Old 05-18-2014, 01:31 PM   #15
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Originally Posted by 73shark View Post
So it appears that the parasitic draws, ie things that can't be turned off are the BIM, solar controller, propane detector, and radio memory. But wouldn't the radio memory be on the chassis battery?
Since mine has the Tripp-Lite, I can turn it off.
When my AI was new I experimented by flicking off ALL the breakers under the rear sofa in an attempt to get around the parasitic draws and left it plugged into shore power. Battery was dead of course after a few days (I was really dumb then) and the Kenwood had lost all its settings.
Old 05-18-2014, 03:56 PM   #16
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Oh, I just found out today, by trial and error, that the tank heaters are a possible parasitic draw, too, though most of us won't have to worry about that one. I had the main disconnect switched off, and the Tripplite also switched off, and accidentally bumped the tank heater switch while transferring some gear. Sure enough, the switch lit up. I am sure glad for the lighted switch, else I might not have noticed it accidentally switched on! I wonder if that's why the tank heater switch is the only switch that lights up?
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 05-18-2014, 05:15 PM   #17
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Originally Posted by Bikerbill View Post
The radio draw memory from the RV batteries even when the Master Switch if Off. I have a set of wiring diagrams from Airstream and I took the time to follow all the circuits to determine my statements.
OK Bikerbill -- how did you get a set of wiring diagrams from Airstream? I thought they protected them like the crown jewels for some reason.
- - Mike
Old 05-19-2014, 07:35 AM   #18
BikerBill
Poconos of Pa , Pennsylvania
I asked politely as my conversations were knowledgable enough for them to be comfortable with me to send the file. I sort of did promise not to share them, but nothing was said about me not looking and answering questions though.
Bikerbill is offline   Reply With Quote
Old 05-27-2014, 07:06 AM   #19
norman , Oklahoma
Originally Posted by Protagonist View Post
I'd make the water heater the first thing shut off by the 12vDC EMS, if it's in electric mode, because you can always switch over the water heater to propane mode, and an electric heating element is a major electricity user as well.
Am I incorrect if believing that the electric water heater element due to the size of it's load can never run on the batteries and, like the a/c, the microwave and the coffee pot, can only run on shore power or (in a very inefficient use of propane) off of the generator?
russ240 is offline   Reply With Quote
Old 05-27-2014, 08:38 AM   #20
Newbie
joemikeb's Avatar
Fort Worth , Texas
The A/C or the microwave or the coffee pot can run either on shore power or the generator but not all at the same time and none of them will run on battery power. The electric water heater will however run on battery power. Whether you are on shore power or running the generator you only have a 30 amp system and any two of those devices would overload the system. To prevent that the power management system will automatically shut down the device that uses the most power first and if necessary the next down the line and the next until the load is reduced to below 30 amps. If you are connected to shore power and start the generator, the system will drop the shore power and switch to the generator so you still only have 30 amps available.
Make errors — otherwise the Great Spirit realizes
you have finished your purpose on earth.
— Navajo saying
joemikeb is offline   Reply With Quote
Old 05-27-2014, 09:24 AM   #21
BikerBill
joemikeb, the water heater WILL NOT operate on the inverter while on battery power. It is not wired to the inverter, only to Shore Power and/or Generator. The water heater electric element is 1400 watts and the inverter only provides 1000 watts at 115 volts. I am looking at the wiring diagram for my 2014/13. The AC, Electric Water Heater, M-wave, the outlet over the sink and back on the right side by the lounge and outside on the right rear corner operate ONLY on 115 shore power or generator along with the power to the inverter itself.
Old 05-27-2014, 10:40 AM   #22
UKDUDE's Avatar
Sedona , Arizona
What do the coffee pot references refer to? I have no coffee pot in mine.
Old 05-27-2014, 02:15 PM   #23
Newbie
joemikeb's Avatar
Fort Worth , Texas
There is a plug located in the overhead shelf above the left end of the "kitchen" counter that is designated as the "Coffee Pot" plug. It is only hot when on shore power or the generator is running. It is intended for high wattage devices, such as a coffee pot or perhaps an electric skillet or other high amperage device.
— Navajo saying
Old 05-27-2014, 03:03 PM   #24
Fulton , Maryland
Hidden Coffee Maker Outlet and Aisle Light Wiring
On my 2013 there was also a 120V AC coffee maker outlet buried behind the panel in overhead cabinet right above the sink. See first photo below. I think this is a violation of any good wiring practice to enclose a connection behind a hidden panel.
I changed it to a duplex receptacle and remounted it on outside of panel so I can use this outlet with slow cooker in sink. See second photo below.
I also found wiring for another 12V DC aisle light next to the propane alarm on floor right behind the galley. See yellow connectors in third photo below. I got an extra aisle light from Airstream dealer and installed it -- works great for added night lighting next to bathroom. See fourth photo below.
Airstream apparently hasn't changed the wiring design for things they eliminated in production. That saves them from having to update their precious wiring diagrams.
Name:	Hidden Coffe Maker Outlet2.jpg
ID:	212977   Click image for larger version
Name:	New Coffe Maker Outlet.jpg
ID:	212979   Click image for larger version
- - Mike
Old 05-27-2014, 04:00 PM   #25
Newbie
joemikeb's Avatar
Fort Worth , Texas
Out of curiosity I just went out and opened up that panel above the sink in my 2013 lounge AI and found only wiring for the 12V kitchen cabinet counter lights and the pump switch. I looked in the similar panel in the cabinet over the range and found the wiring for the "Coffee Pot" outlet and some more 12V wires but no sign of another 110V outlet or way to install one without cutting the cable and splicing it in.
I am beginning to think the reason the wiring diagrams are so hard to come by is much of the wiring is ad hoc and can vary from unit to unit.
— Navajo saying
Old 05-27-2014, 07:37 PM   #26
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Mine has the wiring behind the panel where Boxter mounted his outlet in photo #2.
Good to hear about the extra aisle lite wiring under the streetside seat. Will have to check mine. Bet the lite is pricey tho. Paid ~$60 for one of the reading lites over the lounge.
Old 05-27-2014, 08:27 PM   #27
Fulton , Maryland
I checked my records. It was only $16 last October when I got it from dealer. See photo below of what it looked like before I installed it, chrome outer ring not in photo. I think it was P/N 522377, it is the same light used in the side step foot well. See attached page from Airstream Interstate Part Book.
Hope this helps,
File Type: pdf 2013 Airstream Interstate Parts Book page I-45.pdf (20.5 KB, 19 views)
- - Mike
Old 05-28-2014, 03:31 AM   #28
Hope this helps,
I'm really surprised that Airstream quit putting a courtesy light there. My 2012 has a light there, although it is under the LPG detector rather than over it.
WBCCI #1105
TAC LA-4
Storage Solutions: battery box and new made-to-open twin beds whitefawn All Argosy Trailers 5 12-19-2014 02:33 PM
Battery Box Modification Options Ridgerunner3 Batteries, Univolts, Converters & Inverters 5 10-09-2013 04:28 PM
Battery Issues aswbe Batteries, Univolts, Converters & Inverters 29 08-08-2011 07:27 PM
