10-25-2016, 05:55 PM
Port Angeles
Refrigerator not working on gas 2006 Interstate
On the maiden voyage (home from purchase) of 2006 Interstate (mid-bath)
The refrigerator works great on AC- but not on Gas.
I tried manualy lighting, it would light and burn, but go out.
Any ideas on what to check?
I could hear the gas solinoid active timing and i think the spark lighter.
But it won't light without me using a lighter.
Other than that everything is great! (Well, a bit wet on Northern California Coast)
Mark
10-25-2016, 06:02 PM
Normal
The burner on ours has had to be cleaned a few times, might check that.
Be sure the frig is on, and set to auto.
Check your fuses.
Maggie
10-25-2016, 06:47 PM
Normal
I'm guessing you have otherwise used your propane, your burners and hot water heater?
Maggie
10-25-2016, 07:18 PM
Port Angeles
Maggie
Yes,
Stovetop, furnace, hot water heater all works fine.
Plus I can see the fridge light when I use a lighter.
Mark
10-25-2016, 09:01 PM
2014 Interstate Ext. Coach
Sedona
Dont most gas appliances have a thermo cutoff to cut off the gas supply in case the flame goes out? Maybe that's faulty?
10-26-2016, 12:48 PM
Ventura County
Mark
Same thing happened to us last trip . Get some pipe cleaners at smoke shop and a can of air used for computers etc. shut everything off . Run pipe cleaner through burners parts after you remove the access door . Shoot canned air in there . More then likely a spider made a web in there . Hope this helps . Pat
10-26-2016, 07:36 PM
League City
The inside of the flue may have had some rust buildup flake off and plug the jet. If you can clean up the orifice, it might hold a flame for you.
10-26-2016, 08:56 PM
Port Angeles
I'll try that as soon as I can.
Pouring rain right now.
