Old 03-28-2015, 06:28 AM   #15
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
So...what do you do with the old fluid? How do you dispose of it properly?
I wonder if this "watery brake fluid" could also contribute to brake lines rotting out. Certainly, living in the snow/salt belt is a major contributor to that, but just wondering if this accelerates the process.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 03-28-2015, 07:14 AM   #16
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
I take my used fluids to the business that does my oil changes. Just took about 7 gallons of tranny fluid there a couple days ago. No charge. I think its a chain called Speed Lube.
mayco is offline   Reply With Quote
Old 03-28-2015, 05:37 PM   #17
jcl
Vancouver , British Columbia
Originally Posted by J. Morgan View Post
I mean really, it seems to me that a brake system will be exposed to the atmosphere to a greater extent in a single bleeding event than it will be for years and years of normal service and regular topping off.
It is exposed to air and moisture every time the cap is taken off. After 11 years, I would have the fluid changed.
Usually it happens when the calipers are looked at. If all that has been done is changing pads, that isn't a brake job, it is just changing pads. My $0.02
jcl is online now   Reply With Quote
Old 03-29-2015, 09:04 AM   #18
2003 25' Safari
Riverside , California
Original fluid in my o4 Tahoe and my o8 Silverado, original everything else but pads.
I am not saying that any person shouldn't change their fluid, but fact is, the brake system is sealed from the air, so it should not pick up water.
Maybe the manufacturers might recommend changing the fluid more to cover their own donkey than to protect us?
I wonder how much a dealer charges for changing brake fluid?
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
The brake syeem is NOT sealed from air.they all have vented master cylinders
2003 25' Safari
2005 Ram 2500 4x4
1994 Ram 2500 4x4
2015 Toyota Tacoma trd 4x4
2000 Jeep Wrangler 4x4
Bob4x4 is offline   Reply With Quote
Old 03-29-2015, 09:09 AM   #19
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
so....you pay someone to change your engine oil, but you do your own tranny and brake fluid changes? what's up with that?
Air:291
Wbcci: 3752
'73 Safari 23'
Old 03-29-2015, 09:34 AM   #20
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Pre ABS brakes on GM vehicles are not vented. They had a bellows gasket that was allowed to change shape to allow for the decreasing volume in the master cylinder as the pads wear. Haven't checked my current GM vehicle w/ ABS.
Old 03-29-2015, 10:22 AM   #21
Cardinal283's Avatar
Dallas , Texas
As a mechanic who is ASE certified in brakes (among other things) the post early on in this thread are correct. Brake fluid absorbs moisture from the atmosphere. This leads to corrosion in the brake system. And lowered boiling pint. There is a test that can be done to check the brake fluid. It's a strip that is dipped in the reservoir and essential checks the copper levels in the fluid as an indication of corrosion occurring due to moisture in the fluid. Compare the color of the strip to the chart on the bottle. Most mechanics con perform this test. I'm sure you can buy the test strips online as well.
Cardinal283 is offline   Reply With Quote
Old 03-29-2015, 02:15 PM   #22
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
If you want to do this project yourself you need to buy one of these.
Mityvac Hand Vacuum Pump Kits
http://www.ebay.ca/itm/Mityvac-MV802...-/140538534873
I have the cheapest on that is just a hand pump without gauge. This way you can drain the brake fluid into the container under the pump and see what condition the fluid is.
Just place wrench on bleeder, start pumping to create vacuum, open bleeder and continue pumping, shutting off bleeder once you have pumped out an amount of fluid that is smaller than your reservoir. Just remember to remove old brake fluid in reservoir BEFORE adding new fluid to reservoir and then drain lines; that way new fluid is instantly going into the system.
I just did my 07 Altima this afternoon and just love my pump, as you're not yelling.....RELEASE, PUMP, HOLD....repeat a hundred times.
Cheers
Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Isuzusweet is online now   Reply With Quote
Old 09-21-2017, 06:08 PM   #23
Undereducated AS Newbie
1989 34.5' Airstream 345
Charlotte , North Carolina
Iron is porous
[QUOTE=J.I am not saying that any person shouldn't change their fluid, but fact is, the brake system is sealed from the air, so it should not pick up water.
[/QUOTE]
~40 years ago I discovered Castrol L(ow)M(oisture)A(bsorption) when I was SCCA road racing. Braking from high speeds, you quickly realized you needed every edge & flushing brake fluid was a known positive because of the hygroscopic nature of brake fluid. Castrol LMA is still the only brake fluid I use.
Bought a state fleet 3/4 ton Dodge that had been out of service for over a year. It seemed to need nothing mechanically, so I planned on driving it the 50 miles home. Wound up driving slower & slower. The brake fluid contained so much water as I applied the brakes the fluid got hotter, turning the water to steam. Steam is not compressible, the calipers weren't releasing & got tighter & tighter until I finally had to open the front bleed screws, releasing steam & scalding water/brake fluid. LESSON LEARNED!
wimpy is offline   Reply With Quote
Old 09-21-2017, 06:23 PM   #24
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Does anyone use Silicone brake fluid? I do not think it absorbs water.
Old 09-22-2017, 05:46 AM   #25
A note for T1N Sprinter owners... the manual clearly says "every 2 years" (on page 300 of the 2006 edition). I'm scratching my head wondering why MB didn't recommend that to me when I just had them change the transmission fluid about four weeks ago.
Old 09-22-2017, 06:20 AM   #26
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
On the contrary, steam is VERY compressible, just like all vapors. But like all gases under pressure, it wants to expand, and it will expand in every direction it's allowed to, in this case toward the brake calipers.
Just a minor quibble. Your explanation makes perfect sense otherwise.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-22-2017, 07:03 AM   #27
jcl
Not me. Silicone fluid has its own issues. It absorbs air, leading to a spongy pedal. It can be harder to bleed the system. And changing to silicone fluid should be done after a full system rebuild, since you shouldn't mix the fluids.
It is a good choice for a show car where performance doesn't matter but paint stripping ability can be a problem.
Old 09-22-2017, 08:45 AM   #28
Lotus54's Avatar
Port Angeles , Washington
It has always been recommended (by most) to change brake fluid every two years. Ever since I can remember.
Not only will the moisture cause fading issues, it can also cause corrosion issues.
Some manufacturers recommended changes the flexible hoses every two years also. Iíve seen them fail internally myself several times- sometimes acting like a one-way valve pumping the brakes up and holding them on.
Certainly best if the ABS pump is cycled, but even if not, at least MOST of the fluid would be new.
Change should be done with hydraulic clutches also (unless they use mineral oil, which some motorcycles use).
I have not done the AI- but I need to get on that soon!
Mark
Lotus54 is offline   Reply With Quote
Brake fluid change wvabeer Land Yacht/Legacy Motorhomes 21 03-15-2014 12:59 PM
Actibrake leaking brake fluid adonh Brakes & Brake Controllers 7 11-13-2011 05:12 PM
Brake Fluid Reservoir Barb H. Land Yacht/Legacy Motorhomes 2 08-08-2011 08:03 AM
Need help on how to access brake fluid reservoire on a 1997 airstrams cutter poloharvey Brakes & Brake Controllers 3 10-11-2010 10:28 PM
Brake Fluid Reservior DonaldWyllie Land Yacht/Legacy Motorhomes 3 07-15-2007 03:06 PM
