inverter with 125 Amp Charger carl2591 Batteries, Univolts, Converters & Inverters 42 01-28-2014 03:26 AM
Magnum Inverter upgrades Support Admin Airstream Classifieds 0 09-23-2013 12:28 PM
Magnum Energy inverter - chargers Jammer Batteries, Univolts, Converters & Inverters 5 03-22-2011 10:11 PM
