Old 04-21-2016, 08:06 AM   #1
2014 27' Flying Cloud
Seguin , Texas
Releasing Parking Brake
Argh. CoachNet folks put on the parking brake before they changed my tire (which is GOOD). What's bad is can't get the parking brake off!!
2015. Simple Lever beside driver's seat. Pushed button, slightly pulled up on lever and then pushed to the floor. Nothing. Lamp still on and brake is locked so it's not just the indicator light.
Page 150 of the Sprinter manual explains how to do and that's what I've done. Is there some quirky trick to this.....
Laidback1 is offline   Reply With Quote
Old 04-21-2016, 08:11 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Try this…
Push the lever all the way to the floor. Pull it up without pressing the button, until it goes one click past where it was before (you should hear/feel the click). THEN press the button while pushing down.
If the service tech over-applied the lever, you will have to pull up farther than you think the lever will go. But trust me, it will go. You can't apply enough force with just your arms to break the lever.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-21-2016, 11:12 AM   #3
Seguin , Texas
Protag,
Thanks. That was it. I just wasn't going far enough because I felt it would break. Must have been over applied
Gas Water Heater - Main burner releasing gas without pilot Gasgano1979 Water Heaters, Filters & Pumps 14 01-25-2015 11:45 AM
Dodge Releasing the 1500 Diesel Half Ton Kevin245 Tow Vehicles 18 02-17-2013 08:48 PM
Courtesy parking or rental parking needed, Perris Valley, California skydiva Our Community 1 01-13-2011 06:13 PM
parking brake remcolent Brakes & Brake Controllers 5 03-24-2007 08:31 AM
parking brake on trailor remcolent Brakes & Brake Controllers 1 01-02-2004 09:01 PM
