Old 11-03-2014, 04:37 PM   #1
nesoutlook's Avatar
2013 Interstate Coach
Boca Raton , Florida
Refrigerator and battery drainage
I can't remember where I read this on the forum but disconnecting the ac plug for the refrigerator will reduce the battery drain since the inverter need not be running in order to run the refrigerator. Am I correct on this issue? If I am correct what other items can run with the inverter shut down? Just trying to get a better understanding of the electrical system for future boondocking adventures. My Airstream is a 2013 interstate ext on a 2012 MB Sprinter. Any help will be much appreciated.
nesoutlook is offline   Reply With Quote
Old 11-03-2014, 06:04 PM   #2
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
This will reduce your 110 v AC power use from the converter. Its pretty much like unplugging your home kitchen fridge. But it is just a cooler then. It won't get any colder. The 12 v DC power your fridge uses is for the controls, not for cooling.
If you have an inverter, it will still use power with nothing plued into it. The best way to prevent inverter battery power drain is to unplug/pull fuse from inverter.
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 11-03-2014, 06:43 PM   #3
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Not entirely true. The NovaKool frig operates on 12 VDC or 120 VAC. If the inverter is turned off (Since you have the Magnum inverter, I don't know if you can turn it off or shut the breaker off if there is one as 3 Dog Nite suggested. The TrippLite inverter on mine does have an Off switch.), it will run on 12V. If the inverter is on, it will run on 120 VAC which the frig reduces and rectifies to 12 VDC which does waste power. I think that was what you referring to regarding pulling the AC plug.
Old 11-03-2014, 06:45 PM   #4
Boxster1971's Avatar
Fulton , Maryland
Sorry 3 Dog Night that's not correct. The refrigerator in a 2013 Interstate is all electric. The compressor and all control functions are 12v DC. The 110v AC plug on refrigerator is a useless alternative if powered by the inverter as it is wired on the 2013 Interstate. The refrigerator has a converter built in that changes the 110v AC to 12v DC when plugged into an AC source.
Most of us have just unplugged it from the 110v AC receptacle under the sink in galley and then run refrigerator solely on 12v DC.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 11-03-2014, 06:52 PM   #5
3 Dog Nite's Avatar
OK, thanks for the new knowledge. It would be nice if my fridge ran on 12 v.
Old 11-03-2014, 06:54 PM   #6
2005 22' Interstate
Pittsburgh , Pennsylvania
Yes. Running a NovaKool on 120VAC almost never makes sense. Running from 12VDC is the "native" mode of the compressor. If you use the 120VAC input when not plugged into shore power, you would be converting from 12VDC to 120VAC (using the coach inverter) and then immediately turning it back to 12VDC (using the NovaKool's built-in converter). If you ARE plugged into shore power, simply let your coach converter/charger make the 12VDC. The 120VAC input really makes little sense unless you are using the fridge at home.
Formerly: 2005 Airstream Interstate (2500 T1N)
Now: 2014 Great West Vans Legend SE (3500 NCV3)
avanti is offline   Reply With Quote
Old 11-03-2014, 07:52 PM   #7
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
Great info. I know it runs on 12v or/and on 120v but did not know it would internally convert the 120v to 12v so having it plugged in on 120v makes no sense I unplug it tomorrow.
Peter
PSchw is offline   Reply With Quote
Old 11-04-2014, 08:25 PM   #8
toskeysam's Avatar
Townsend , Tennessee
OK You guys have raised my curiosity level. I upgraded the Magnum controller supplied with my Interstate to the Magnum ME-RC50. It has on/off button on the main panel. I leave it off unless I have a specific need for it.
It does not come on when I disconnect from shore power with the refrigerator running....and as far as I can tell, the refrigerator keeps running. Hmmmmmm
FMCA # 436814
toskeysam is online now   Reply With Quote
Old 11-04-2014, 08:28 PM   #9
toskeysam's Avatar
let me clarify that last post. There are 2 on/off buttons on the ME-RC50. One for charge and one for the inverter. The inverter button is what I almost never turn on.
FMCA # 436814
Old 11-04-2014, 08:50 PM   #10
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
On my 2014 - which came with the Magnum - I only ever turn on the inverter if I am unhooked and need to use the TV's or any of the sockets for anything requiring limited power (laptop for example).
The refrigerator will only come on when the 12V coach system is enabled.
Does yours work that way? Otherwise I wonder if it wasn't wired according to Airsteam's standard.
Old 11-04-2014, 08:52 PM   #11
73shark's Avatar
As it should. It'll run on 12V until it sees 120 VAC and then it uses that but converts it to 12 VDC.
I only turn the inverter on when the grand-kids want to watch TV or to charge various devices.
Old 11-05-2014, 08:15 AM   #12
nesoutlook's Avatar
So all functions work without the inverter accept the ac outlets. Is this correct?
Old 11-05-2014, 08:35 AM   #13
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Outlets, microwave, and air conditioner all require 120vAC. All of them work on shore power or on-board generator. Outlets work on inverter, but microwave and air conditioner do not.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-05-2014, 09:20 AM   #14
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
The Novakool is a great product, However the "auto sensor" that switches from 12volt to 110 volt should be a switch not a sensor. Not a good design for those who want to boondock. I would think there could be a way to disconnecting the sensor and hard wiring a switch in place. You could also hardwire the 110volt connection into the shore power only side of the breaker box in a sense by passing the inverter. If it was up to me I would think this would be the better way to wire the coach. I like the Airstream Interstates, but there does seam to be some problems with the way the wiring system work, or rather don't work.
By the way is there many out there using solar systems on these rigs?!
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
ABS drainage system - 2005 Classic RoadToad 2001 - 2005 Classic 16 01-29-2009 02:36 PM
Urgent vintage grey water drainage question! 1959newbie Waste Systems, Tanks & Totes 6 04-21-2007 10:58 PM
Water Tank Drainage popeyedoyle1 Fresh Water Systems 8 03-07-2006 05:50 PM
16' ccd Bambi drainage system question. gbrentsmith Waste Systems, Tanks & Totes 12 10-17-2005 10:08 PM
