Old 08-24-2016, 06:42 PM   #1
2015 Interstate Grand Tour
Mount Washington , Kentucky
Removal of Kenwood DNN991HD
My Kenwood touch screen has died and I need to remove it to send it back for warranty. Does anyone know how AS installed this and how to remove it. I bought the removal keys off Amazon, removed the small frame around it but cannot get the unit out. Picture shows to put the keys half way up the height and push down. There is no space at all half way up and the space at the bottom is doing nothing. I'm afraid to break it and void the warranty.
jp
JayP is offline   Reply With Quote
Old 08-24-2016, 10:17 PM   #2
2011 Interstate Coach
Muskogee , Oklahoma
jp
To remove the headunit, you have to pull off the entire faceplate, which is held on with snaps. To do that, you will need a small flat blade. You can get these at Harbor Freight. Start at the top, and gently pry it off, and work your way around the entire faceplate. After you remove it, you will see that the head unit is held in with four screws. You simply remove the screws and pull it out, unhook the wires and you are done. Here's a link that shows how it's done. You don't use the keys at all with aftermarket head units-only the original radio MB put in. That's long gone. Note that in step 2, it shows 4 screws, two at the top and two at the bottom, and step 3 shows two more. You can ignore the two on the bottom in step 2-I'm pretty sure you won't have to unscrew them as they only hold in the side trim pieces.
http://www.fitaudio.com/?View=entry&EntryID=134
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 08-24-2016, 11:34 PM   #3
Muskogee , Oklahoma
Here's what I mean by the "entire" faceplate in case that was not clear.
Old 08-25-2016, 03:45 PM   #4
73shark's Avatar
Overland Park , Kansas
Here's what the trim panel removal tools look like:
or this:
Old 08-25-2016, 04:03 PM   #5
Rockwell , North Carolina
This thread may help.
http://www.airforums.com/forums/f240...rs-126668.html
jerhofer is offline   Reply With Quote
Old 08-25-2016, 05:40 PM   #6
Thanks Guys
That thread showing the fake wood trim piece needing to be removed to reveal the 4 screws is just what I needed. Should be about 10 minutes.
jp
Kenwood TV Media System Confusion Supercatspjs Audio, Video & TV 11 05-16-2015 08:09 PM
Kenwood DNX7180 / iPhone 5 issues kaylorsan Sprinter and B-van Forum 7 10-14-2013 03:50 PM
Kenwood DNX6190 AirTurtle91 Sprinter and B-van Forum 68 09-02-2013 01:31 PM
How to turn off Kenwood in Dash Display, hot water? Doug454 Sprinter and B-van Forum 5 05-19-2013 06:29 PM
Kenwood Stereo 2013 Interstate Suru Audio, Video & TV 6 05-06-2013 04:27 PM
