Old 12-13-2018, 01:55 PM   #1
Haddon Heights , New Jersey
Refilling propane tank
I did visit a local U-haul location to refill propane in my 2018 AI. The technician there was asking me for plate with propane tank info such us model #, size, etc.
I could not help him (this was my first time.....).
Is there somewhere such plate in AI located? Is this normal that U-haul asking for this info in order to fill the tank?
Voytek is offline   Reply With Quote
Old 12-13-2018, 01:57 PM   #2
2015 Interstate Grand Tour
Bozeman , Ohio
No, that has never occurred during my refills.
jmh2015 is offline   Reply With Quote
Old 12-13-2018, 02:05 PM   #3
YES - going forward, there will be increased scrutiny at many propane filling stations. A Class B Forum thread (here) began a discussion of the U-Haul protocol three days ago.
Right now the reports seem to be centering on U-Haul, due to the lawsuit that they reportedly settled. But what one retail outlet does, the others will soon follow in doing.
The plate on the face of your tank will show the year and spec. You can see pics of my tank here. We replaced ours because it was leaking at the connection threads.
IIRC, it was Protag who offered the great suggestion to carry a selfie stick in the van so that if someone needed to view the tank plate, they could shove the stick under there and see it / photograph it / whatever without having to crawl on the ground.
Old 12-13-2018, 04:06 PM   #4
Thanks for your info. That's what tech at the u-haul said that they need to record all tanks because of the lawsuit (I did hear about the explosion couple of years ago in Philadelphia).
A selfie stick is a good idea (the guy at the station was not happy to crawl under the vehicle....)
Thanks again for the input.
Old 12-13-2018, 04:13 PM   #5
Salem , Oregon
What do you do if you are over 30 and don't have a selfie stick?
NoResults is offline   Reply With Quote
Old 12-13-2018, 04:37 PM   #6
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Wow. I thought if you were over 30 you didn't take selfies.
Perhaps I was thinking of over 60.
However, I may have to get one. A large number of the photos on my iPhone were taken because it was too awkward to get my DSLR into position. For example, photos of all the labels on the components making up the new roof AC; both blower motors, condensers, compressor, etc...
A selfie stick would come in handy.
Vaughan
vswingfield is online now   Reply With Quote
Old 12-13-2018, 04:38 PM   #7
Lily&Me's Avatar
Normal , Illinois
I try to avoid using UHaul for propane, whenever possible.
They are usually the most expensive around, and sometimes have a minimum charge that doesn’t come close to the cost of our little tanks.
Maggie
Old 12-13-2018, 05:03 PM   #8
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
Are these the labels they want? I see 2 on mine.
Alex AVI is offline   Reply With Quote
Old 12-14-2018, 12:38 AM   #9
2015 Interstate Ext. Coach
Thousand Oaks , California
Regarding pricing, my local U-Haul has lately been selling to me at the reduced price for propane fueled vehicles. The employee said that they could honor the lower price because it's a propane tank versus a removable propane cylinder. As always, your mileage may vary.
Ryoungca is offline   Reply With Quote
Old 12-14-2018, 01:50 AM   #10
Alex AVI's Avatar
RYOUNGCA - Good tip, will try that next time. Can't hurt to ask
Old 12-14-2018, 05:52 AM   #11
Around here, U-Haul is the cheapest, not the most expensive. The issue is that many others have minimum purchase quantities that exceed the size of the Interstate's tank. If you don't buy the minimum, they charge you for it anyway.
Alex, it's a metal-engraved plate welded onto the tank. It looks like this, only not rusted (this is the tank we removed). Photo right, approx. middle, you can see the birth year 2006 - that's what they'll be looking to confirm (that it's less than 10 years old):
I bought a selfie stick specifically for this task. The only other time I've used that stick is to demonstrate the roomy girth of the NEMO Disco sleeping bag. This is literally the one selfie stick pic that I have:
Old 12-14-2018, 08:49 AM   #12
Alex AVI's Avatar
INTERBLOG - Thanks. Will look further. That pic was just an archive I had from 1 angle. Plate you mention probably at a different angle, how much you wanna bet I will need my selfie stick to find it
Old 12-14-2018, 08:49 AM   #13
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
This is pretty odd. Why would UHaul require specs on a fixed-mount cylinder?
Just for clarification, US-based RVs use two types of cylinders, *DOT and **ASME. DOT cylinders are the usual ones on sees on tow-behind RVs: They are removable. And they require recertification from time to time; hence the requirement that fillers check the recertification date. ASME cylinders, by contrast, are fixed mount. They are generally found on motorhomes, including the Interstate. And they do not require periodic recertification. There is no stamped date that would prevent a refill.
That said, fillers are free and encouraged not to fill ANY cylinder, DOT or ASME, that appears very rusty, dented, or otherwise damaged.
Lynn
*DOT = Department of Transportation
**AMerican Society of Mechanical Engineers
WBCCI 21043
Old 12-14-2018, 02:51 PM   #14
I mentioned as well on the Class B Forum that our Texas U-Haul staff must take a phone picture of the propane fill port and upload it to an internet site before they can complete the sales transaction (this from my own direct experience on my last fill-up). They want proof of the config / condition of the fill port for their records. The shut-off switch is right next to our fill port so presumably they want a pic to prove that the tank was shut off while being filled.
If any given tank type has no inspection or recert protocol or calendar, then it has to be either an accidental omission at either the regulatory or the engineering standards level. That food truck explosion in Philadelphia that killed the mother and daughter... their propane tank was reportedly manufactured in 1948. Nobody in their right mind would knowingly use a tank that old, on general principle - recert schedules be damned. The deceased must not have been aware of where their tank had originated.
For cross-reference, we also had a propane discussion along these lines at a previous thread called Sprinter fire and explosion. There was a Roadtrek last year that was engulfed in a massive fire at a California propane filling station. I'm a bit surprised it took U-Haul to get the ball rolling on more stringent filling requirements because U-Haul's was by no means the only recent propane disaster.
Refilling propane tank sciggy87 Base Camp 1 11-28-2018 07:14 PM
LP tank removal for refilling DeltaRon 2016 - Current Classic (all lengths) 11 07-16-2018 08:15 AM
Northeast Refilling potable water Mifair Boondocking 18 08-22-2012 04:00 PM
New Valves & Refilling 30# Aluminum Tanks nairnchyz LP Gas, Piping, Tanks & Regulators 21 04-07-2009 08:20 AM
LP Tanks (Refilling) silversled LP Gas, Piping, Tanks & Regulators 6 12-29-2006 09:51 PM
